Ofna Ultra GTP2e
#1308
Wow, those lights controlled by your 3rd channel are VERY cool.
So are you going to paint up another shell for everyday driving or just use the one with the lights?
Are they bright enough to light up the road in front of the car so you can drive around at night without hitting a curb?
#1313
Got a question for you guys, How do your bodies line up with the bottom of the chassis, do you run the shell even with the chassis or do you let the sides drop lower than the bottom of the chassis itself?
Finally got the new bumper installed on the GTP2e and the new Viper body i have for it is taller on the sides if you will than the PF8gt it came with. and I'm seeing a bit of fender rub on the rears on compression. Will raising the body up a notch or 2 effect the handling at all?
Also generally speaking what sort of ride height are you running on the GTP2e? Mine seems high compared to some pictures i have seen but that not a terrible thing as I'm not on the track and the extra bit of clearance helps for the small rocks and crap on the road/parking lots etc..
#1318
Would only recommend the extra body mods if you are planning on doing speed runs 80mph plus.
Lowest I have used is 8mm but you need to shim up the center diff from the chassis to maintain the arm angle (dog bones level) at ride height. You need to perform the dm-1 front bumper mod on the car as the gtp2e bumper will rub and act as a bump stop limiting suspension travel.
#1319
yeah i definitely notice the front bumper scrubbing. it will act as a skid plate of course but it certainly limits some suspension travel sticking down a good 1/4"
or so. What is involved in the DM1 bumper mod?
Here's some pics of how it is sitting right now. The body is just under level with the chassis, i have a bit of room to trim if needed.
