Old 08-03-2012, 06:54 PM   #1861
ZERTA RACING's Avatar
Trader Rating: 36 (100%+)
Originally Posted by over gear View Post
FDR is the Final Drive Ratio. FDR = Spur/pinion x internal ratio. sakura internal ratio is 1.90.
from my experience, i run 3.5 to 4.0 for 17.5 . check the motor temp after each run... i try to keep it between 160-170F ...
as for the pinion, what's the cloest one to 38t you have in your pit box? 38t might be too big. Build the car first and see how much room u have. I think you might need a smaller spur.
LOL found the answer to my question i believe but i read the 19t pulley makes the internal ratio 2.0 correct?
TEKNO RC
Customer Service Representative
Web: www.teknorc.com
Contact: info@teknorc.com
Tel: (858) 997-0833
ZERTA RACING is offline   Reply With Quote
Old 08-03-2012, 06:55 PM   #1862
Originally Posted by SteveM View Post
When I ran 17.5 BL in the blinky class I used 64P gears with an FDR of 4.10
were you running any fans? do you remember the teeth on the gears you used?
TEKNO RC
Tel: (858) 997-0833
Old 08-03-2012, 06:56 PM   #1863
joelwhite's Avatar
Trader Rating: 55 (100%+)
yes 19t pully and 38 would make it 2.0.
HEART OF A HUSTLER RACING TEAM
Trick Graphics--see spdrac430 on this forum for all your painting needs
Team Pit Racers-Fastest Guys In The Pits!
joelwhite is offline   Reply With Quote
Old 08-03-2012, 07:30 PM   #1864
SteveM's Avatar
Trader Rating: 126 (100%+)
I did not use a fan and I ran a 90T spur and 42T pinion with the 19T center pulleys for a FDR of 4.286.
SteveM is online now   Reply With Quote
Old 08-03-2012, 08:35 PM   #1865
Thank you. will yeah racing spurs fit?
Do you think 76 spur with 42 pinion @ 3.619 would be to low of a FDR. I am running 3.5 in my yokomo and the motor does not get above 150 after a 10 min main.
TEKNO RC
Tel: (858) 997-0833
Old 08-04-2012, 01:43 AM   #1866
Originally Posted by aquito View Post
Hey guys I have a stock Sakura S. it was built according to the manual specifications. I took it for a spin and it's awesome but the rear is really slippery I'm practically drifting the car with street tires..any suggestions on how I can fix that?
When is it loose? On power or off power? Corner entry or apex or exit? What is your toe, camber, ride height? What motor are you running? FDR? Track conditions?
Without more info I can only guess your car is doing what mine did when new. Go with a stiffer spring up front and a softer in the rear. Try a 5.0 in the front and a 6.0 in the rear. Adjust the droop to 2mm front and 2mm rear. This will give you a decent starting point and will hopefully start to get that drift under control.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 08-04-2012, 02:16 AM   #1867
wollow86's Avatar
Also be sure to check your camber and front toe with a gauge. IIRC, the manual is way off with the lengths it asks you to build the links.
As vette said, go 6.0 or even 6.5 depending on your grip level and driving style. If you dont have 3Racing springs available, try tamiya blue or yellow springs for a mini (if you have them...)
Narrowing the rear with the XI arms, or narrow blocks (XI arms are cheaper..) will also help, but check those other things first.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 08-04-2012, 06:01 AM   #1868
SteveM's Avatar
I have only ever run a 17.5 BL motor in my Zero. Try matching the FDR you're running in the Yokomo on the Zero and check for temps. Adjust from there.
Old 08-04-2012, 04:06 PM   #1869
hello im thinking on using this car in open mod (good or bad ideal?)
but not sure on what motor to run (first time club is going open mod)
im thinking 8.5 but not sure on gearing ...what would you guys use?
urban is offline   Reply With Quote
Old 08-07-2012, 10:20 AM   #1870
spring71's Avatar
Smile
New 3racing SSK Driveshaft came out.
http://www.tqrcracing.com/shop/produ....asp?p_id=4351
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 08-09-2012, 12:40 AM   #1871
wollow86's Avatar
New motor mount root for the XI, give's some more room for the pinions, has mounting holes in accessible places even with a very small spur. Its similar to the modified kit motor mount option for the S. Just like any XI motor mount, you will need to move the motor mount root hole forward 3mm to fit onto a zero/s chassis.
This is on my DH, but I do have a 2nd one on the way I will fit to my hybrid.
Old 08-09-2012, 05:06 AM   #1872
sir Wollow86
nice XI you have there. By the way if you have your S hybrid with the XI new motor mount please post pictures so that we would have an idea how to convert it.
I also want that new motor mount because of the spur mount that has a button screw for the top deck.
Thank you!
kikoy is offline   Reply With Quote
Old 08-09-2012, 07:21 AM   #1873
wollow86's Avatar
Originally Posted by kikoy View Post
sir Wollow86
Thank you!
I currently have the original XI lower chassis on my hybrid, with the zero vertical motor mount. The only difference there is I needed to move the hole for the root arm rearward by 3mm. The opposite would be needed to run the XI motor mount (either of them) on the zero/zero s chassis. I'll snap a photo of my very shonky (almost destroyed it) job of moving the hole when I get the other new motor mount for the hybrid. Should be next week some time.
Old 08-09-2012, 11:39 PM   #1874
Okay thanks! I wanted to use the original motor mount of the zero but it has no screw on top of the spur carrier for the top deck. I also dont like to use the vertical motor mount for the S because of the swapping position of the belt to the other side. i also want to have a low center of gravity. Im planning to run my S in the 13.5 class.
Old 08-10-2012, 02:18 AM   #1875
wollow86's Avatar
I don't run the scews in the top deck at that position, my deck doesn't even have the holes for it. I assumed that was an XI thing (which I do run the screws on)? Because I'm using the zero bulk heads, I need to use the zero top deck (soft).
I wouldn't think the CG would be effected to much by the motor mount, seeing as the motor is still up there anyway...
But in any case there is a lot more room with the new mount. I got my pinions today, easily fit a 47 with the 60. There's a little room to spare, 50-51 should be no problem if you wanted to. I have found though that fitting anything larger then about 43 starts to get tricky, you would need to remove the top deck, and trial and error you way through motor position.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
