Old 08-11-2012, 07:21 PM   #1876
can some one let me know why i would up grade my Differential to sak65/v2?
hotrod306 is offline   Reply With Quote
Old 08-11-2012, 09:11 PM   #1877
wollow86's Avatar
Only difference i've noticed is the outdrives. They have a larger spacing to allow the use of blades, which should increase the life of the outdrives. Other then that I'm not sure what's different.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 08-11-2012, 10:08 PM   #1878
What shock are people running with the +4mm shock towers?
Also what gearing will give me a 4.0 FDR?
d.k.vmatt is offline   Reply With Quote
Old 08-12-2012, 06:42 AM   #1879
shadowracer24's Avatar
I run associated on mine but any other tc shock would work. What pitch are asking about, 48 or 64?
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 08-12-2012, 06:45 AM   #1880
rather 48 as i run normal car parks on weekends that arnt always clean
Old 08-12-2012, 09:01 PM   #1881
I up graded to the 19t center pulley but do i need the SAK-06 Spur Gear Shaft Set
I dont have it but went ahead used pulley any way, will i run in to problems?
Old 08-12-2012, 11:18 PM   #1882
Trader Rating: 6 (88%+)
Ok so I want to get one of these, are there any upgrades that are really necessary?
The website reviews say:
Tamiya (#84049) TB-03 Lightweight Urethane Bumper
3Racing (#KIT-SAKURA-S) SAKURA ZERO S 1/10 Touring Car
3Racing (#SAK-09) Solid Axle Outer Joint For 3racing Sakura Zero
3Racing (#3RAC-WX124/PK) Wheel Adaptor (4mm) for Sakura Zero - Thick
3Racing (#SAK-S16/WO) Graphite Upper Deck For SAKURA ZERO S
3Racing (#SAK-66/V2/PK) Vertical Motor Mount - Ver. 2 For 3racing Sakura Zero
3Racing (#SAK-48/PK) 50mm Aluminium Oil Damper Set For 3racing Sakura Zero
Is there anything else I might need?
Ironwolf1974 is offline   Reply With Quote
Old 08-13-2012, 08:22 PM   #1883
[QUOTE=Ironwolf1974;11086785]Ok so I want to get one of these, are there any upgrades that are really necessary?
look at post 258
Old 08-13-2012, 08:30 PM   #1884
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 08-13-2012, 09:03 PM   #1885
Trader Rating: 49 (100%+)
Anyone have an extra gear adapter? SAK-u05? Need that, but don't have time to order from China. Send me a PM if you do.
Thanks.
~B
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 08-13-2012, 09:13 PM   #1886
HKS hobbies seems to have that part in stock.
http://www.hksrc.com/store/index.php...roduct_id=8419
VTA = 3Racing Sakura Zero S
Mini = Tamiya M-04
Off-Road = ECX Ruckus/Torment SCT
Home Track = Jeff's RC Studio,(Fort Myers, Florida)
NewRCSim is offline   Reply With Quote
Old 08-13-2012, 09:49 PM   #1887
thanks! Never really looked at them before.
My problem is, I wanted to get it relatively quick..... everything I've ever seen about their sending things out is that they are slow...... was trying to have it this weekend.... with them taking a few days to ship, from most things I've read, it won't help me out
I will keep them in mind though just in case
SpeedMerchant Rev7
Old 08-14-2012, 04:36 PM   #1888
FauxMako's Avatar
Hot Shot Hobby.
http://hotshothobby.com/searchquick-...ywords=sak-u05
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 08-16-2012, 02:54 AM   #1889
anyone got a good baseline setup for a Zero S running in VTA. FDR for the track we have been advised will be around 3.5 ish and it is an outdoor tarmac track. Looking for some guidance on shock oils, camber, droop, toe, etc...
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 08-16-2012, 04:54 AM   #1890
wollow86's Avatar
Depending on the track condition, I run about 30-40wt with 2-3 hole pistons. Try -2 rear toe, long upper links and 2mm shims under front and rear inner links (zero kit setup for RC). Shocks around middle position on front and rear towers, 5.75 front and 6.0 rear springs. This is with narrow arms. If your running stock rear arms try going down to 6.5 rear springs. 5mm front ride height and 5.5 rear. Droop 3-4mm front and 2mm rear. Camber -1.5 front -2 rear.
Tune to your driving style.
I ran that setup on the weekend and the car felt really balanced, with just a touch more turn in.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
