Old 07-04-2012, 09:17 PM   #1726
I changed to the vertical motor mount and as a result had to switch the belts side to side and diffs. However now I cannot use the battery holders on the inside or the belt touches them.
How is everyone else handling this?
mt_100 is offline   Reply With Quote
Old 07-04-2012, 09:40 PM   #1727
When you install the 19t pulley and a different spur gear, do you need the part SAK-06 or is it ok as it is. I've just received the other parts I ordered to do the build but I didn't get that bit.
davlind is offline   Reply With Quote
Old 07-05-2012, 12:48 AM   #1728
mingnon's Avatar
battery tape works fine
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 07-05-2012, 01:12 AM   #1729
Originally Posted by SteveM View Post
Based on my experience so far, here is a basic list.
  • SAK-S17/PK Vertical mount
  • SAK-05 Aluminium Gear Adapter
  • SAK-07A Center Pulley Set 19T
  • SAK-06 Spur Gear Shaft Set (or use Tamiya shims with the stock item)
  • SAK-58PK Belt tensioner (optional)
  • SAK-14 - chassis down stop protection plate
  • SAK-S16/WO Graphite Upper Deck (or modify the stock one)
  • AE 40 wt shock oil (all 4 shocks)
  • Tamiya Heavy Duty Servo Saver
If you want a front spool, you need to purchase three separate items to assemble one.
  • SAK-02 - 38T white pulley
  • SAK-09 - Solid Axle Outer Joint (2)
  • SAK-08/PK - Front Solid Axle
B4 FT +8mm
SC10 4x4
jimmer411 is offline   Reply With Quote
Old 07-05-2012, 04:21 AM   #1730
SteveM's Avatar
Trader Rating: 126 (100%+)
You have to do some grinding with a Dremel tool. Go back through this thread and look for my posts with pictures to show what I did.
SteveM is offline   Reply With Quote
Old 07-05-2012, 04:23 AM   #1731
SteveM's Avatar
The SAK-06 only gives you a pair of thicker pick spacers and I didn't buy this part. I used a few Tamiya shims to adjust the play at the spur and it worked fine.
Old 07-05-2012, 04:32 AM   #1732
Thanks SteveM
Old 07-05-2012, 04:46 AM   #1733
You can also use the extra spacers you got left from the gear diff. These are the perfect size
Thomaseh is offline   Reply With Quote
Old 07-05-2012, 07:37 AM   #1734
orcadigital's Avatar
Trader Rating: 61 (100%+)
Most seem to go to battery tape. You can still use the outer L brackets, but you need to come up with something to keep the battery from rubbing on the belt. I was running VTA (and thus had to add weight) and the center weight kit has horizontal threaded holes to run a bolt through that allows you to keep the battery pushed out. You can also dremel the existing mounts, or fabricate something else to go on the inside.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 07-05-2012, 08:13 AM   #1735
SteveM's Avatar
The outer battery tray guides don't need to be touched. The inners will need some alterations but nothing too difficult. I used a plastic servo mount with a bolt to maintain the battery position. See my pics.
Old 07-05-2012, 10:08 AM   #1736
FauxMako's Avatar
The "foot" from the old motor mount also can be used to keep the battery away from the belt.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 07-05-2012, 11:31 AM   #1737
stablizer AND stablizer mount!
nicholasxuu is offline   Reply With Quote
Old 07-05-2012, 12:27 PM   #1738
SteveM's Avatar
I tried the sway bars and didn't like the way the car reacted and took them off. Not needed in my opinion.
Old 07-05-2012, 04:04 PM   #1739
I agree with you a lot but I have to disagree here. They are a more advanced tuning tool so I highly recommend to learn the rest of the car first but they are necessary to push the car to its full potential. If I didn't use them I wouldn't be on the podium. Learn the car and grow the driving skill then add them to maximize your tuning options. If you don't know the car then you will never know how to use them or feel the changes they make but they work extremely well.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 07-05-2012, 04:26 PM   #1740
SteveM's Avatar
My advice WRT the Sakura is based entirely on the 17.5 blinky class. I have not yet run my sedan in any other class. The sway bars might prove a useful tuning aid for the open mod class but for now I'm fine without them.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
