Old 03-12-2012, 07:46 AM   #1321
Originally Posted by dasrustler View Post
30/36 Speed run 5s 101
+ YouTube Video
Nice vid.... I've seen a few back flips myself
Losi 8ight E Mamba 1800KV Fastest run 103mph on 5s
Ofna GTP2 E 2200kv 136mph and going up!!
http://www.youtube.com/watch?v=PWXNdQ4Ptl8
135mph run
LosiPat is offline   Reply With Quote
Old 03-12-2012, 07:50 AM   #1322
dasrustler's Avatar
Trader Rating: 35 (100%+)
Thanks Pat. I bet you have. Although the free spin in mid air ruined one of my rear tires. Oh well it comes with the territory.
Losi 5ive 2028 MGM Compro 400A 80.9MPH |FG 4WD Brushless MGM 250A 107MPH
Savage XL MMM 1800KV | LST2 Mamba Monster 1600KV
Muggy Mamba XL 1717 | | GTP2E MMM 2200KV 123MPH
SCX10 Defender| Losi 8ight 2e 106MPH | HT-FPV NAZA GPS
dasrustler is offline   Reply With Quote
Old 03-12-2012, 12:11 PM   #1323
Monteman's Avatar
Trader Rating: 16 (100%+)
i wish i had an airport to play on.
watch those tarlines lol. they will get you every time
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 03-12-2012, 12:16 PM   #1324
dasrustler's Avatar
I got lucky. My friend works there so a whole length of decommissioned runway is ours all day
I usually run on the clean side of it but on Sunday the stunt drivers were doing their trials. Didn't wanna run at all but it was too tempting :-)
Old 03-12-2012, 12:39 PM   #1325
Monteman's Avatar
Nice. I should make friends with Airport staff here in Edmonton. We have an airport downtown doing nothing lol.
Old 03-12-2012, 12:43 PM   #1326
dasrustler's Avatar
It's always worth to make new friends :-)
Although it's a 40mile drive for me from LA. I figured better put money into gas rather than into a-arms and uprights lol
Old 03-12-2012, 04:24 PM   #1327
yeah i definitely notice the front bumper scrubbing. it will act as a skid plate of course but it certainly limits some suspension travel sticking down a good 1/4"
or so. What is involved in the DM1 bumper mod?
Here's some pics of how it is sitting right now. The body is just under level with the chassis, i have a bit of room to trim if needed.
You dont have to run DM1 bumpers to get more clearence, just grind the stock ones flush to the chassis , thats what I did, I do run DM1 bumpers now but only because I like the look of the rear diffuser one, so I run them as a matching set, I dont get max ground clearence like with a SNR chassis, but do get within 2mm of the chassis hitting the ground
But even then I run my DM1 bumpers lower ,and actually ground them down to make it not stick out past the 2mm titanium brackets I made
Joat is offline   Reply With Quote
Old 03-12-2012, 07:38 PM   #1328
Monteman's Avatar
i like the look of that rear diffuser. does the DM1 bumpers mount to the GTP2e chassis or do you have to custom it up
Old 03-12-2012, 07:54 PM   #1329
Two choices buy a SNR carbon chassis or make brackets like mine
Old 03-12-2012, 08:14 PM   #1330
Monteman's Avatar
Cool, gives me something to tinker with. SNR can keep the chassis.
That would be a completely pointless purchase just to mount a diffuser out back lol. For me anyways.
Fab job it is
If i can put a GTP2e bumper on my ERBE, im sure i can figure out a piece or something to mount the diffuser haha
Old 03-13-2012, 12:12 AM   #1331
Fab job it is
I run torsion/blade sway bars so I made these
front
rear
If you run regular sway bars you can make something that goes under the diff housing under the front lower pin plate I would then brace it for protection, and keep it from flexing under impact
With the blade/torsion sway bars I would need a slitting saw to do it the way I want.
Use Titanium, stronger then aluminum and lighter then steel, grade 4,it's not hard to work with at all, easier then stainless to me.
Old 03-19-2012, 07:17 PM   #1332
drpower's Avatar
RX8 2250kv 24T pinion
4S very fun
6S OMG, there may as well have been jet engines with after burners. Caught a bump and it was hydroplane airtime, OFNA tires without belt....torn to rags. Installed 50sh Sweep slicks, good to go. Garmin Forerunner 301 said 60.3 MPH, I think it could go closer to 80Mph on a better stretch to let it wind out. Eagle Tree logger reports temps aren't even getting hot, mind you it was 6 degrees celsius. The car is deadly, 4PL controls it perfect HS-7945TH steers it with excellent reponse. No complaints.
drpower is offline   Reply With Quote
Old 03-20-2012, 01:39 AM   #1333
wrong17's Avatar
Trader Rating: 107 (100%+)
Default IPANEMA Wide 49mm tires
Does anyone know if the IPANEMA Wide 49mm tires will fit on the front of a GTP2e?
http://mytoyz.wrong17.com
wrong17 is offline   Reply With Quote
Old 03-20-2012, 04:19 AM   #1334
They will fit but you do have to be careful and use EPA to make sure they will not rub your front A armís.
135mph run
Old 03-20-2012, 06:25 AM   #1335
wrong17's Avatar
okay... thanks
