19 turn Vs Stock set up
Ok another set up question.....
I know Stock and Mod setups are different, but what about a car with a 19 turn?
What differences should I look at in a 19T set up for a TC3?
Thanks....
Thanks....
I run 19T & stock on a TC3, all i do is add a little drag brake, for the 19T & put more traction on the rear, via tires, traction compound, or ride height.
Re: 19 turn Vs Stock set up
Thanks....
Thanks....
What are you running now for tires, electronics etc? Is your car set up for stock w/rubber tires? What are you running on carpet or asphalt? Small or large track?
i do the same as charlie o, just a bit more drag, but i dont change anything else, if you want i can pm you my set up as it works for me on tarmac and carpet
J-P
J-P
TC3
Rubber tires
Rubber tires
Originally posted by mb racer
i run 19t with full roll and no breaks on asphalt with rubber tires ...dont run stock cuz "friends dont let friends run stock" .. but tires are usually 27 take offs or sorex 36s... ....
Location: Built By The Racers For The Racers. Corona CA
