Old 06-10-2012, 08:02 AM   #1651
Trader Rating: 58 (100%+)
Originally Posted by Stanfsu View Post
Hey All,
Currently I run with a Sakura Zero with a cheap servo. I was thinking about upgrading my servo with a Savox SC-1251MG low profile digital that retails for about $63. Thoughts on this servo?
Buy
MC112b is offline   Reply With Quote
Old 06-10-2012, 08:30 AM   #1652
R/C Tech Charter Subscriber
Trader Rating: 30 (100%+)
Hey All,
Spend the extra 5 bucks and buy a 1258 so that in the future, you'll have a servo that useful in something other than a on-road application....my two cents
Lowrance is offline   Reply With Quote
Old 06-10-2012, 05:26 PM   #1653
wollow86's Avatar
Hey All,
I love mine. I have one in my.XI DH and one in my FGX. I also have a 1257 in my Zero hybrid. Depending on your layout, the space savings are nice and they weigh less as well. In terms of on road the 1251 is the better investment because you can use them in basically anything.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 06-10-2012, 06:25 PM   #1654
Stanfsu's Avatar
Trader Rating: 294 (100%+)
Send a message via Yahoo to Stanfsu
That is what I will do Yea!!!
Losi | Futaba
Low Ballers will be ignored!
Stanfsu is offline   Reply With Quote
Old 06-11-2012, 05:11 AM   #1655
buckeye dan's Avatar
Default will be racing a zero this fall
i was wondering what kind of spare parts i should have on hand since hobby store will prolly not have any for my zero. i would appreciate any input as far most likley to break parts thanks.
buckeye dan is offline   Reply With Quote
Old 06-11-2012, 07:45 AM   #1656
ta04evah's Avatar
+1 Great price and good performance, it's faster than my slowing reactions.
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 06-11-2012, 03:12 PM   #1657
Front and rear arms. Front and rear hubs and front steering knuckles. If you hit a lot of walls then front suspension mounts. If you are pretty clean you could pass on those until you are ready to upgrade to the aluminium mounts.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 06-11-2012, 03:20 PM   #1658
Default thanks for selling to me
thanks
Old 06-11-2012, 03:43 PM   #1659
Default i had tc5
I had a tc5 doing same thing ate at least 5 spurs then i noticed that the motor would move . this would make the pinion move and ruin spur. upon further checking there was a screw missing that held motor mount to rear bulk head . once this was replaced that took care of spur problems so i suggest checking that there is no movement or missing screws.
Check the layshaft screws to see if they are loose or missing. Also check the layshaft bearings for wear.
Old 06-11-2012, 08:11 PM   #1660
Trader Rating: 49 (100%+)
okay, so with the vertical motor mount, do I need anything additional or need to make any modifications? Is there any reason not to get the XI turnbuckles instead of the regular Zero S titaniums? Going to be ordering my car within a day or two.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 06-11-2012, 10:28 PM   #1661
I am currently finishing up my Zero S build. I ordered the regular titanium turnbuckles,(didn't like how small the middle part was for the wrench they provide) and they seem to be the same part number as for the XI (3RAC-TR335 for the 35mm, and 3RAC-TR340 for the 40mm ones). The complete set also look the same. They seem good so far, except for the wierd placement of where you use your turnbuckle wrench, (it is set more to one side than in the middle).
VTA = 3Racing Sakura Zero S
Mini = Tamiya M-04
Off-Road = ECX Ruckus/Torment SCT
Home Track = Jeff's RC Studio,(Fort Myers, Florida)
NewRCSim is offline   Reply With Quote
Old 06-12-2012, 01:26 AM   #1662
wollow86's Avatar
I find that placement a good thing. It means its easier to make larger adjustments because your not hitting stuff mounted close in with the turnbuckle wrench.
Old 06-12-2012, 10:34 AM   #1663
FauxMako's Avatar
Plus it makes it easier to remember which way is tighter and which way is looser.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 06-12-2012, 04:36 PM   #1664
Not quite, the screw for the motor mounts root arm is out by a few mm. It's 3mm further rearward for an XI mount on zero chassis. I have a zero mount on an XI chassis, just drill and countersink a hole.
Just wanted to say thanks for your help willow86. My car is just about ready to run. Just need to solder the deans plug or whichever plug i think should work well and I'm ready to go!
Turnigy RWD SCT with 3000kv Hobbywing combo
Tamiya Nitrage 1/8 5.2cc Nitro Truggy
3Racing Sakura Zero 21.5T TC
3Racing Sakura Ultimate 13.5T TC
pmac is offline   Reply With Quote
Old 06-13-2012, 02:16 AM   #1665
wollow86's Avatar
No problems, happy I could help. Personally I either use deans or direct bullets.
I got a chance to test my my hybrid last weekend. It worked pretty well! Handles just like my XI used to, I applied the same setup as I normally would and it was great. Only difference being 2* rear toe instead of 3* that I run for boosted 17.5
Here's a pic of the final product. XI lower chassis, shock towers, battery stops and dampers. Zero bulkheads, alloy steering, alloy suspension mounts (narrow rear), motor mount, turnbuckles, cvd's. zero s plastics, diffs, and one lonely laysaft mount.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
