3Racing Sakura Zero S
#1666
Need info. I have a Sakura zero I run 17.5 TC and a Sakura Zero S I run VTA. I want to change the center pullies to the 20 or 21, but the belts won't allow for enough adjustment. If I use a rear belt from a Tamiya 416 I can adjust. Any info for the front belt? Thanks
#1667
The bearing holders on the diffs are egg shaped so you can loosen the belts a little by rotating them to another position however moving diffs towards the front or rear can alter the cars handling
#1668
#1669
Alot of people in my area are selling or have already sold thier Xray cars
to get one of these. They said these Sakura cars flex more and that gives
ya an edge in 17.5 Vintage Trans Am. Obvisously the Xray cars are really
stiff compared to other chassis. At least that's what I was thinking when they told me this. So most are going to this Sakura chassis.
I run a 3 Racing chassis on my TA05.
Never had a problem with the 3 Racing upgrades.
#1670
The car was great at the Norwegian Nationals round 3: http://www.redrc.net/2012/06/fjeldva...rd3-in-norway/
Didnt do any major setupchanges with my Sakura Zero, neither did Espen who won with his out of the box Sakura Zero S! Only thing that was changed was the shocks!
#1671
Sir what shocks did mr. espen fjeldvar and You used during the race?
By the way Congratulations for the podiumm and the fastest time.
#1672
Thank you very much!
#1675
Not enough pictures here!
Front body post location, very similar to TA06 (hence, was able to reuse one of my bodies)
Tamiya short springs will fit.
Used the TC6 lipo retainer, and modified two of the stock retainers (flipped around) to move the lipo out for balance.
Anyway....not bad for a $100.00 car....as I had the electronics laying around.
#1676
Steering Problems
Steering Help -
So I installed a new servo (Savox 1258) onto my Sakura S Zero. I have made the adjustments to the steering endpoints. The problem is that at times when I turn right the car does not turn and goes straight into the wall I still have the stock servo saver could that be the problem?
#1677
Steering Help -
#1678
Steering Help -
I'm sorry I didn't realize you were fighting the car that much. Please whenever you have a issue with the car come on over and ask. We can get you on a set up board and balance and tune the chassis as well as making a lot of adjustments to get it handling right. I probably won't be there this Saturday and they are closed next Wednesday night but I'm planning on being there the Saturday after that. A lot of guys there are or have run the sakura. If I'm not there ask grant. Chris can guide you in a direction but his experience is with x ray. still a great person to ask for set up tips.
keep posting in the forums and pm me if you like. I will be more than happy to help you get this chassis hooked up.
Just in case you don't remember me I have the yellow usgt corvette and the red Ferrari f1.
#1679
Trader Rating: 120 (100%+)
I've had problems, with the Savox servo's too. They draw a lot of power, and some receivers can't handle it. Try a different receiver, or add a receiver battery pack. Futaba's are no problem, but some Spektrums don't like Savox.
#1680
Spectrum and Savox(the TC servo's 1257,1258) are a no no.
The reciever can't handle the current draw of the savox servo.
With Futaba reciever it isn't a problem as with the Team Orion servo's
I have several savox servo's and use them with a Futaba radio without problems.
ESC i use are Tekin and Hobbywing 120amp V2.1.
Did use a spectrum with the Savox and problems with the servo's taking to much current and shutting the steering down.
regards Roy
regards Roy
