Old 07-06-2004, 03:30 PM   #1
onebeatuptc3's Avatar
Send a message via AIM to onebeatuptc3
Default Throttle Profiles?
Ok i have had my novak dually for quite a while, but i havent realized i have the option for different throtle profiles ( this is in my tc3 with a reedy spec 19t) and i have only set the esc up itself. What do the different profiles do? Thanks.
onebeatuptc3 is offline   Reply With Quote
Old 07-06-2004, 04:28 PM   #2
Wency_TA03R-PRO's Avatar
Bro throttle profiles are design for different tracks lay-out. Its a factory set profile but you can edit its program let say you want a more agressive response on every minimum throttle on the radio you can do it.. Its all in the manual of the ESC just read it well.. Hope it helps..
Wency_TA03R-PRO is offline   Reply With Quote
Old 07-06-2004, 04:56 PM   #3
hobbipro's Avatar
Trader Rating: 19 (100%+)
I believe the dually has only 2 profiles, a stock and mod. Stock will be punchy, and mod will be smooth. For 19T just use the stock profile.
hobbipro is offline   Reply With Quote
Old 07-06-2004, 09:38 PM   #4
Super Moderator
Grizzbob's Avatar
Right, & if you feel like you're having trouble with wheelspin, then that's another reason to try the mod profile, as it smooths out the feel of the throttle(making it a bit easier to control).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12
Go Pokes!!!
Grizzbob is offline   Reply With Quote
RCSignup.com - FREE Race Registration - FREE Track Profiles - FREE Racer Profiles superpb Web Links 3 01-16-2008 01:15 PM
SEO by vBSEO 3.5.0
