Old 12-13-2010, 12:09 AM   #151
OverGeared's Avatar
Originally Posted by monkee View Post
I see how those m3x10's could be an issue in the center because the bulkhead isn't deep enough
Seems like the rear of that set could accept a m3x10 but I'll use an 8 like it suggests
**edit
Lol the new pic shows 10 in the rears!
:P
After the build, you will find that the front belt is in for a too much tension. I just adjusted the bearing blocks to give the belt a little tension at least while breaking-in the car. After some initial runs, the belt will loosen-up, re-adjust the bearing blocks back by 1 notch at a time till the stock setup...
OverGeared is offline   Reply With Quote
Old 12-13-2010, 12:16 AM   #152
monkee's Avatar
Trader Rating: 15 (100%+)
what is this picture referring to?
i cant read the writing :P
3Racing Sakura Zero S-56422_142242445825235_138119022904244_200426_7873440_o.jpg
monkee is offline   Reply With Quote
Old 12-13-2010, 12:22 AM   #153
old-man's Avatar
I can't read Chinese(though I am Chinese ) but I think they are saying that you need to take of some material away from the arrowed areas to prevent touching of the pulley and the belt.
old-man is offline   Reply With Quote
Old 12-13-2010, 01:02 AM   #154
monkee's Avatar
ok. that makes sense.. i see the points where it may touch the chassis
Old 12-13-2010, 01:38 AM   #155
ahpeq_ong's Avatar
what else should i buy if i buying zero s...?
shock...?
lipo chassis..?
bulkhead...?
suspension mount..?
motor mount..?
ahpeq_ong is offline   Reply With Quote
Old 12-13-2010, 02:46 AM   #156
old-man's Avatar
shock...?
lipo chassis..?
bulkhead...?
suspension mount..?
motor mount..?
If you are going down the road to upgrade the parts with alloy parts might as well go for the Sakura not the S.
However if you want to get spares and kit I suggest you get in touch with the local distributor in Malaysia.
Old 12-13-2010, 03:01 AM   #157
why?
I don't see any obligatory
cheapskate.brok is offline   Reply With Quote
Old 12-13-2010, 04:03 AM   #158
OverGeared's Avatar
shock...?
lipo chassis..?
bulkhead...?
suspension mount..?
motor mount..?
The box stock Sakura S will be just right for a beginner. However, since I am assuming that it will be driven by a "beginner" - expect some broken parts to come up as the driver tries the feel of driving it around the track (most pros will eventually break some parts in their top notch car also). Upgrading is just an option for the driver - if he considered it as "option".
Now, regarding the issue of buying a full Sakura Zero as against the Sakura "S" with an upgrade, I guess (for me) upgrading the "S" is most economical.
Since you are in Asia, part availability will be a breeze. Some of the items may be out of stock, but they eventually re-stock them with no hassles.
Here you go Dude...
Aluminum Bulkheads, Steering and Suspension Mounts (Front and Rear) at total of US$77.16:
(3R-SAK-34/PK) 3Racing Front Bulkhead Cover
(3R-SAK-31/PK) 3Racing Front Bulkhead
(3R-SAK-37/PK) 3Racing Rear Bulkhead Cover
(3R-SAK-32/PK) 3Racing Rear Bulkhead
(3R-SAK-15/PK) 3Racing Suspension Mount FF-0
(3R-SAK-17/PK) 3Racing Suspension Mount FR-0
(3R-SAK-18/PK) 3Racing Suspension Mount RF-0
(3R-SAK-23/PK) 3Racing Suspension Mount RR+30 (RR3 Degree)
(3R-SAK-10/PK) 3Racing Steering System Aluminum
Additional Spares (Front and Rear) at total of US$31.41
(3R-SAK-41) 3Racing Upright
(3R-SAK-26M) 3Racing Rear Suspension Arm
(3R-SAK-43) 3Racing Front C Hub 4 degree
(3R-SAK-25M) 3Racing Front Suspension Arm
(3R-SAK-44) 3Racing Knuckle Arms
(3R-SAK-42) 3Racing King Pin Post
Optional Upgrades at total of US$76.90
(3R-SAK-48/PK) 3Racing Aluminum Oil Damper Set
(3R-SAK-13B/WO) 3Racing Graphite Main Chassis 2.25mm (Narrow)
(3R-SAK-40E) 3Racing Universal Shaft 44mm Steel
Summing it all up:
Sakura Zero "S" kit @ US $102.00 plus the total of the above mentioned list, your upgraded car will be US $287.47 and still end up with a few plastic spares as well.
You can even buy the spares for the front and rear gear differentials and still end up lower than the street price of the full Sakura Zero.
Old 12-13-2010, 04:14 AM   #159
old-man's Avatar
Originally Posted by cheapskate.brok View Post
why?
Not an obligation, but a suggestion. Better for beginner to have technical support especially setting up the car.
Old 12-13-2010, 04:18 AM   #160
ahpeq_ong's Avatar
Here you go Dude...
Summing it all up:
total will be cheaper than sakura zero...
Old 12-13-2010, 04:20 AM   #161
OverGeared's Avatar
Yup... plus a handful of important spares. Oh, not to mention the stock chassis...
Check your RC Tech inbox, I sent you a message.
Old 12-13-2010, 04:21 AM   #162
ahpeq_ong's Avatar
got it...
thank you..
Old 12-13-2010, 01:58 PM   #163
Hey so are the zero adjustable shocks ok? Has anyone had any leaking problems?
Ive ordered a Zero S and the Aluminum zero shocks as well and my mate tells me the shocks are rubbish.
Eat more possum!
Lees52 is offline   Reply With Quote
Old 12-13-2010, 02:33 PM   #164
Pro10noob's Avatar
The shock itself ain't rubbish only the shaft guide is a bit loose.
I put Photon guides in there and a very little spacer in it so that the o-ring is abit tighter fit.
It still is smooth but i got a lot less play on the shaft now.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-13-2010, 04:03 PM   #165
i run triple or double orings, super smooth and absolutely airtight!
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
