Old 06-19-2012, 07:09 PM   #1396
Thanks, guys!!!
Fluxn81 is offline   Reply With Quote
Old 07-03-2012, 09:21 AM   #1397
wrong17's Avatar
Trader Rating: 107 (100%+)
Here is a strange question for you guys...
Does anyone live in the Sacramento California area have a GTP2e that I can use to mark the mounting holes and wheel well on my brand new body? I have someone asking me to paint a body for them but I sold my GTP2e a while ago. So I can not trim the body or drill the mounting holes without a GTP2e.
Thanks for your help!
http://mytoyz.wrong17.com
wrong17 is offline   Reply With Quote
Old 07-08-2012, 02:08 AM   #1398
Hello from France,
some new modifications!!
I switch to Hobbywing SCT 120 Pro and it's better than my previous Hobbywing 150A. Smoother and lower temp!!
I also add some Yeah Racing fans on the Leopard motor.
Our last race was 31C (88F) in the air and 49C (120F) on the track.
After a 9mn race:
Battery (Hobby Center 4S/6.500mAh/70C): 42C (107F)
Moteur (Leopard 4074/2.150kv sensored with fans): 43C (109F)
Controler (HobbyWing SCT 120A Pro): 45C (113F)
Here's a video of that race (third A-Main).
My GTP2e SNR is the yellow Porsche in N1.
http://www.youtube.com/watch?v=1OSqP...1&feature=plcp
+ YouTube Video
Au revoir.
romuald31 is offline   Reply With Quote
Old 07-09-2012, 01:26 PM   #1399
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
Way to represent dude they don't have a chance.
www.snrgraphite.com
SNR Graphite is offline   Reply With Quote
Old 07-12-2012, 08:46 PM   #1400
Wondering what everyone has for tips..Right now I have Castle esc and 2200 motor. 6s setup running on it. I have a 47 spur and had a 20 pinion. I was using my phones gps and speedview to try and get a gps out of it. I ended up getting a reading of 76mph. I then upgraded to 29 pinion and was only getting 77mph on the reading. The car does seem faster and more unstable. It does flip easier as well. I just ordered a garmin forerunner 101 for a more accurate speed in the future. I am also going to need a new body since mine got pretty torn up. Suggestions for a body for speed runs? Suggestions for keeping it more stable at high speeds and the back end not wanting to slide out?
Robert
MCD Rally X4 27.2 full mod, Nutech Beetle 30.5 full mod, Tamiya Hilux, RC10T, RC10
wyattroa is offline   Reply With Quote
Old 07-12-2012, 09:52 PM   #1401
dasrustler's Avatar
Trader Rating: 35 (100%+)
Robert
What
tires are you running?
Body?
Suspension?
Losi 5ive 2028 MGM Compro 400A 80.9MPH |FG 4WD Brushless MGM 250A 107MPH
Savage XL MMM 1800KV | LST2 Mamba Monster 1600KV
Muggy Mamba XL 1717 | | GTP2E MMM 2200KV 123MPH
SCX10 Defender| Losi 8ight 2e 106MPH | HT-FPV NAZA GPS
dasrustler is offline   Reply With Quote
Old 07-13-2012, 07:40 AM   #1402
Originally Posted by dasrustler View Post
What
Body?
Suspension?
Running sweeps 50 shore
Stock body, no wing
Stock suspension, ride height just lower then where the stock bumper hangs down.
I have SNR carbon chassis on the way along with the front bumper and rear diffuser.
Robert
Old 07-13-2012, 08:38 AM   #1403
dasrustler's Avatar
Stock body, no wing
Robert
From my personal experience,
GRP B soft or PMT 20's
Ofna DP8 Body or the stock body with wing with rear lip trimmed off
Rear suspension as tight as possible.
Sweeps are terrible for speed runs.
Old 07-13-2012, 12:47 PM   #1404
Thanks! Anyone know when upgrading to the SNR carbon chassis if it is a direct swap over with all parts? Or are the dog bones from the center diff to the front and rear diffs going to be too short? I though I had heard mentioned it lengthened the car, but I am unsure.
Robert
Old 07-13-2012, 04:08 PM   #1405
It is a direct fit, the only thing you need to get if using the dm-1 front bumper and rear diffuser is 5 4x12mm screws and 5 4mm nylon lock nuts. I just did the swap last week and it is awesome you will love it!!
rarelyseen is offline   Reply With Quote
Old 07-20-2012, 07:10 AM   #1406
X2 !!!
Losi 8ight E Mamba 1800KV Fastest run 103mph on 5s
Ofna GTP2 E 2200kv 136mph and going up!!
http://www.youtube.com/watch?v=PWXNdQ4Ptl8
135mph run
LosiPat is offline   Reply With Quote
Old 07-22-2012, 12:50 AM   #1407
Threw a xl2 in because i destroy mambas . just need to make some 8s packs.
on 6s 5000mah run time seems endless.
Is anyone using the xo-1 tires ? i bought grp soft compound and they started chunking in the heat .
bigblkblazin is offline   Reply With Quote
Old 07-24-2012, 08:34 AM   #1408
Hello from France,
just want to share with you some informations about ratio.
Car: OFNA Ultra GTP2e
Controller: HobbyWing SCT120 Pro
Motor: Leopard Hobby - 4074 - 2.150kv - sensored - double ventilators!!!
Battery: 4S - 6.500mAh - 70C hard case
The spur gear is 51t and internal ratio is 14/44
Short track: pinion 16/17t
Medium track: 17/18t
Large track: 19/20t
Even with 30 in the air after a 9mn race, the controller temperature is around 45C, battery around 42C and motor round 55C.
Au revoir.
Old 07-24-2012, 10:37 AM   #1409
Send a message via AIM to Carpetracer92
So what tires do you guys recommend for bashing around? Slicks or foams?
Check out Long Island Low N Slow
Garage= Slammed g37,Full Exhaust
Carpetracer92 is offline   Reply With Quote
Old 07-24-2012, 10:56 AM   #1410
wrong17's Avatar
I like using the GRP 1:8 RALLY - B Soft from http://www.brucknerhobbies.com
$21.99 for 2 ($44 for a set) tires mounted on white wheels. Plus these tires are belted so you are good for high speed runs too.
If you ever mounted the stock ofna tires its a PITA... especially with the dual internal foam. And the non belted tires are useless once you go faster than 60MPH because it expands and flaps like crazy.
