Old 02-16-2012, 07:49 PM   #1246
Jstall7543's Avatar
I'm unfamiliar with the data logger, what exactly do you use it for? I assume it's to record voltage patterns/spikes? But what then? Can you give a couple examples of why I might need one? Or what you can do with it that's useful? It seems like it would be most useful on a track or for speed runs, and have a controlled event when creating the log.
Say your geared to the moon for a speed run on 4200 6s 45c on a 2650kv, and you attempt a 80 to 100mph run and the esc goes up in smoke does it fry your data logger too? Can you still obtain the data to figure out where you went wrong?
RC is a way of life and a ridiculous hobby.
Ridiculously Fun! Subscribe to my YouTube Channel! Or ELSE! Hehee! http://www.youtube.com/user/Jstall7543
Jstall7543 is offline   Reply With Quote
Old 02-16-2012, 07:59 PM   #1247
drpower's Avatar
Thats exactly why you get a logger, and obviously you wouldn't poor everything you have into your system and then max speed the first time out. gearing, voltage and speed start low view the results, bump it up, view the results etc etc. I have two temp sensors, one loop on the motor and another on the esc, plus an RPM sensor. See your power usage and temps in real time. Actually my friend is an electronics engineer and helps me when we use it so really I don't know much other than I want the temps to be in check. The logger has other options, FPV, GPS.
drpower is offline   Reply With Quote
Old 02-16-2012, 10:41 PM   #1248
Jstall7543's Avatar
I see, it could be handy for being able to tell if the battery is getting taxed the max or being able to tell if the battery will allow for more gearing. It just looks so cluttered on the chassis, wires everywhere! Anyone know if I can buy the x0-1 motor anywhere and what size it is?
Old 02-17-2012, 03:44 PM   #1249
Jstall7543's Avatar
Installed some LED's today for night runs, still not completely done yet.
Old 02-17-2012, 05:30 PM   #1250
Monteman's Avatar
Trader Rating: 16 (100%+)
as if the headlights where they were supposed to be weren't enough... the strip is a nice touch
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 02-17-2012, 07:14 PM   #1251
Jstall,
Thanks for the tips! Did you add loctite to any screws or disassemble/reassemble anything prior to your first run? Or was it pretty much just add electronics and go?
I see from one of your pics that you are using an HPI Tork motor. Were there any clearance problems between the motor and chassis? I was concerned about the tall "fins" on the Tork motors.
Look forward to hearing what speeds you're able to get with your new motor.
Originally Posted by Jstall7543 View Post
That's the body it came with from tower last week. It is weird the way they show the other picture but the description on the car is correct.
Im pretty sure you could go to 23t no problem. My 2650 just came in today, I'm going to stick with 20t on the 2650, I'm going 5s though. The car is a blast to drive! It's a rush! Out of the box I had to crank the spring pre load about a 1/4" or so, the springs are backed all the way off. Also need to ajust the droop screw to keep the front end from rising up to far under heavy acceleration. I also moved the rear hubs to the rear position for a little bit longer wheel base. Other than that I'm loving this thing! I ordered some 12v lights for it powered by a small 3s lipo turned on and off by the 3rd channel. Should be sick for driving under the street lights.
rc10b4awd is offline   Reply With Quote
Old 02-17-2012, 09:57 PM   #1252
Jstall7543's Avatar
I just put blue loc tight on the wheel nuts, everything else feels really tight. The installed motor in the pics is a hpi 2200kv i removed a few rows of the heatsink to fit in my sc8e to clear the rear chassis brace so I'm not sure if I'll need to do the same thing to the new 2650, I hope not! I'll find out tomorrow. I'm installing the tail light LEDs right now. I work night's so the lights will help in the parking lot when there are no overhead lights. The sinks twist right off with pliers if needed.
Old 02-17-2012, 10:05 PM   #1253
Jstall7543's Avatar
Ya, the 10mm 12v LEDs need to be installed on a angle so they don't point to the sky! I had to use a hot glue gun to install them with out any baskets. With the lights off they look just like projectors, it's pretty cool. I've only done one other set of lights on my crawler so this is all new to me. Being a machinist for over 20years makes things easier.
Have you ever tried 5 or 6s on your 2650?
Old 02-17-2012, 11:10 PM   #1254
Monteman's Avatar
No not yet, drove it once on 4s. I think that will be enough for me. For now anyways lol.
Old 02-18-2012, 09:10 AM   #1255
Jstall7543's Avatar
Here is the rear lights. They look really cool.
Old 02-18-2012, 12:31 PM   #1256
Jspeed's Avatar
Jspeed is offline   Reply With Quote
Old 02-18-2012, 03:29 PM   #1257
Jstall7543's Avatar
Can't get more aero than that! I like it!
Old 02-19-2012, 11:46 AM   #1258
Originally Posted by Jspeed View Post
When??? Huck
Huck50 is offline   Reply With Quote
Old 02-19-2012, 11:55 AM   #1259
Monteman's Avatar
It says soon...
im interested too, as if i don't have enough bodies already. lol
In other news, i need to buy a new front bumper assembly for my GTP2e...
The one i had fell onto the front of my ERBE-gt project...
Old 02-20-2012, 12:06 AM   #1260
Jstall7543's Avatar
What body are you going to run on the ERevo GT?
