Old 02-25-2012, 12:16 AM   #1291
Jstall7543's Avatar
I got the gtp-2e lights all setup on 3s lipo switched thru my controller on the 3rd channel.
http://www.youtube.com/watch?v=-VhnE...e_gdata_player
RC is a way of life and a ridiculous hobby.
Ridiculously Fun! Subscribe to my YouTube Channel! Or ELSE! Hehee! http://www.youtube.com/user/Jstall7543
Jstall7543 is offline   Reply With Quote
Old 02-26-2012, 06:32 PM   #1292
Monteman's Avatar
Trader Rating: 16 (100%+)
Got a question about the power system for the GTP2e. I found a Novak HV Pro 6.5t combo here locally. Is this something that would be suitable for the GTP2e? What sort of speeds could i expect on 4s (which i believe is the cap on the HV pro, but it looks discontinued as far as i can tell)
Or should i stick with my MMM/2650kv?
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 02-27-2012, 01:36 AM   #1293
Hello from France,
heres my standart set up for my GTP2E SNR
Front: the SNR Graphite chassis allow to use an "inline" bumper so the ride height is much better!!
dif: 60.000
shocks: 800 / DM1 red springs / the more horizontal position but you must unscrew to get the right lenghth
Ride Height: 7mm
Caster: 1mm in the front of the arm
Camber: -3 (at the ride height) - then, adjust regarding tyres degradation
Optional sway bar: 0
Toe out: 1
Rebound: 1 mm more after ride height
Akerman: full forward
Rear: optional PBS rear end
dif: 30.000
Ride height: 9mm
Toe in: 3
Rebound: 2 or 4 mm depending on the braking
Camber linkage: the more angled
Electronic: HobbyWing 150A + 2250kv + 4S = gearing 16 to 19t depending the track size
Au revoir
romuald31 is offline   Reply With Quote
Old 02-27-2012, 11:58 AM   #1294
Jstall7543's Avatar
I'd stick with the 2650, I think the gtp2e is to probably to heavy for the Novak system. It would be drivable but probably not as impressive and wouldn't handle the heat as well so you would have to limit the gearing. From my experiance the Novak rotors delaminate from the shaft if they get to hot. The permanent fix is permatex sleeve retainer to re glue. I bought the HPI 2650/esc combo on tower for $249 shipped with member coupon. Not a bad deal.
Old 02-27-2012, 01:28 PM   #1295
Monteman's Avatar
yeah i was thinking it might be too small. wanted to check since i think the last novak anything i had was a rooster esc in my B2 lol
Old 02-27-2012, 05:48 PM   #1296
Thumbs up
That Novak motor is 36x72 and it could work awesome on 4s with lower gearing than your C1512 motor
watch temps and it could work real nice for you
if it were me, I would want to try that kv in this car
brushless55 is offline   Reply With Quote
Old 02-27-2012, 07:50 PM   #1297
Monteman's Avatar
what sort of gearing are you thinking on 4s?
Old 02-27-2012, 08:35 PM   #1298
Jstall7543's Avatar
I've got 3 ballistic 550's two 4.5's and one 5.5 with a hi torqe rotor in it, therefore I feel like I do have some knowledge about the motors. They are good for short cource trucks but they are lighter than the ofna. If you went full snr carbon I'd try to run one. I for one enjoy big block power! 6s 2200 or 2650 5s
Old 02-27-2012, 10:31 PM   #1299
Questions??
What is your gearing on the CC1512 motor now?
thanks
Old 02-28-2012, 04:26 AM   #1300
Originally Posted by petero292 View Post
That was a wicked run pat. It is awsome to watch that car run.
Thanks Pete.... I've seen your Losi 8ight do some sick passes you know
Losi 8ight E Mamba 1800KV Fastest run 103mph on 5s
Ofna GTP2 E 2200kv 136mph and going up!!
http://www.youtube.com/watch?v=PWXNdQ4Ptl8
135mph run
LosiPat is offline   Reply With Quote
Old 02-28-2012, 11:35 AM   #1301
Love the LED's!!! cool vid
135mph run
Old 02-28-2012, 11:57 AM   #1302
Jstall7543's Avatar
Thanks bro, installing them took several hours! But they look amazing at night, no problems seeing the car lol, can't look directly at it!
Old 02-28-2012, 06:57 PM   #1303
Monteman's Avatar
Here's a dumb question. All I can find for spurs for this guy are the 51t plastic spur #30110 and the 51t steel #31040. Is that it?
What are our options for spur gears on these. Or is everything pretty much based off XX/51 gearing?
Old 02-28-2012, 07:18 PM   #1304
Wow, those lights controlled by your 3rd channel are VERY cool.
So are you going to paint up another shell for everyday driving or just use the one with the lights?
Are they bright enough to light up the road in front of the car so you can drive around at night without hitting a curb?
rc10b4awd is offline   Reply With Quote
Old 02-28-2012, 07:49 PM   #1305
Monteman's Avatar
thanks
i currently have 17/51 on the car.
