Time to buy a new battery Any input?
#16
Correct me if I am wrong but the more amps pulled from a battery gives you the punch needed without the battery struggling???
so your saying if I ran a 21.5 turn brushless I should use nothing more than what a 30c battery cause I will get better punch??
amps=punch yeah?? but please correct me if I am wrong.
plus internal resistance will stop the punch from happening cause the lower the resistance the battery has the easier the battery will give up its power...
Fordy
#17
ThunderPower 25c Great bang for you buck!
#19
this is a description I found on ebay with a thunder power battery and its either a typo or this batteries isnt all that crash hot like ppl say.....
Thunder Power
5400mAh 25C 2 Cell 7.4v Li-Po
These potent batteries feature impact-resistant hard-case housings, a carbon fiber finish and a unique wire lead exit design where the leads can be positioned flush with the top or end of the battery, allowing for easy drop in. They fit in most cars and trucks. This battery includes 12-gauge wire leads with Traxxas High Current, and is equipped with Thunder Power balance connecters and wire leads compatible with all Thunder Power balancers and chargers with balancers.
Key Features
Perfect for backyard bashing or racing
Capable of continuous discharge rates up to 25C and burst discharge rates up to 50C
Delivers higher voltage under typical and heavy loads than most 15C to even 28C batteries
Specs
Type: Li-Po
Capacity: 5400mAh
Voltage: 7.4v
Connector: Traxxas High Current
Number of Cells: 2
Part Number: THP54002SSRT
Isnt it a 25c battery performing just better than MOST 15c batteries lol
Thunder Power
Key Features
Specs
Type: Li-Po
Capacity: 5400mAh
Voltage: 7.4v
Number of Cells: 2
#20
I'm no battery expert by any means. I asked and was told the 25c was as good as the 40c for stock racing. So why spend the extra money? They were good enough to take 1st and 2nd at IIC, and qualify 6th in super stock.
As for why to use the brand. Every big race I go to you always seem the Thunderpower guy walking through the pits. Which for me thats a pretty cool deal. It seems that the cells are very stable. I've yet to see a Thunderpower pack swell up, and most of the people I race with use them. Most importantly they are fast. The only down side to them was the case, and that has been fixed.
#21
My Thunder Power packs have been very reliable and their performance over time has not changed at all. That said, I did have a 5000/40c pack puff on me last summer. I had been using it for several months. I sent it back, well past the 90 day warranty, hoping to catch a break on a replacement. I received a brand new pack within a week, no questions asked. So yes, the packs are awesome, and in the rare event, the company backs them up.
Also, for what it's worth, I buy them with my own money.
#22
#24
For stock, both the 25C and 40C heat up more naturally through the run than a 50C pack will do. Stock is also not overtapping the batteries either. Modified racing will just meltdown a lower C rating pack without question. They pull a lot of current and need a batteey pack with a higher C rating. That is why for all the Thunder Power team drivers, generally 40C is the choice for stock (25C still works awesome though), and 50... or the new 65C for Modified.
Hope that helps a little bit. I'm sure Jim will pop on here if I'm stating anything incorrectly. LMAO
-Korey
#26
I use Thunder Power but I came across these: 6000mah 60C C-MAX Extreme 7.4V Lipo Battery - Deans Plug. anyone use them?
#27
I have a couple of em heading my way in the post. Will be a few months before anyone can give a report on how they perform long term since they're brand new. My 24C SMC packs have performed quite well so far and are almost a year old so hopefully these new ones work the same or better.
#29
Lipo batteries are very temperature sensitive. A 25C or 40C pack has a greater chance of heating up more than a 50C+ pack. That rise in temperature lowers the internal resistance, giving more punch.
-Korey
-Korey
