Old 08-16-2012, 02:54 PM   #1891
nikkon's Avatar
Trader Rating: 245 (100%+)
Send a message via AIM to nikkon
Who has the best price on these at the moment? Looking to pick up one for my son and I so we can both run the same car.
Tekno d8/xerun 80a/hw 2250kv
Stampede 4x4/mmp/castle 1410
Slash 2wd lcg/mmp/x12
nikkon is offline   Reply With Quote
Old 08-16-2012, 04:16 PM   #1892
Thanks Wollow, I'll let you know how it goes
Originally Posted by wollow86 View Post
Depending on the track condition, I run about 30-40wt with 2-3 hole pistons. Try -2 rear toe, long upper links and 2mm shims under front and rear inner links (zero kit setup for RC). Shocks around middle position on front and rear towers, 5.75 front and 6.0 rear springs. This is with narrow arms. If your running stock rear arms try going down to 6.5 rear springs. 5mm front ride height and 5.5 rear. Droop 3-4mm front and 2mm rear. Camber -1.5 front -2 rear.
Tune to your driving style.
I ran that setup on the weekend and the car felt really balanced, with just a touch more turn in.
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 08-16-2012, 05:07 PM   #1893
FauxMako's Avatar
http://www.hotshothobby.com has them in stock.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 08-16-2012, 06:32 PM   #1894
HKShobby also has these kits in stock as well
http://www.hksrc.com/store/index.php...roduct_id=8274
VTA = 3Racing Sakura Zero S
Mini = Tamiya M-04
Off-Road = ECX Ruckus/Torment SCT
Home Track = Jeff's RC Studio,(Fort Myers, Florida)
NewRCSim is offline   Reply With Quote
Old 08-18-2012, 02:02 AM   #1895
http: //www .youtube.com /watch?v=m7SKs7z4yNM
Just want to share a run with my Sakura..
dspeed19 is offline   Reply With Quote
Old 08-19-2012, 05:20 PM   #1896
How well does turnigy 5000 roar battery fit this chassis
hotrod306 is offline   Reply With Quote
Old 08-19-2012, 08:58 PM   #1897
sporadicidiocy's Avatar
My NanoTech 5800 fits, so a 5000 should be no problem since it should be the same size.
90% Sakura Zero: Reventon S V3.0 10.5T
Sakura Ultimate: GTB2 17.5T
F104 Pro: SXX V2 Trackstar 21.5T
F103 Chevronmodels 6-wheel conversion
sporadicidiocy is offline   Reply With Quote
Old 08-20-2012, 01:25 AM   #1898
BCZero's Avatar
I run the turnigy 5000 roar approved hard case one, I'll assume that's the one you mean, and it's fine.
Stock: XRay T3 '12, F1: Tamiya F104v2, Buggy: Tamiya TRF201, SCT: AE SC10 4x4 FT, Radio: Airtronics MT-4
BCZero is offline   Reply With Quote
Old 08-20-2012, 06:04 AM   #1899
Iv just ordered my zero s to use in vta, And iv seen people recomending the tamiya servo savers. Will the stock one that comes with the tt-01e work?
thanks
matthew
d.k.vmatt is offline   Reply With Quote
Old 08-20-2012, 03:56 PM   #1900
The hi-torque servo saver is really good. The stock one in the kit will probably be better than the TT01e one.
Space for rent!
Old 08-20-2012, 04:50 PM   #1901
Do you have a link mate?
Also do these cars need a high torque servo or are they light enough to get away weth a les powerful one? What's recomended?
Old 08-20-2012, 08:51 PM   #1902
I would go for speed and centering ability in a servo. these cars are light enough where a standard torque servo will work great. Watch the weight of the servo. typically the zero is left side heavy. A lighter servo will make things easier to balance.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 08-20-2012, 09:24 PM   #1903
Speaking from experience, I'd say don't use the stock Sakura S servo saver.. it's crap.
Either get the Tamiya high torque or the Xray composite stiff set. The stock TT01E servo saver will work too as long as you still have the proper servo arm adapter for your brand of servo.
Old 08-21-2012, 03:59 AM   #1904
I put the sakura servo saver in my sons TT01, it's not an E or an R or a D version just the straight TT01. I wasn't a fan of the standard servo saver in the kit. lol
But the Tamiya hi torque one is the go.
Space for rent!
Old 08-21-2012, 04:12 AM   #1905
Will this suit?
http://www.ebay.com.au/itm/3Racing-H...item2ebdd09cb2
As well as.
http://www.savoxusa.com/Savox_SV0220...avsv0220mg.htm
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
SEO by vBSEO 3.5.0
