Old 03-20-2012, 07:19 AM   #1336
Default Bearings
Is there a good upgrade for bearings for the GTP?? Thinking about that upgrade just want to make sure its worth it.
Losi 8ight E Mamba 1800KV Fastest run 103mph on 5s
Ofna GTP2 E 2200kv 136mph and going up!!
http://www.youtube.com/watch?v=PWXNdQ4Ptl8
135mph run
LosiPat is offline   Reply With Quote
Old 03-20-2012, 07:23 AM   #1337
dasrustler's Avatar
Trader Rating: 35 (100%+)
Been looking at avid engine bearings for the center spindle and regular ceramics for the outdrives. They don't have all in stock
Now only if I can find some alloy diff housings
Losi 5ive 2028 MGM Compro 400A 80.9MPH |FG 4WD Brushless MGM 250A 107MPH
Savage XL MMM 1800KV | LST2 Mamba Monster 1600KV
Muggy Mamba XL 1717 | | GTP2E MMM 2200KV 123MPH
SCX10 Defender| Losi 8ight 2e 106MPH | HT-FPV NAZA GPS
dasrustler is offline   Reply With Quote
Old 03-20-2012, 07:27 AM   #1338
drpower's Avatar
go on ebay look at all the choices Boca Bearings gives for Ultra GTP. I put an econo set into a restoration and even the cheap ones made the car feel like new.
drpower is offline   Reply With Quote
Old 03-20-2012, 07:41 AM   #1339
Thanks guys.... i will look into both of them!!
135mph run
Old 03-21-2012, 06:19 PM   #1340
drpower's Avatar
74.1 Mph today
Old 03-22-2012, 07:08 PM   #1341
tonydig11's Avatar
Trader Rating: 21 (100%+)
Hey guys. Today was my first run with the gtp2e in hot weather. I am running a MMM 2200 IV 51/18. Batteries are 4s 5800 35c. I had good get up an go for about 7 mins then it would run slower. I pulled over and has a motor temp if 170, esc temp of 125 and lipo temp of 150. These seem to high for me. Any suggestions on set up would be great
JQ THE e-car, Tekno V4 conversion, mamba monster, savox
Losi 5ive 5th scale
tonydig11 is offline   Reply With Quote
Old 03-23-2012, 06:19 PM   #1342
rcwck's Avatar
Motor and esc temp ok lipo a bit warm. 7 minutes is all that we race being hard into the throttle and voltage level. Your gearing is pretty short for those temps. I run an EDF fan on motor/esc with a 47/23 Tekin 2250KV set up. Track temps were 130 at times last summer. Straight speed ~ 55mph. I think you must have too much timing, some sort of drivetrain drag or a hardware issue. That gearing/KV should be much cooler and a straight speed ~40mph.
rcwck is offline   Reply With Quote
Old 03-24-2012, 12:29 PM   #1343
Monteman's Avatar
Trader Rating: 16 (100%+)
Ok so i have my DM-One Spec E bumper kit now. Is it possible to transfer a good chunk of the GTP2e parts to a DM-One chassis? Or are they totally different, not a chance of transferring the GTP2e front and back halfs over?
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 03-25-2012, 01:02 AM   #1344
Everything is different, spacing for diff cases, even the center diff/spool has different spacing then the dm1
Joat is offline   Reply With Quote
Old 03-25-2012, 10:14 AM   #1345
Monteman's Avatar
That's kind of what i discovered once i got unlazy and started comparing parts lists.
I have a decent tax refund coming this year, maybe i'll pick up a DM-one Spec-E in addition to my GTP2e
Old 03-27-2012, 12:02 AM   #1346
If you call ofna, tel them what car you have and what parts by part number you want to run, they have a capatbility chart. (i called them about a 9.5 buggy) noticed another buggy uses the same, but then realized that buggy, and another une use a same set of parts. called ofna they checked their chart to say if it will work or not.
ALIEN3T is offline   Reply With Quote
Old 03-27-2012, 07:04 AM   #1347
Monteman's Avatar
i was asking becuase i was thinking of just transferring all the GTP2e parts to a DM-one Spec E chassis and using the DM1 bumper/diffuser. (as an option to fabricating up some brackets for them).
Looks like the SNR chassis is my only "just bolt it on" option.
Old 03-29-2012, 08:44 PM   #1348
Trader Rating: 17 (100%+)
i just picked up one tuesday and just now finished paintiing it. i am using the tekin rx8 and 2650 motor, should be lots of fun. do they still race these in socal? i would like to give it a shot. i will post pics tomorrow.
ralph brunt is offline   Reply With Quote
Old 03-29-2012, 11:04 PM   #1349
RC Passion's Avatar
Bring it out to OC Circuit's surf city race this sunday. Look under California racing OC Circuit! 1st Sunday @ Surf City, 3rd Sunday @ Corona hobbytown!
RC Passion is offline   Reply With Quote
Old 03-30-2012, 12:34 PM   #1350
well here she is, my rattle can job bled through in a couple of spots think i need to upgrade the tires and the springs seem a bit soft, any suggestions?
