Old 08-28-2012, 03:50 PM   #1936
Originally Posted by d.k.vmatt View Post
Iv started building my kit with the v2 vertical motor mount SAK-66/v2 and Iv found the stock and the carbon top deck Iv got wont fit by miles. Is there a special part number for use with this motor mount?
The carbon deck should work fine and the stock frp deck will fit with some grinding. it is a little tight by the vertical arm but it will fit. If you are still having problems post some pics so we can help better.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 08-28-2012, 04:23 PM   #1937
I'll get some pictures tonight. I get the feeling I might have assembled the motor mount wrong.
On a side note. Damm turning those screws into the plastic is hard. Only did about 10 screws and my hand was hurting
d.k.vmatt is offline   Reply With Quote
Old 08-28-2012, 04:52 PM   #1938
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
grind some off.. and search this thread.
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 08-28-2012, 06:39 PM   #1939
sporadicidiocy's Avatar
Don't forget you'll need to flip the belts when using the vertical motor mount.
Plus you'll need to modify the battery holders to clear the flipped belts.
90% Sakura Zero: Reventon S V3.0 10.5T
Sakura Ultimate: GTB2 17.5T
F104 Pro: SXX V2 Trackstar 21.5T
F103 Chevronmodels 6-wheel conversion
sporadicidiocy is offline   Reply With Quote
Old 08-29-2012, 07:31 AM   #1940
Any pictures of the mods needed for flipped belts? Should I have an idler pully to hold it up and away from the battery?
Old 08-29-2012, 07:43 AM   #1941
SteveM's Avatar
Trader Rating: 133 (100%+)
See my post #987 for pics of the mods I made to the battery tray retainers.
SteveM is offline   Reply With Quote
Old 08-29-2012, 07:43 AM   #1942
Trader Rating: 68 (100%+)
I am going to order a spool i an mot finding the pulley seperate or does it come with it?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 08-29-2012, 08:38 AM   #1943
SteveM's Avatar
See my post #1725.
If you want a front spool, you need to purchase three separate items to assemble one.
  • SAK-02 - 38T white pulley
  • SAK-09 - Solid Axle Outer Joint (2)
  • SAK-08/PK - Front Solid Axle
Old 08-29-2012, 09:03 AM   #1944
Thanks Steve.
SpeedZone Batteries
Old 09-02-2012, 03:43 AM   #1945
HAd my first real run of my sakura today. And its a really nice car but the stock tyres are trashed with in 10 min And they provide very poor traction.
I will run it again next weekend with my new vta tyres and i hope it gets better
Old 09-02-2012, 08:55 AM   #1946
Glad you like the car. I agree with you about the stock tires. I haven't had much luck with them either. The vta tires should hook up pretty decent. You may need to male a spring change or two and some camber and toe adjustments but the kit set up should be pretty close.
Serpent S120 13.5
Old 09-03-2012, 02:34 AM   #1947
They're surprisingly good on polished concrete floor with very poor traction. When I raced with friends in a warehouse with very smooth low traction floors, I ran the stock tires and everyone wanted to know what tires I was running, because I could out-corner everyone without sliding around.
It's probably because they're far softer than any tires they ran, then I went and tried them outside in the parking lot and it was like riding on a stick of butter... and it wore out pretty fast.
Old 09-03-2012, 06:27 AM   #1948
Hey, did anyone ever think of removing the main belt, converting it to 2wd?
issuzark is offline   Reply With Quote
Old 09-03-2012, 06:34 AM   #1949
Why would you want to?
Old 09-03-2012, 08:11 AM   #1950
Well, more variations of the same car. Also, to try how 2wd works on RC.
Sounds like I'm alone with this curiosity.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
