GFX Mods
#31
Yes, the clear plexi has a cutout for the fan . I went to my local TAP plastics to have them cut the plexi and drill the holes too. I was going to do the Cathode Lighting with the clear plexi on top of the charger but, I ordered the wrong size Cathodes, I wanted 4" , accidently ordered 12"
Tre, thanks for the props, ofcourse, I was motivated to make the faceplates by looking at your work.
Thanks, John
Thanks, John
#32
Im In the prosses of Modding my GFX. Im sanding the case smooth (it's a lot of work) and Painting it gloss black. I have cut a window and have 4" tubes for it too. Ill post pics when Im done.
=MisFitz= NuKe: Can you check on your picture links, I cant see them.
Good work you guys.
Good work you guys.
#33
Pucho - What color tubes are you putting inside it? I have one 4" blue cathode tube and it's plenty powerful. The pain in it is that the transformer is big. I had to mount the transformer on one side and the tube on the other. I used deans connectors to connect to the board so when you open the case you can pull apart the wiring. I also wired in the switch. Let me know if you have a problem with the neon tube and the LCD display when it's all hooked up.
Runin Ronin - Oh, that sucks. 12" is too long
John
John
#34
I also have 2, 4" tubes, My window is not as large as yours so I have a little more options as far as the transformer goes. Thanks for the tip on the Deans plug I had not thought about that. Ill let you know how it goes.
#35
Good work you guys.
Good work you guys.
#36
alright, I put them back up...
#37
I heared someone had to millaniums inside their t-35. I was thinking 2 lrps comps with the motorun. would be the Sh!t I like to see how the guy did it.
#38
Looks good!
Hector: the reason that the Milleniums work is because the way they are layed out. I have looked into doing the same with the Pulsar but it would be waaay tooo much work.
OK back to sanding!
OK back to sanding!
#40
#41
John I have been soooooo buisy that I Haven touched my equipment in Months! so the case right now is in a grey primered stage. Someday Ill get to it.
#42
John could you take a pic of your gfx with the case off so we can see how you wired it and layed everything out?
#44
Anyone else have any pics?
#45
why can't I see any of those dam pics. it says the link to photbucket or whatever its called is gone.
