Old 08-21-2012, 03:23 AM   #1906
Pro10noob's Avatar
First yes it will.
Second, why you want that servo??
Because of the torque??
Speed is better and 5KG torque is enough.
Go for the MG1257TG, fast and strong.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 08-21-2012, 03:29 AM   #1907
i went because it was cheap.
I might grab that 1257tg
as it only runs a 6.0v will it run off the spectrum reciver with a novac gtb2 powering it?
d.k.vmatt is offline   Reply With Quote
Old 08-21-2012, 03:48 AM   #1908
Pro10noob's Avatar
Forgot to ad that if going for that servosaver, also use the alloy servohorn.
The one with the single hole.
No flex in servosaver and looks the bomb in pink
regards Roy
l===/o\===l
Old 08-21-2012, 03:56 AM   #1909
Cant find the pink one you suggest
Old 08-21-2012, 04:07 AM   #1910
Pro10noob's Avatar
Here you go.
Color is a bit darker then the car but looks fine
regards Roy
http://os.3racing.hk/products.php?products_key=4064
http://os.3racing.hk/products.php?products_key=4114
l===/o\===l
Old 08-21-2012, 05:36 AM   #1911
what one is better the 16 or 18mm set?
Old 08-21-2012, 05:53 AM   #1912
Pro10noob's Avatar
Depends on car,space and steering trow you need.
I had to dail travel back on transmitter when using the 18MM.
It also depends on what TX/RX you are using.
If you can't reduece steering travel and you got to much trow your servo will use a lot of torque and can burn out.
If you have the function to limit steering travel then it won't matter.
regards Roy
l===/o\===l
Old 08-21-2012, 06:06 AM   #1913
my dx3 will let me so the 18 should work.
Thanks for all your help
Old 08-24-2012, 09:45 AM   #1914
Hey guys. Another Sakura Zero S user here. And this is my first post here :P
But yeah.
What's the difference between the 2 types of vertical mount mods on sale in their website?
Also, does it really need that graphite upper deck to work?
Thanks guys!
issuzark is offline   Reply With Quote
Old 08-24-2012, 09:54 AM   #1915
sporadicidiocy's Avatar
But yeah.
Thanks guys!
You can dremel/grind/sand off a bit of the stock top deck to make it fit, just go slowly and test fit often.
90% Sakura Zero: Reventon S V3.0 10.5T
Sakura Ultimate: GTB2 17.5T
F104 Pro: SXX V2 Trackstar 21.5T
F103 Chevronmodels 6-wheel conversion
sporadicidiocy is offline   Reply With Quote
Old 08-24-2012, 10:01 AM   #1916
But yeah.
Thanks guys!
One mount is for the Zero (non S) and does not include the opposite aluminium piece. It should be clear from looking at the pictures and I think the 3racing declares only one mount compatible with the Zero S.
halldor is offline   Reply With Quote
Old 08-24-2012, 10:20 AM   #1917
So there is a bit of structural differences here and there between the FRP and the carbon upper deck. I know what to do now.
Another thing though. When I was using the stock 80T spur I couldn't fit in my 40T pinion.
I think it's possible if I switch the 80T to a 70?
Old 08-24-2012, 11:16 AM   #1918
I'm running 70:36 on mine in VTA, and a 40T will fit (looks like a 41 will, too). I did some grinding on the top deck to make a bigger hole around the pinion gear to make it slightly easier to change gears. I was thinking about adding 3mm spacers under the top deck to raise it up to make room for pinion gear changes. Has anyone tried this?
Kevin Marcy is offline   Reply With Quote
Old 08-25-2012, 07:12 AM   #1919
Haven't tried it and I'm not sure what handling effects it would have but you would be changing the flex characteristics of the car. I would expect the chassis to become more flexible. give it a try and be sure to let us know how it works.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 08-25-2012, 08:10 AM   #1920
Hello
I have a few Sakura zero S (not all of them are built ) and and have a few Q's
So all my cars have the basic upgrades (v motormount , aluminum spur,downstops,19t gear,5mm wheel hexs) stock topplate
So I'm going to run a few class's
Gta 21.5, stock 17.5, open mod ( not sure what motor to use, some of the guys run 13.5with boost) I don't want to run boost so I'm thinking 10.5.....(will I get left in the dust? )
All on carpet
Any way would I set up all the chassis the same?
What hop up parts should I buy first for which class?
So far all the cars are built to set up in manual with 3degree in rear
Any advice would be great
Ps I pick up 1 for my son to run stock with as well and cost would be close to 1 XRay for all of my Sakura s
hotrod306 is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
