Old 04-29-2012, 02:41 AM   #1501
Originally Posted by 6376vette View Post
If you are referring to the spec r ecs axles then yes. The 46mm axles for tamiya fit with no modifications. Be sure to get the v2 axles. v1had problems with coming apart at the pins.
Thank you very much sir 6376Vette. Ill try to order the V2
kikoy is offline   Reply With Quote
Old 04-29-2012, 02:44 AM   #1502
Originally Posted by mingnon View Post
i use the ones from 3 racing, havent had any issues
Thanks for the inputs MIGNON.
Old 04-29-2012, 03:08 AM   #1503
mingnon's Avatar
Gave the new metal outdrives a run last night. Usually have broken one of the Sak-09 on the pipes and/or wall, we run indoor on carpet in a local sports centre.
Ran the SAK-09HD - initially sounded really noisy and didnt feel smooth in the corners. A bit of AW grease solved that problem. When i got home pulled out the spool, and examined the parts. The inside edge appeared rough in its finish, so a bit of wet/dry and they are nice and smooth and work great.
Best of all, no breakages
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 04-29-2012, 09:44 PM   #1504
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
this car looks promising...
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 04-30-2012, 08:19 PM   #1505
aquito's Avatar
how good are there sakura for drifting?
aquito is offline   Reply With Quote
Old 05-02-2012, 11:57 AM   #1506
skyball's Avatar
...if you're interested in drifting, take a look at this: http://kkchung.pixnet.net/blog/post/30636934. It's a prototype sakura drift car...
skyball is offline   Reply With Quote
Old 05-02-2012, 01:19 PM   #1507
mingnon's Avatar
Damn!
that looks sweet !
Old 05-02-2012, 01:53 PM   #1508
hotshotrc's Avatar
We sell Sakura Zero's out of our store here in Marietta, GA. We are an authorized 3Racing dealer, so dont order from Hong Kong anymore when you can get it from us in 3-5 days ! Several people on this forum have purchased from us so what are you waiting on?
We have sold dozens of Sakura Zero's and hundreds of Hop Up parts.
Check us out at www.HotShotHobby.com. If you are in the Atlanta area, come race with us !
_Brad
HotShotRC Raceway and Hobbystore
http://HotShotRc.com http://HotShotHobby.com
1050 Industrial Park Drive, Ste C Marietta, GA 30062
770-427-3770
hotshotrc is offline   Reply With Quote
Old 05-02-2012, 09:58 PM   #1509
What surface is recommend, for the tires that come with the kit.
4bigkidtoys30 is offline   Reply With Quote
Old 05-02-2012, 11:10 PM   #1510
I'd assume the kit tires would make reasonable pavement carpark type basher tires. For competitive use you may want to look at a racing slick style or if VTA the HPI VTA tire.
Further to that when you VTA guys run the 200mm bodies on the zero s do you do anything to increase the track other than fitting the HPI or similar wheels 26mm/31mm wheels and tires front and rear?
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 05-03-2012, 03:47 AM   #1511
SteveM's Avatar
Trader Rating: 133 (100%+)
I ran the kit tires indoors on a carpet track and they worked surprisingly well. I normally run Sorex 24R or 28R slicks indoors.
SteveM is offline   Reply With Quote
Old 05-03-2012, 05:14 AM   #1512
No track modifications are needed. I ran a lot of different vta bodies with and they all fit fine with the 26/31 tire combination. My usgt Corvette doesn't quite fill out the rear wheel wells with a 26mm tire in the rear but it still looks fine.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 05-03-2012, 10:14 AM   #1513
my local track is asphalt, mid-high grip, not knowing if my track will eat the kit tires up...if I want to replace them, would HPI 26mm wheels with super compound tires work with this kit...3mm offset in front, and 6mm offset for rear!
Old 05-03-2012, 11:42 AM   #1514
Should work but I would keep the offset the same for 17.5. Check with the track though. A lot of places run a spec tire. If not look at the sweep 36 tires for warm temperatures and the sweep 32 for cooler temps. Solaris hard and medium compounds would work well too. Hard when it is hot out and medium when it is cool.
Serpent S120 13.5
Old 05-03-2012, 12:53 PM   #1515
mingnon's Avatar
no need to adjust track
heres a pic of my sakura zero s with vta body i run with down here in Oz
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
