Old 05-18-2012, 05:25 AM   #1561
SteveM's Avatar
Trader Rating: 133 (100%+)
Originally Posted by team mopar View Post
Not to beat a dead horse the zero is the better car over the S ? Would this car be a wise choice for vta class? thanks for your input
The Zero would be over kill for VTA. I have a S with upgrades that might be better.
Sakura Zero S w/Upgrades
SteveM is offline   Reply With Quote
Old 05-18-2012, 01:41 PM   #1562
Lol. No such thing as overkill. my sakura s is a zero at this point and it did rather well in vta. I wouldn't say the zero is any better for vta but I wouldn't call it overkill. Either set up will do well in this class.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 05-18-2012, 02:19 PM   #1563
team mopar's Avatar
cool just need a good base to work with that someone has been happy with thanks for your comments. and thank you! Oh, if i go with the S what upgrades should i do before even putting it on the track. sorry stevem i have no paypal account lol
team mopar is offline   Reply With Quote
Old 05-18-2012, 02:21 PM   #1564
joelwhite's Avatar
Trader Rating: 55 (100%+)
Only things I have done to mine are the vertical motor mount, 19t pullies, aluminum spur mount and xray hard front pumper. Drives very well!
HEART OF A HUSTLER RACING TEAM
Trick Graphics--see spdrac430 on this forum for all your painting needs
Team Pit Racers-Fastest Guys In The Pits!
joelwhite is offline   Reply With Quote
Old 05-18-2012, 06:20 PM   #1565
FauxMako's Avatar
+1 Those would be the key upgrades.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 05-18-2012, 06:51 PM   #1566
SteveM's Avatar
I actually have two, one 95% upgraded and the second only with those few mods I listed in my for sale post.
Old 05-18-2012, 07:27 PM   #1567
I bet they both drive great too. I have been toying with the idea of getting the xi dh but I can't justify getting another chassis when the zero is so good.
Serpent S120 13.5
Old 05-19-2012, 03:38 AM   #1568
Also get titanium turnbuckles the stock ones bend easy and you cant get a wrench to turn them which makes setting camber/toe very frustrating, i also got extra springs one pair harder and one pair softer than standard
thefan is offline   Reply With Quote
Old 05-19-2012, 03:41 AM   #1569
SteveM's Avatar
Both are awesome and shame lots of fellow club racers with some very expensive rides. ;-)
Old 05-19-2012, 08:03 PM   #1570
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Are the center pulleys interchangeable with the Tamiya 416? I was looking at the 19t pulleys.
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 05-20-2012, 03:09 PM   #1571
wollow86's Avatar
I have some full size TRF shocks on the way, anyone who's running these what spring packs are you using? I was thinking HPI because I can get them locally, but I'm not sure if its the pairs of pro matched springs, or the pro 4 set that I should be getting?
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 05-21-2012, 04:30 AM   #1572
wollow86's Avatar
For a follow up on the XI chassis....
I'm in the process of building a hybrid XI/Zero (s), er, thing... and have found out a few things.
- The rear bulk heads, have a different configuration for the holes, on the XI chassis vs the Zero/s. This means that you cant use the 2 front screws to hold in the bulk head. But its still held in place by 1 pin and 2 screws, so should be fine.
- The XI deck doesnt fit using the Zero bulk heads. It's slightly to short.
- The Zero motor mount root arm, doesn't line up with the chassis screw. Misses by about 2mm. But the pin and rear screw do line up. The layshaft holder is fine.
Now I think the rear bulk head isn't going to be an issue. It will be secure enough with the 2 out of 3 screws. And I will just use the Zero CF deck with XI lower.
For the motor mount, I'm just going to drill a new hole and counter sink it.
The good news, is that the standard or alloy Zero (s) steering system mounts up fine. I'm yet to check it with knuckles on, but with a servo in it's fine. Just need to organise a kimbrough servo saver.
Old 05-21-2012, 02:46 PM   #1573
I use them with regular tamiya touring springs. I mounted my shocks on 416 shock towers (direct fit)
prorace is offline   Reply With Quote
Old 05-22-2012, 03:43 AM   #1574
wollow86's Avatar
Just finished the conversion to use an XI lower chassis on a Sakura Zero (S).
The car I used started life as a Zero S. When I got it, all that remained zero s was the layshaft holder, and lower chassis. The rest was basically Zero.
Here's the changes required for a zero to XI.
- Drill/counter sink a new hole for the motor mount root arm. 3mm forward.
- Dremel top deck around the front of the layshaft pulleys, aprox 2mm.
- Fit 517t front belt from Sakura XI.
I'll also be adding battery stoppers from the XI into the centre of the chassis to prevent the battery moving into the belts. And, because the car I picked up came with full size TRF shocks, I'll be moving those to my XI DH. So I plan to use the XI standard shock towers on the Hybrid, with either Zero front alloy bulk head covers on the rear, or XI rear bulk head covers. This will mean both my cars can run the exact same body mounts.
When I've done that I'll snap some pics of the finished product, but for now...
Old 05-22-2012, 04:10 AM   #1575
Quick question: If i change from 20T center pulleys to 19T center pulleys, would the car go faster? Aka. increase Internal drive ratio? Or slower? decrease Internal Drive Ratio?
Thomaseh is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
