Old 06-03-2012, 06:24 PM   #1621
FauxMako's Avatar
Originally Posted by hotrod306 View Post
where can you buy this car? (besides hk) any place in canada? usa?
I'd check:
http://tqrcracing.com/
http://hotshothobby.com/
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 06-03-2012, 06:50 PM   #1622
R/C Tech Charter Subscriber
Trader Rating: 30 (100%+)
While searching for a replacement chassis, I've found that Integy has the car and parts. Their selling the un-assembled kit for 89.99....shipping looks like 15 bucks. http://www.integy.com/st_main.html?p...prices=&page=1
They have my chassis too...10 bucks!
Lowrance is offline   Reply With Quote
Old 06-04-2012, 05:14 AM   #1623
wollow86's Avatar
Originally Posted by pmac View Post
Hi sakura s drivers,
I have recently made the purchase of a shiny new pink box filled with sakura s goodness.
After reading through the whole thread I have an addition to the above query. Can you use the standard height sakura x1 rear shock tower instead of the trf416 tower?
Hope to hear from the experts soon.
Cheers,
Patrick
Originally Posted by wollow86 View Post
I'm about to test that as soon as my parts arrive. By quick comparisons, using a zero front bulk head cover, with the XI standard tower, should still fit standard size shocks. The 416 tower is basically a +4 tower. you can't use the XI bulk head cover though, the screws are about 2mm further apart.
Only ordered them mid last week, so probably won't have the bits until end of next week, or early the week after.
Got the parts today. Easy fit. Front zero bulk heads, rear XI tower, and add a 2mm spacer behind the ball stud.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 06-04-2012, 10:14 AM   #1624
I' recently run into a problem with my modded zero s.....it keep on eating the newly replace spur after i had an incident with a loosen spur screw....can anyone help?appreciate it.thanks!
jack_lee is offline   Reply With Quote
Old 06-04-2012, 02:27 PM   #1625
Check the layshaft screws to see if they are loose or missing. Also check the layshaft bearings for wear.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 06-04-2012, 02:32 PM   #1626
We sell this car for $89.99 with $4.95 shipping. Its a special order item though so it takes a few days to get it in. We plan on stocking them with the major parts in the future.
rm25x is offline   Reply With Quote
Old 06-04-2012, 07:21 PM   #1627
Hello all,
I was just wondering if the X1 motor mount SAK-X03/PK fits the same mounting holes as the SAK-S17/PK?
Just asking as the SAK-S17/PK has been out of stock for ages!
Cheers,
Patrick
Turnigy RWD SCT with 3000kv Hobbywing combo
Tamiya Nitrage 1/8 5.2cc Nitro Truggy
3Racing Sakura Zero 21.5T TC
3Racing Sakura Ultimate 13.5T TC
pmac is offline   Reply With Quote
Old 06-04-2012, 07:31 PM   #1628
aquito's Avatar
How many days would it take to ship it out? I'm interested in buying one.
aquito is offline   Reply With Quote
Old 06-04-2012, 09:06 PM   #1629
wollow86's Avatar
Hello all,
Cheers,
Patrick
Not quite, the screw for the motor mounts root arm is out by a few mm. It's 3mm further rearward for an XI mount on zero chassis. I have a zero mount on an XI chassis, just drill and countersink a hole.
Old 06-04-2012, 11:33 PM   #1630
Thanks 6376vette for the fast reply.i've ordered the bearing set to change.
So i'm running out of spur gear(48p,80t) and many of the suppliers is also no stock.does anyone now what car's spur fit our sakura?or any other manufacturer that produce part for sakura zero?thanks!
Old 06-04-2012, 11:37 PM   #1631
Pro10noob's Avatar
Xenon spurs will fit and i believe Kimbrough also.
Xenon i am sure as i used them on my Sakura Zero.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-04-2012, 11:42 PM   #1632
davenz's Avatar
I am using the panaracer spurs. I get them from rcmarket.com.hk.
link below
Dave
Sakura Zero - hw v3.1 sp13.5
3 racing cactus - 10.5 trackstar
Last edited by davenz; 06-04-2012 at 11:45 PM. Reason: http://rcmarket.com.hk/index.php?manufacturers_id=175&osCsid=8d59811fe92dbc36642d0b890d0fdb71
davenz is offline   Reply With Quote
Old 06-05-2012, 09:12 AM   #1633
link below
Dave
thanks!ordering the panaracer spur now....is it a direct fit?
Old 06-05-2012, 05:06 PM   #1634
Trader Rating: 49 (100%+)
Okay, so I'm going to ask several questions here and the answers are relatively important (yes I have read most of the thread, just double checking and making it easy to search for in the thread for myself). I am going to be testing one of these cars for our carpet track locally, to have another "entry level"/moderate price range chassis to get people racing this fall. In our area many people are not willing to drop $400 for a TC6 etc and then electronics etc etc, before they know they like it. From everything I have read, these kits are great kits and can compete with their Tc6 and Xray counterparts.
I will be testing the car as built from the kit to start (so I know what to expect and how it runs, when advising people on the kit). Then I will be getting parts that I hear are very helpful/necessary. Here are the things I know that I should try: 19t Pulley, aluminum spur gear adapter, and the vertical motor mount.
Some other parts I want to have for setups, are 1mil shims, different springs etc.
Our track is approximately 80x36, maybe slightly smaller, CRC carpet. The track will go from a "green" track to a track with a nice dark groove over the period of a few weeks nights or sometimes one weekend race day.
What springs would be good to use that 3racing offers for their mini shock? I will also be trying regular TC shocks with Tamiya shocks later, but want to try out what most people will have/ be able to get easily.
As far as Xi arms, these are supposedly harder and therefore break more easily? Is this correct?
I know there will be more, but for now this is a good start. I want to try to order a kit soon, build and start testing, so when carpet season rolls back around I'm ready to go. I'll probably be upgrading mine with carbon/graphite chassis' and others parts down the road, but I'll get that info down the road.
Thanks in advance.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 06-05-2012, 05:31 PM   #1635
Can someone please tell me what springs the kit comes with? And has anyone figured out the spring rates for their springs? It looks like their description of a spring tells the wire size, length, and number of turns, but not any sort of force/distance ratio.
Kevin Marcy is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 10:21 AM
