Old 09-21-2010, 03:26 PM   #1
sosidge's Avatar
Default The HotBodies/HPI hub moulding...
The issue with the rear hubs on the HotBodies/HPI suspension mouldings are quite widely known - that one hub ends up with about 0.5 degree less rear toe than the other when mounted.
Has anyone noticed something similar on the front knuckles? I've noticed (three years late!) that the right-front wheel always has about 1 degree more negative camber than the left-front when the top links are the same length.
Both parts are on the same sprue (#73507), so that might have something to do with it.
Have HPI/HotBodies ever revised the moulding to improve the alignments?
Old 09-21-2010, 05:53 PM   #2
Korey Harbke's Avatar
When that happens to me, it's the upper bulkhead being bent, or the ball stud not being threaded in straight. Check those and see if it helps
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
SEO by vBSEO 3.5.0
