Old 06-26-2004, 06:12 PM   #1
macnkitty2002's Avatar
Unhappy hpi sprint gearing help
I've got an HPI Sprint, which is not the best electric to race with in the first place. I stuck a 17 turn motor in it and put a 64 pitch 122 tooth spur and a 31 tooth pinion. I got plenty of run time and a killer take-off, but no top speed! How should I gear it to reduce the take-off and increase the top speed? How can I keep up with the big guys without getting another motor?
Thanks for the help
Mac Scott
macnkitty2002 is offline   Reply With Quote
Old 06-27-2004, 01:41 AM   #2
R/C Tech Founder
R/C Tech Charter Subscriber
If the faster people are running lower wind motors (10, 11, 12 turn) it will honestly be tough for you to keep up with them using a 17.
Otherwise, you can always try gearing up a couple of teeth on the pinion, but don't overgear it. Try not to go below an 8.0-8.5 final drive ratio. You can calculate the ratio like this:
(teeth in spur / teeth in pinion) x internal drive ratio
Not sure what the internal ratio is on an HPI Sprint, you may have to check www.hpiracing.com for that information.
If you need a cheap, lower-wind motor to keep up, you might try one of Trinity's machine-wound Speed Gems motors. They are in the $35-or-so range and should get you a bit closer on top speed.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
1/10 sprint car radsnappy R/C Items: Wanted to Buy 1 06-14-2008 09:55 AM
Hpi Sprint 1 BayArea101 Electric On-Road 2 08-01-2007 09:00 AM
Need Help!! Hpi Sprint SArehart Electric On-Road 3 03-07-2007 11:02 AM
HPI sprint merc-blue Electric On-Road 0 01-09-2005 03:00 PM
HPI sprint merc-blue Electric On-Road 2 01-07-2005 03:40 PM
SEO by vBSEO 3.5.0
