Old 07-02-2004, 07:26 PM   #1
xray racer's Avatar
Trader Rating: 22 (100%+)
Default Break In- cells??
i dont have a charger that has a break in fucntion, and i was wondering if i can break in motors off cells???
if so... how many??? and for how long do i break in the motor
and do i need to do anything apart from clean it up again after that???
i race stock if that makes any difference
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 07-02-2004, 09:52 PM   #2
As you mentioned, A charger with a motor run feature or an Indi dyno or similar device is Ideal for what your trying to do .....but you can also use a 3 or 4 cell pack... most people would agree that 3 volts is considered the optimum speed for most stock motor brush break-in ....check the brushes minute to minute until all four corners of the brush are seated (shiney)or if you have serrated brushes,until all of the serrations are shiney....usually 300 seconds (give or take)will do it....the cleaning and oiling(bushings or bearings) of the motor should be done before the break-inn....cleaning after the break-in wont hurt but is usually not nesessary on a fast break-in.......how often you tru your comm and repeat this depends on how serious you are.........the first 2 to 3 runs after the re-build will be your best .........hope this helps you some
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 07-02-2004, 10:36 PM   #3
Neil Rabara's Avatar
Three cells should be enough. About 2 min in length.
Neil Rabara is offline   Reply With Quote
F/S - 4 cells 6 cells IB4200 Batteries for TC or Trans Am Solara R/C Items: For Sale/Trade 5 08-11-2008 08:38 AM
2 packs Power push 3600 intel. cells,4 cells whynot R/C Items: For Sale/Trade 0 05-31-2005 08:01 PM
XRAY T1FK - RC12L3 - Serpent 710 - Surge Batteries (4-cells & 6-cells) and more XrayRacer R/C Items: For Sale/Trade 24 03-31-2005 02:19 PM
1.18+ cells -vs- orion's 1.19= cells dawgmeat Electric On-Road 142 03-31-2005 10:01 AM
SEO by vBSEO 3.5.0
