Like Tree42Likes
Old 03-28-2014, 05:51 PM   #151
could some one post a setup for gta 21.5t carpet rubber tire setup?
urban is offline   Reply With Quote
Old 04-07-2014, 09:42 PM   #152
does any one have their own pics of mi1v2?
Old 09-29-2014, 09:51 AM   #153
cementsurfer86's Avatar
Here's my base carpet setup for those looking for a base to start the indoor season. I've had great luck in our Scale Spec class, as well as some limited racing in Stock. FYI this setup is for the standard Mi1, but should cross over to the v2 as well.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 09-29-2014, 10:21 AM   #154
Could some one post the carpet stock setup thanks
TeamThibault is offline   Reply With Quote
Old 09-29-2014, 10:32 AM   #155
The only real difference between the two was rear toe and spring rates.
> Increase rear toe to 3mm per side
> Increase camber to 2 deg. all around
> AE Copper springs in the rear
> AE Purple springs up front
That made for a drivable car, although depending on layout and grip levels, you may want to play with springs a bit more.
Old 09-29-2014, 09:21 PM   #156
Default gearing
can you gear the car box stock to fdr 4 for 17.5 binky?
Old 09-29-2014, 10:14 PM   #157
Not sure, because I use 64p gears (kit comes with 48p)
Pick up Schumacher Pt# U2252, this will allow you to use industry standard spur gears, which will make gearing much easier.
Old 10-02-2014, 06:04 PM   #158
5th wheel's Avatar
Just now building my mi . going to try it on asphalt for practice than move on to carpet when our track changes over. So far it's a nice build
5th wheel is offline   Reply With Quote
Old 10-02-2014, 06:08 PM   #159
5th wheel's Avatar
Does anyone know how to install the u2252 gear adaptor thir no instructions with it
Old 10-02-2014, 08:17 PM   #160
The part comes with a lot of extra pieces that aren't needed. It was designed for multiple cars. The adaptor just slides over the pin with the spur attached to the adaptor itself. Then just add the layshaft pulley and spacers per the instructions.
Old 10-04-2014, 04:05 PM   #161
5th wheel's Avatar
Ok thank you sir I did not know what the other parts were for.
Old 10-04-2014, 11:25 PM   #162
Default servo
What servo are you guys are using?
Old 10-09-2014, 06:01 PM   #163
5th wheel's Avatar
I use a savox
Old 10-09-2014, 08:29 PM   #164
Savox SC1251MG. Inexpensive, fast and reliable. I like the low profile too, allows me to tuck my ESC cap behind it.
Old 11-06-2014, 11:42 PM   #165
Posted a small write-up on build tips for the Mi1, for those interested.
Copy and paste the link to my blog from my signature.
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
Original Schumacher Mission. For Sale Datruk Australia For Sale/Trade 7 04-06-2009 03:42 AM
Motor Question? WRXTC Electric On-Road 45 08-06-2005 01:01 PM
Tags
mi1, mission, schumacher
