Old 12-15-2010, 10:41 AM   #181
Madulla's Avatar
Second Zero S just arrived, don't have time to build till this weekend. Going to build this one with the FRP chassis. This one is going to be used for VTA.
Madulla is offline   Reply With Quote
Old 12-15-2010, 11:19 AM   #182
13pages and no test report on how the car handles on the track? (compared to the more expensive topdogs) it has been out for a month now!
Hatebreed is offline   Reply With Quote
Old 12-15-2010, 03:32 PM   #183
monkee's Avatar
Trader Rating: 15 (100%+)
what body are you guys using? the back body posts are very far back
monkee is offline   Reply With Quote
Old 12-15-2010, 03:39 PM   #184
RC MARKET's Avatar
Protoform LTC-R
RC MARKET is offline   Reply With Quote
Old 12-15-2010, 11:25 PM   #185
monkee's Avatar
tight fitting....
if i were using my spektrum receiver, i might have to mount it on its side..
but as this is a 'screw around' car, the cheap 2.4 will work just fine
Old 12-15-2010, 11:27 PM   #186
monkee's Avatar
Originally Posted by RC MARKET View Post
Protoform LTC-R
do you have a pic of it mounted? id like to see where the posts come out the back
Old 12-16-2010, 10:03 AM   #187
Madulla's Avatar
My body posts come out very close to the rear wing uprights on my protoform P37. I have another one sitting on the bench ready to be painted.
Old 12-16-2010, 11:08 AM   #188
monkee's Avatar
pic please!
Old 12-16-2010, 11:29 AM   #189
Madulla's Avatar
Here are a couple of pics. I ran this body on my TC3, so thats why all the holes. The Front posts are in the TC3 holes, kinda bent to fit in. The lower front holes are a little to low on the body but show the width they should be.
Old 12-16-2010, 11:36 AM   #190
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Keep in mind, you can run the rear posts on either side of the shock tower safely. It'll get you a little more room if you have a body that doesn't have all of the flat parts in the proper place.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 12-16-2010, 02:23 PM   #191
Madulla's Avatar
The pics are with the posts infront of the shock tower. If the shocks were behind then the posts would end up under the wing and it would be a pain to get the clips on.
Just learned I need to flip the belts to get the vertical motor mount on... more work than I thought hehe
Old 12-16-2010, 03:01 PM   #192
over gear's Avatar
and also a new upper deck.
over gear is offline   Reply With Quote
Old 12-16-2010, 03:09 PM   #193
Madulla's Avatar
Which upper deck do I need?
Old 12-16-2010, 03:13 PM   #194
squarehead's Avatar
SA-38/WO is used with the SA-66/PK vertical motor mount.
Everything depends.
Nothing is always.
Old 12-16-2010, 11:23 PM   #195
Is the stock spur on this vehicle considered 64 pitch?
What size pinion would fit onto this car without modifications or upgraded parts?
I am thinking of club racing with a 17.5 motor
hotdogs is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
SEO by vBSEO 3.5.0
