Old 09-07-2012, 01:05 AM   #1966
BCZero's Avatar
Originally Posted by SteveM View Post
Which part number from Spec-R did you use?
Steve, I'm using the 3racing ones designed for the X1
3racing part no. SAK-X27 SSK driveshaft
Stock: XRay T3 '12, F1: Tamiya F104v2, Buggy: Tamiya TRF201, SCT: AE SC10 4x4 FT, Radio: Airtronics MT-4
BCZero is offline   Reply With Quote
Old 09-07-2012, 01:47 AM   #1967
Originally Posted by Glarke View Post
Actually probably a better question is - Is it possible to get a FDR of 4.0 or lower and a free drive train with just the kit parts (and new spur/pinion)?
Mine is 3.33 as of now. Heheheh. And yes it's possible.
issuzark is offline   Reply With Quote
Old 09-07-2012, 02:59 AM   #1968
My servo keeps centering in a new spot every time causing the car not to go straight. Car or electronics issue?
d.k.vmatt is offline   Reply With Quote
Old 09-07-2012, 03:11 AM   #1969
wollow86's Avatar
It's probably the servo saver. Are you running the kit one? If so get a kimbrough. Will solve it for you.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 09-07-2012, 03:26 AM   #1970
SteveM's Avatar
Trader Rating: 133 (100%+)
Perfect...thanks.
SteveM is offline   Reply With Quote
Old 09-07-2012, 03:34 AM   #1971
I'm running a hd 3 racing one
Old 09-07-2012, 03:46 AM   #1972
wollow86's Avatar
Not sure about the HD part.. but 3Racing savers are terrible. Have been on every 3R car I've owned. It's most likely the issue. Get a kimbrough, not expensive (should be less then $10 shipped).
Old 09-07-2012, 04:02 AM   #1973
got a link. i need it by next weekend haha
Old 09-07-2012, 05:37 AM   #1974
wollow86's Avatar
I usually just use ebay
Old 09-07-2012, 08:16 AM   #1975
Guys, does increasing the gear ratio make the car harder to even push from a stationary position? That's what happened to my car. I'm running a 40t pinion to a 70t spur.
Also, causing my FDR to be now 3.33
Will it actually make the car harder to push from stationary?
Old 09-07-2012, 03:13 PM   #1976
If I understand right yes it will with the motor installed. The lower FDR will mean to push the car a fixed distance you are rotating the motor more revolutions = more work done
Glarke is offline   Reply With Quote
Old 09-07-2012, 07:16 PM   #1977
Oh all right! Thanks! Was quite worried about it.
Old 09-08-2012, 01:09 AM   #1978
Sorry Ive got that back to front. Fewer revolutions which means you are taking away mechanical advantage (moving closer to a 1:1 ratio) which has the same end result. Harder to push
Old 09-08-2012, 02:51 AM   #1979
ta04evah's Avatar
The Hi torque Tamiya ones work well too, the 3rd spring is tricky to get on but it's worth the effort.
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 09-08-2012, 03:20 AM   #1980
What width are the stock wheels?
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
