Old 09-09-2012, 07:00 AM   #1981
Stockers are 24mm wide.
Anyone have any tips on building the stock gear diffs? Mine keep leaking and if i tighten them hard enough to stop leaking it become very hard to turn.
d.k.vmatt is offline   Reply With Quote
Old 09-09-2012, 07:42 AM   #1982
wollow86's Avatar
Have you tried building them as per 3Racings guide?
Can be found here: http://os.3racing.hk/articles.php?articles_key=133
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 09-09-2012, 08:02 AM   #1983
I will try that thanks
Old 09-09-2012, 01:30 PM   #1984
shadowracer24's Avatar
The best way I have found is to run the screws in with the top first until it is snug and then take the top of and sand the case flat. When you first put the screws in it pulls a little of the plastic up around the screw holes and the seal will not seat fully. after you sand the case down level you take that high spot off and then the case will seal up good and not leak. Have not had a leak in mine since doing this and have ran 12 or so races with it.
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 09-09-2012, 04:54 PM   #1985
Thanks shadow
I saw that last night when i pulled it apart so i sanded it flat and left it over night and it hasnt leaked. But then i read the tutorial last night and it says to sand the flash off the gears too. So back apart the diff goes haha. Iv got a race on sunday so i need it in the best condition i can.
What shocks do people run with the +4mm carbon towers? Trf417 shocks?
Old 09-09-2012, 07:12 PM   #1986
Does anyone know if 3Racing makes a ball diff for the Sakura Zero S?
Or the part number for the steel ballstuds that come on the car?
Kevin Marcy is offline   Reply With Quote
Old 09-09-2012, 11:22 PM   #1987
Paul R's Avatar
can you order from 3racings web site ? cause there copy rights date is dated in 07 .
Paul R is offline   Reply With Quote
Old 09-10-2012, 03:59 AM   #1988
wollow86's Avatar
I order from there all the time.
Old 09-10-2012, 07:54 PM   #1989
nikkon's Avatar
Trader Rating: 245 (100%+)
Send a message via AIM to nikkon
Finally got all my parts in over the week and put mine together sunday. Still working on a few bodies for it and electronic placement. Still have to order alum bulkheads, titanium turnbuckles,Stiffer front bumper, rear cvd's and front one way.
Tekno d8/xerun 80a/hw 2250kv
Stampede 4x4/mmp/castle 1410
Slash 2wd lcg/mmp/x12
nikkon is offline   Reply With Quote
Old 09-10-2012, 08:15 PM   #1990
Nice job Nikkon! What did you use for the pink trim?
VTA = 3Racing Sakura Zero S
Mini = Tamiya M-04
Off-Road = ECX Ruckus/Torment SCT
Home Track = Jeff's RC Studio,(Fort Myers, Florida)
NewRCSim is offline   Reply With Quote
Old 09-10-2012, 08:18 PM   #1991
nikkon's Avatar
Thanks, neon paint markers you can buy at walmart in the craft area. They come in an assortment of 5 colors for $10.
Old 09-11-2012, 06:36 AM   #1992
BCZero's Avatar
Hi Kevin,
I would recommend building a gear diff with the right fluid weight over a ball diff for the zero (based on experience) however, if you're a ball diff fan and can't be swayed, the Parts you need are...
Ball Diff Parts
Steel Balls 3RB-B30
24mm Diff Spacers. 416-10A
Thrust bearings 416-10F
Diff screw set SAK-01
38T Pulley SAK-02
Diff housing SAK-03
Dust cover tape SAK-04
Bearing Set BS-SAK01/V1
By steel ball studs do you mean the 6mm Ball stud hex screws?
If so...
4.8mm 6mm Ball studs. 3RAC-BS4806/PK
4.8mm 9mm ball studs. 3RAC-BS4810/PK
Or if you mean the ones on the suspension arms which are like a ball nut, they are. 5.8mm Ball Stud. Don't have that part no. On my list for some reason...it should be in the back of the manual though...
Edit: just checked it isn't for some reason, I'll keep looking...Ok seems they are 3rac-bs58h5 with a variety of colour codes, the most normal being titanium which is 3RAC-BS58H5/TI...
Stock: XRay T3 '12, F1: Tamiya F104v2, Buggy: Tamiya TRF201, SCT: AE SC10 4x4 FT, Radio: Airtronics MT-4
BCZero is offline   Reply With Quote
Old 09-11-2012, 07:21 AM   #1993
ta04evah's Avatar
Originally Posted by BCZero View Post
Hi Kevin,
Ball Diff Parts
Steel Balls 3RB-B30
38T Pulley SAK-02
Diff housing SAK-03
Got my Zero S in the mail today and I was going to try and make a ball diff. However after seeing what I would have to order I think it's a good time to learn to build & drive with gear diffs.
Nice work with the pink trim nikkon.
I was gifted a few upgrade parts such as alloy bulkheads, cf shock towers along with a cf lower & upper deck from a Sakura Zero.
I'm still considering using the standard Zero S chassis even after I flip the belts for the upright motor mount. The reason being that I'll still be able to utilise parts of the battery holder that the S comes with, I'm no fan of taping batteries into a car.
Should I do this or go with the cf chassis instead and look into different ways of securing the battery?
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 09-11-2012, 07:59 AM   #1994
SteveM's Avatar
Trader Rating: 125 (100%+)
Cheers
Rob.
There was a mod posted some time ago where a chap used the AE TC6 graphite lipo battery braces along with the stock Zero S strap.
SteveM is offline   Reply With Quote
Old 09-11-2012, 09:23 AM   #1995
FauxMako's Avatar
Haven't ever used the CF wide chassis, but the CF narrow chassis comes with battery braces that make tape mounting the battery very easy.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
SEO by vBSEO 3.5.0
