Old 07-12-2012, 01:05 PM   #1786
I think I overdid the pink joking with my girlfriend and learning control of an airbrush. Maybe I should put a Kotex logo on the front doors.
cannon fodder is offline   Reply With Quote
Old 07-13-2012, 03:12 AM   #1787
Here's my solution to a transponder mount. Haven't tried it yet but quietly confident.
Cars: Sakura Zero S, Tamiya M05 Pro, Associated B4, HPI Firestorm Flux
davlind is offline   Reply With Quote
Old 07-13-2012, 01:34 PM   #1788
buckeye dan's Avatar
Default finally gonna race my new zero
finally get to race my zero tomomrow at toledo with team mopar . will be nice racing indoors instead of in heat. ok so right now seems alot of parts are out of stock on zero is this a problem i have to worry about?
buckeye dan is offline   Reply With Quote
Old 07-13-2012, 08:53 PM   #1789
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Are the suspension blocks interchangeable with Tamiya trf series or the serpent
s411.
How are the dampers?
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 07-13-2012, 09:48 PM   #1790
Probably not. The xi dh is a new release and the f113 is in the works so 3racing is probably pretty busy right now. Same thing happened when the xi was a new release. The s parts seem to go in cycles. I remember when the bulkheads and covers couldn't be found a few months ago. I think there is just such a demand for the parts that 3racing gets behind sometimes.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 07-14-2012, 09:07 PM   #1791
team mopar's Avatar
To the guys running at 21.5's in 64 pitch. What gear combo is working for you?
The car has the 19t center sprocket to loosen the belts so the puts me at 2.0
Im running a 90 spur and a 49 pinion came off track at 220! Knocked pinion down
to 45 and came off at 200!! With a heatsink only no fan.Must tell you this is a used motor a internet purchase. Zero is in vta class this what they're running at this one track i go to. I know it should be a 25.5 class.
What you do ya think? P.o.s Ballistic ? Or total gear change
team mopar is offline   Reply With Quote
Old 07-14-2012, 09:29 PM   #1792
I run 88 spur with a 46 pinion. Not too far off of your gear. I come off at 140 with a twin fan. 168 when the fan comes unplugged.
Check for binding in the drive train. If all is loose try to figure out if you have any tire slip. Even a very small amount of breaking traction can heat up a motor. I dropped 30 degrees by eliminating a very small amount of slip.
Serpent S120 13.5
Old 07-15-2012, 06:58 AM   #1793
team mopar's Avatar
Ok i know i had tire slip, rear end was all over the place and had a push in the front.' new tires' .
Baffled me because I'm running the same fd numbers on a car with a 25.5 but that has older softer tires makes sense thank you 6376vette!
Old 07-15-2012, 08:24 PM   #1794
xrayroooahhhh's Avatar
Default Mod Touring
I read many posts in this thread.....just do not seem to find to much info or feedback from guys trying the S platform in Pro-mod??
I see Steve M's must have list of upgrades but putting a 3.5 or 4.5 indoor carpet....anything else become MUST HAVE?
Thanks for all the posts and information on this thread and any advice
R
-ROOH RACING-
www.donerite.net
xrayroooahhhh is offline   Reply With Quote
Old 07-15-2012, 08:33 PM   #1795
Stu NZ's Avatar
Angry
Mate...you are doing well to get 220 out of a Ballistic, I seemed to be able to melt the POS just by facing them towards the sun,, go to a different flavour and your life will become much more pleasant,,,,worked for me and will never go near that brand again...
Stu NZ is offline   Reply With Quote
Old 07-15-2012, 09:46 PM   #1796
I never had trouble out of the ballistic. 21.5 or 25.5. I have heard stories about them though. My ballistic 21.5 seems to have the same power as my revtech 21.5 but my reedy sonic seems to have just a touch more than either of them. I guess its all on the particular motor. The only one that has failed me has been 2 speed passion 17.5 motors. I won't use another one.
Serpent S120 13.5
Old 07-16-2012, 10:10 AM   #1797
FauxMako's Avatar
In USGT I'm running 48/96 64p with an Epic 21.5 with only a heat sink (no fan) and coming off in the 120/130 range.
In VTA I'm running 49/93 64p with a Ballastic 25.5 with only a heat sink (no fan) and coming off in the 130/140 range.
You've got to have something binding somewhere to be generating all that heat.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 07-16-2012, 12:32 PM   #1798
Madulla's Avatar
I run a 21.5 ballistic in VTA with a FDR of 4.2 It comes off at 160. If I turn up the timing 1 notch higher if comes off at 180+. The ballistic is very sensitive with timing, plus you are geared way higher than I am. With a 21.5 Duo3 I was running the same gearing with the timing maxed and coming off at 140. Also if you got the temp 220F on the can, it was even hotter inside. After that it does not matter what you do it will be hot. You had a FDR at 3.6 pretty sure it cooked.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 07-16-2012, 02:39 PM   #1799
team mopar's Avatar
I got more to the story out of the shipping box the 21.5 ballistic's timing was cranked to 45! Of coarse i backed it down how ever this is never a good sign when buying used novak equipment. Tried to save a buck and took it in the "blank". With all your suggestions i will totally regear and make the call on the motor after that. I do agree its cooked. Back to the 25.5 and get it ready for Nashville. Thanks guys! Sam.
Old 07-18-2012, 11:41 AM   #1800
I just finished reading the who thread and there is some great information on this car. I'm looking at getting one but my wife is not wanting me to spend more than $100 and I still have to get electronics. We will see what happens.
Wish you well with your setups.
othercents is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
