Old 02-13-2012, 03:24 PM   #1231
Originally Posted by Jstall7543 View Post
I threw a GTP 2e together over the weekend. These cars are awesome for $179.99 shipped at tower with the $30 off coupon. It arrived in 3 days. I'm running the castle 2200kv on 5s 4200mah 45c Hyperion, savox 1257, drift box gyro, 20t pinion. This car is a blast, comes at you like a bullet! With the current setup I got 51mph on radar on a really sketchy road on my test drive. It feels way faster than 51mph. I'm throwing in a 2650kv on the same 5s battery this week. Should be rediculous for bashing around these streets.
I had my heart set on the DM1 but it is out of stock every where so I went with this and I have to say it drives great, cornering is great, drifts look awesome! I'm really happy with the simple 1/8 scale layout configuration and it works great, I didn't expect the car to be this awesome! My buddy's were like how much was this thing? $179.99
Nice! Any pics with the body off? Thanks,Huck
Huck50 is offline   Reply With Quote
Old 02-13-2012, 06:17 PM   #1232
Jstall7543's Avatar
Why is there so much DM1 talk in the GTP 2 thread? Just curious?
RC is a way of life and a ridiculous hobby.
Ridiculously Fun! Subscribe to my YouTube Channel! Or ELSE! Hehee! http://www.youtube.com/user/Jstall7543
Jstall7543 is offline   Reply With Quote
Old 02-14-2012, 09:12 PM   #1233
Hey Jstall,
Nice car. I'm thinking about getting one of these too. Did yours come with that PF8 body or the DP8 (McLaren)? The Tower web page shows a DP8 body and Ofna customer service told me this was a running change. Just curious which body to expect if I order one of these.
Also, do you think a larger pinion (like a 23t) can fit using the stock motor mount and spur (51t)? I'm thinking of running a 23t pinion with 2650kv motor on 4s.
Thanks.
rc10b4awd is offline   Reply With Quote
Old 02-14-2012, 09:43 PM   #1234
Monteman's Avatar
Trader Rating: 16 (100%+)
Jstall, that white body is so plain it is drop dead sexy. Wow! Love it!
Is that white white or pearl white? the front looks to have a bit of pearl to it?
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 02-16-2012, 03:59 AM   #1235
Jstall7543's Avatar
Originally Posted by rc10b4awd View Post
Hey Jstall,
Thanks.
That's the body it came with from tower last week. It is weird the way they show the other picture but the description on the car is correct.
Im pretty sure you could go to 23t no problem. My 2650 just came in today, I'm going to stick with 20t on the 2650, I'm going 5s though. The car is a blast to drive! It's a rush! Out of the box I had to crank the spring pre load about a 1/4" or so, the springs are backed all the way off. Also need to ajust the droop screw to keep the front end from rising up to far under heavy acceleration. I also moved the rear hubs to the rear position for a little bit longer wheel base. Other than that I'm loving this thing! I ordered some 12v lights for it powered by a small 3s lipo turned on and off by the 3rd channel. Should be sick for driving under the street lights.
Old 02-16-2012, 04:01 AM   #1236
Jstall7543's Avatar
No, no pearl. I used the HDR on my iphone4 so maybe it captured some other light in the room.
Old 02-16-2012, 04:31 AM   #1237
Jstall7543's Avatar
Bringing this GTP 2e thread back from the dead lol! I forgot i bought some pre mounted sweep belted treaded tires and wheels, they look sick. $78 shipped though. But I guess the stock tires are more prone to failure than the belted tires at the higher speeds. That reminds me the gtp 2e foams that come with the stock tires are the hardest I've ever done. I hated them! I cut and glued the inner foam to the wheels and then cut and glue the outer foam to to inner foam, then put one part of the tire completely on and stretch and work the tire around and over the inner foam, check for any foam lumps before glue, it's real easy to roll the outer foam over because the tires are really stiff and tight to the rims. This is all the info I have right for now hope this helps you guys out. The stock tires do work really well, the belted tires are primarily going to be for speed runs. The car pulls really really hard lol and now I'm adding more power! I just cant help it! For every day thrashing 50/60mph should be good enough for me. I'm sure on 6s the 2200kv will pull 60mph with a 20t pinion since I'm hitting 51mph on 5s. 2650kv testing this weekend.
Old 02-16-2012, 04:47 AM   #1238
Jstall7543's Avatar
Originally Posted by Huck50 View Post
That 42.4 mm heigth is the killer...I ordered a Savox 1232 with those same dimensions(actually it was 45.0 mm heighth) and it would not fit,bottomed out before I could bolt it down and sticks up at least 1/4",at least in my DM-1 Spec e,not sure about anything else.
After looking again...that heigth on the 1232 was 45.0mm,so this one may work?! Sorry for that...I guess I didn't check the dimensions properly! Thanks,Huck
Put some servo spacers in. Problem solved, lots of cars/trucks come with them in the kit. In the Rc8be, sc8e kit they are included.
Old 02-16-2012, 04:54 AM   #1239
Yeah! I had the same problem with tire foams on my DM-1 Spec e.My DM-1 came with the "standard" tires,not the belted ones(I bought separate)that I had trouble with.
I destroyed two sets of foams and then decided to have my LHS install the tires. I think he thought it was like installing a "regular" elastic band type tire,but these have zero stretch at all. My LHS ended up with a few lumps,but better than what I could ever get!
The Sweep EXP's I ordered had quite a few wobbles in them,at least two had a wobble and were out of round,so basically I could not use.
Someone should do video on installing the Ofna "belted' tires.Huck
Old 02-16-2012, 04:59 AM   #1240
Can I buy these "servo spacers" somewhere,or do they only come in a kit? My new Ofna DM-1 Spec may have them in one of the bags,What do they look like,a round plastic washer type? Thanks,Huck
EDIT: I found out what they look like and I will look in my parts bag,cause my Savox 1232 is too deep and hits the servo box bottom,before tightening down. Thanks,Huck
Old 02-16-2012, 12:50 PM   #1241
Jstall7543's Avatar
Nice, as long as the angle doesn't become to extreme and the steering linkage doesnt bind you should be fine! The spacers I have look kinda like a figure 8.
How's the DM1 go? I really wanted one but it was out of stock everywhere. I'm really happy with the gtp 2e so far, I might pick up a DM1 in a few moths if I really get into driving this car. Bang for buck the gtp is the most on street fun I've ever had! I'm turning it up another notch this weekend!
Old 02-16-2012, 01:27 PM   #1242
Jstall7543's Avatar
Here is the body off shot someone was asking about. This is before I put the drift box in, it's my initial test run setup. Fairly clean and simple install.
Old 02-16-2012, 04:54 PM   #1243
drpower's Avatar
GTP2e
Tekin RX8 2250kv
RC Monster HD 30T Pinion
Thunder Power G6 6S 65C 3850Mah
Hitec HS-7945th
IGT Hobbies 350Z Calsonic
Eagle Tree V4 150A
Garmin Forerunner 301
Left to right RC8B - 9.5 MBX - GTP2e
drpower is offline   Reply With Quote
Old 02-16-2012, 06:17 PM   #1244
Monteman's Avatar
Dayum! I have said it before but that Nissan body looks freaking amazing.
Old 02-16-2012, 07:46 PM   #1245
Jstall7543's Avatar
Ya, that does look like a real race car, with the power plant to back it up! 30t pinion on 6s must be loco!
SEO by vBSEO 3.5.0
