Integy auto super lathe?
hey guys would you this was a good lathe for a first time buyer? iv used my m8s eagle and hudy lathes before but i need one for myself now, heres a link
http://integy.automated-shops.com/cg...20104048717.0f |
I saw one up close last weekend. Awsome lathe for the price, simple to use and the cut is perfect. The only thing that bothered me was that it I don't think you can get replacment blocks for it...
FD, I shouldn't worry, it comes with Carbide V blocks as standard so you are harldy likely to need replacements for many, many years, if ever!
Originally posted by fatdoggy I saw one up close last weekend. Awsome lathe for the price, simple to use and the cut is perfect. The only thing that bothered me was that it I don't think you can get replacment blocks for it... |
etzkev - Yes when I compared them(I have a mod fashion) they are almost the same(auto has slots in the guides for oil). The Fashion guides are dam near impossible to get anymore, they have been discontinued.
Once I aligned the blocks and replaced to a Mcmaster diamond bit, the lathe is just as good as the Fantom and Hudy lathes i've borrowed in the past. :)
Originally posted by fatdoggy etzkev - Yes when I compared them(I have a mod fashion) they are almost the same(auto has slots in the guides for oil). The Fashion guides are dam near impossible to get anymore, they have been discontinued. -etzkev |
Originally posted by Aurra Sing Once I aligned the blocks and replaced to a Mcmaster diamond bit, the lathe is just as good as the Fantom and Hudy lathes i've borrowed in the past. :) |
etzkev - Ahh the extremely pathetic depth adjustment. :lol: Yes you need to be very careful with it, I only ever do very fine cuts and never back it out. I'm using two shims under the bit, it maybe your shimming(or a misaligned or loose bit). I was running three shims till about 3 weeks ago when the cuts suddenly turned to crap, I dropped it to two shims and it's back to normal. :confused:
etzkev - i've got that xipp lathe a well. like fatdoggy said, it's likely the shimming. it seems like the factory likes the bits to be almost dead center, but i find that offsetting the cutting edge appreciably from center always produces a better cut. it sounds like your bit is either dull, or too close to center where it pushes the com away until the pressure allows the sharp part of the bit to dig in and begin to cut.
shim it upward so that the sharp edge sits atop the com just a bit. |
etzkev - i've got that xipp lathe a well. like fatdoggy said, it's likely the shimming. it seems like the factory likes the bits to be almost dead center, but i find that offsetting the cutting edge from center always produces a better cut. it sounds like your bit is either dull, or too close to center where it pushes the com away until the pressure allows the sharp part of the bit to dig in and begin to cut.
Originally posted by seaball etzkev - i've got that xipp lathe a well. like fatdoggy said, it's likely the shimming. it seems like the factory likes the bits to be almost dead center, but i find that offsetting the cutting edge appreciably from center always produces a better cut. it sounds like your bit is either dull, or too close to center where it pushes the com away until the pressure allows the sharp part of the bit to dig in and begin to cut. shim it upward so that the sharp edge sits atop the com just a bit. Thanks for you help though, etzkev |
Oh yeah, for any of you guys using carbide bits, I have some nice bits for sale in the for sale/ trade forums. They are all brand new and work great! :D
-Kevin |
