Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-28-2004, 10:31 AM   #1
Default Some questions on how to operate a comm lathe
Just got the hudy tech lathe and this is my first time using a comm lathe. When you put the comm on the v blocks, do you need to remove all the motor spacers on the comm or do you just leave them there? How tight should the sliding v block rest against the comm?
Thanks.
Supra66 is offline   Reply With Quote
Old 06-28-2004, 10:35 AM   #2
Randy Caster's Avatar
You can set it up to where you can use the shims, or so that youd have to take them off, it's adjustable. I set mine up so that it doesnt use shims, and has very little play. When I cut I push lightly on the comm side of the armature shaft so that it wont wobble as I make my pass.
Tamiya TRF - Peak Racing - BMI Racing - KO Propo - AKA - Parma - Manutech - Slapmaster Tools - Pound It Paints
Old 06-28-2004, 07:17 PM   #3
Charlie O's Avatar
Ditto.
Charlie O is offline   Reply With Quote
Old 06-28-2004, 10:33 PM   #4
Need help on hudy tech lathe too.
if you unscre the Vblock to make adjustment for the arm. what is the good way to ensure that both Vblocks is parallel to each others and also perpendicular to the main block. This is to ensure that the final cut will not be corn shape.
thank you in advance
X9er is offline   Reply With Quote
Old 06-29-2004, 02:41 AM   #5
tornado's Avatar
Howdy! need a little help here too. I'm new to this lathe thingy.....just bought one and this machine has no instructions what so ever. The trouble is there is a bit and some spacers. The question is.....how many spacers must I put ?
Thanks to all da gurus.
tornado is offline   Reply With Quote
Old 06-29-2004, 03:26 AM   #6
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
it depends on the models and who ya ask some pages back are discussion about cutting comm with good diagrams
Yo!
KoE is offline   Reply With Quote
Old 06-29-2004, 06:46 PM   #7
WC
WC's Avatar
Trader Rating: 17 (100%+)
Keep a right-angle protractor & ruler with the Hudy case...
When I reset my blocks, I measure the distance between the 2 and use the right-edge to check that its square against the bulkhead.
I try not to adjust the blocks too much, I've fixed them to fit most of my arms. The looser arms just use a washer/s to shim the freeplay; its quicker than readjusting & measuring.
Measure your comm with good calipers across the straight surface and it'll show up if you've cut it cone-shaped.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 06-29-2004, 06:55 PM   #8
WC
WC's Avatar
Hudy Instructions (PDF)
www.PandaGFX.com
www.MelbRC.org
Old 06-29-2004, 07:03 PM   #9
tornado's Avatar
I've just got a 3-racing lathe.....comes with no instructions....blasted jets %&*@@@# and he just giggle and laugh.
Old 06-29-2004, 07:03 PM   #10
tornado's Avatar
Thanks mate .... though it is Hudy's instructions but it is very helpful .
Old 06-29-2004, 08:05 PM   #11
practice with an old arm. do not try cutting your best motor till you feel you understand the lathe. see if anyone at your track will help you get started. motor speed is important also.
i always use a washer on the comm side. when cutting i put slight pressure on the opposite side. use a little oil on the v-block also.
my final cut i use a small drop oh WD40. i like it better than the marker.
baih is offline   Reply With Quote
Forum Jump
Comm lathe questions firebirdude Rookie Zone 4 04-10-2008 01:59 PM
HELP Getting a Motor Lathe to operate RCpurplecow Electric On-Road 14 05-19-2007 11:29 AM
Trade EXTREME COMM LATHE(Hudy)for MUCH MORE COMM LATHE JoeyE R/C Items: For Sale/Trade 0 05-07-2006 08:49 AM
Comm Lathe Questions Cain Electric Off-Road 17 01-31-2004 10:31 PM
Motor lathe and comm stick questions racerdx6 Electric On-Road 7 12-19-2002 03:36 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
