Old 09-20-2010, 02:34 AM   #1
Exclamation Problem about LRP SXX ver2 esc..?
hi guys,
i was using a new sxx ver.2 1month ago with LRP X12 4.5R motor(12.5mm rotor, -10 timing, gear ratio 8.8),
compare with my old tc spec esc, i feel this sxx ver.2 not good....
i try many setting about feel and boost...
speed is ok, but the throttle response not accuracy than my old tc spec esc...like if i give 30% throttle the esc give me a 20% or 50% response....
also, the automatic brake not enough even i set value 10 of auto brake mode......
Can they give me a solution or setting about these problem..... ?
teamsanwa is offline   Reply With Quote
SEO by vBSEO 3.5.0
