Old 07-02-2012, 02:33 PM   #1711
So, a quick question seeing that my next race is at Hvervenbukta in Oslo. I normally run 3* toe-in in the back, but Hvervenbukta is a 1/8 track with a huuuuuuuge sweeper before a looooooooong straight. Do I gain more speed going with 2* toe-in in the back? What is the difference in speed vs. corner speed
Thomaseh is offline   Reply With Quote
Old 07-02-2012, 02:52 PM   #1712
mingnon's Avatar
explains it all
http://www.competitionx.com/rc-racin...oe-in-toe-out/
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 07-02-2012, 04:31 PM   #1713
When I ordered my car, the vertical motor mount was not in stock. So here's my alternative (inspired by the TC6).
Kevin Marcy is offline   Reply With Quote
Old 07-02-2012, 06:38 PM   #1714
Stanfsu's Avatar
Trader Rating: 294 (100%+)
Send a message via Yahoo to Stanfsu
I would love to upgrade the plastic Knuckle Arms with alum but it appears that 3racing does not sell this upgrade. Any suggestions? What will fit? Has anyone done this upgrade?
Losi | Futaba
Low Ballers will be ignored!
Stanfsu is offline   Reply With Quote
Old 07-02-2012, 07:04 PM   #1715
FauxMako's Avatar
Alum there would bend where plastic will break. Bent parts aren't any good. The plastic parts are also going to be much cheaper than alum so replacing a broken plastic part is still better than replacing a bent alum part.
If you are breaking steering knuckles, c-hubs or front arms, get the X-ray hard bumper. It's a drop in upgrade and will protect the front end much better than the stock bumper. It's a little thicker than the 3racing bumper, a couple of 3-4mm spacers on top of the bumper posts fill in the gap between the posts and the top plate. The 3Racing TT01/TB03 CF bumper plate fits the Sakura Zero as well.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 07-02-2012, 08:48 PM   #1716
+1 stay away from aluminium knuckles and c hubs. Tamiya parts can be made to work but it definitely isn't worth it. You need flex and a breaking point. Not a soft bending point. Remember that although these are toys they are precision toys. As Mike said bent parts are no good and they can not be reliably straightened.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 07-03-2012, 04:53 AM   #1717
Stanfsu's Avatar
Okay I will stay with the plastic
Losi | Futaba
Old 07-03-2012, 11:57 AM   #1718
FauxMako's Avatar
Ooooh:
http://os.3racing.hk/articles.php?articles_key=143
Mike
Mini M03 & M05
Old 07-03-2012, 02:36 PM   #1719
mingnon's Avatar
yes, they work great and are cheaper than other options, waiting to see what "wears out" on them
Old 07-03-2012, 06:49 PM   #1720
Trader Rating: 49 (100%+)
Okay, finished my build, and overall for the money, I am impressed. One problem I am having though is a binding in the drivetrain after everything is installed. The belts are not overly tight, not quite loose either, but wouldn't cause this amount of tightness. It seems to be coming from the spur adapter. I used the plastic spur adapter, and put in a 64 pitch spur. I can't remember what brand spur it is, but could it be too thick? I vaguely remember seeing something like this, but I can't find it..... any idea?
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 07-04-2012, 05:00 AM   #1721
Originally Posted by mingnon View Post
Thanks, is there a huge speed difference?
Old 07-04-2012, 04:10 PM   #1722
mingnon's Avatar
i prefer about 1deg toe in on rear and 1 on the front, just makes the car feel a bit more stable when in VTA setup (im not that flash a driver), tried 0 all round and didnt like it.
Old 07-04-2012, 04:57 PM   #1723
Has anyone compiled a full list of recommended upgrades with part numbers? Im thinking about ordering one pretty soon.
Associated B4 FT +8mm
Associated SC10 4x4
Associated B64D
Losi XXX-SCT
jimmer411 is offline   Reply With Quote
Old 07-04-2012, 06:42 PM   #1724
mingnon's Avatar
go back one page and have a look at Steve M's post
Old 07-04-2012, 07:24 PM   #1725
SteveM's Avatar
Trader Rating: 139 (100%+)
Based on my experience so far, here is a basic list.
  • SAK-S17/PK Vertical mount
  • SAK-05 Aluminium Gear Adapter
  • SAK-07A Center Pulley Set 19T
  • SAK-06 Spur Gear Shaft Set (or use Tamiya shims with the stock item)
  • SAK-58PK Belt tensioner (optional)
  • SAK-14 - chassis down stop protection plate
  • SAK-S16/WO Graphite Upper Deck (or modify the stock one)
  • AE 40 wt shock oil (all 4 shocks)
  • Tamiya Heavy Duty Servo Saver
If you want a front spool, you need to purchase three separate items to assemble one.
  • SAK-02 - 38T white pulley
  • SAK-09 - Solid Axle Outer Joint (2)
  • SAK-08/PK - Front Solid Axle
SteveM is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
