Old 12-22-2011, 11:46 PM   #1201
Was gonna do some test runs after I reassemble her, went to charge my TX pack and noticed it puffed
Joat is offline   Reply With Quote
Old 12-23-2011, 09:33 PM   #1202
Jspeed's Avatar
Nice work, very cool!
Jspeed is offline   Reply With Quote
Old 12-23-2011, 11:15 PM   #1203
Thanks, took me forever, 1 hour here and there over 5 months ,many design changes,not to mention I never used a mill before
Old 12-24-2011, 10:59 PM   #1204
is the Castle 2650 motor a good one on 4s or is there something better for this car?
I'm wanting to get into 8th scale and have a CC2650 lying around
thanks
brushless55 is offline   Reply With Quote
Old 12-25-2011, 02:06 AM   #1205
RC Passion's Avatar
thanks
It should run very well on 4s! Especially for speed runs and long straight-aways 200ft plus. Just make sure u run in an open area away from any obstructions and people!!!! ie an empty parking lot w/o curbs.
RC Passion is offline   Reply With Quote
Old 12-25-2011, 10:42 AM   #1206
Thumbs up Head spinning!
Ok, I'm getting a headache reading through this killer thread!
but I'm learing a lot here!!
Ok, sounds like the CC2650 motor I have on 4s will work great..
but now I cannot decide between the GTP2e, the DM-1, Or the Dirt Oval??
I am looking for a blacktop basher, but with the new traxxas car I may build a XO killer on 6s!
I have several motors to choose from
CC2650
CC1520 (1600kv)
Medusa 3670 2300kv
Medusa 3680 1600kv
someone help me choose...
Old 12-25-2011, 01:03 PM   #1207
Jspeed's Avatar
Looks great for being your 1st prototype, maybe consider manufacturing more of your kits to sell.
Nothing wrong with making a little extra coin and helping GT guys around the world at the same time. It takes a little work and small investment, but itís very rewarding when you see others enjoying your product.
The only downside are the typical jealous idiots that might badmouth you for being an entrepreneur and innovator, but you seem to have the talent needed to build great products for racers. Something to think about, Merry Christmas!
Good luck with your project!
Old 01-01-2012, 09:06 PM   #1208
c0nr4d's Avatar
Default Tires
Hey guys how's it going?
I am new to the on-road scene. I will be getting my GTP2e soon.
I live in a hot climate and I am wondering if these tires would be ok to use for just parking lot bashing.
http://www.ebay.com/itm/Sweep-Racing...#ht_3766wt_952
c0nr4d is offline   Reply With Quote
Old 01-01-2012, 09:55 PM   #1209
pcsmaui's Avatar
Sweeps makes good tires - but a couple of cautions, the one you gave a link to is Shore 45, which is a soft compound rubber - will wear quickly on hot asphalt. Which is one of the determining factors for choosing tires. The other is the surface - if it's a parking lot, I assume you'll have a fair amount of dust and sand, therefore I'd use a treaded tire. For high speeds - definitely belted.
I've had good luck with Sweeps 45, but on cool asphalt, and I only use treaded. For hotter asphalt, I've had the best luck with GRP B compound treaded & belted. Only place I've found them consistently in US is RCBoyz as far as I know they only come pre-mounted on white wheels - but they hookup well, and wear better than anything else I've tried.
Hope that helps.
(2x) Ofna GTP2e, Brushless
Losi 8 2.0, Brushless Conversion
(2x) Losi Ten - SCTE
TRX E-Revo, & TRX Summit Brushless
pcsmaui is offline   Reply With Quote
Old 01-01-2012, 11:35 PM   #1210
c0nr4d's Avatar
Hope that helps.
Thanks so much for the help man. Yea I would say the surface would have some dust/sand. I am looking at the 55deg treaded tires from RCBoyz's Ebay but none are belted. The 50deg is belted, would that be ok? What does EXP means?
I would love the black ones but these will do for now lol.
Have anyone used this servo?
http://www.ebay.com/itm/Savox-SC-025...#ht_1538wt_952
It looks taller, Im wondering if it'll fit.
Old 01-02-2012, 11:56 AM   #1211
Default lighter car
Originally Posted by SNR Graphite View Post
3615 grams or 7.9lbs
This is running weight with 4s lipo and body and PMT tires.
Steve, is that weight difference just with your carbon fiber changes, or did you have to change other items as well?
Also, i just left your site was wanderring 2x things:
1) is your GTP2E chassis set up to run velco straps for those trying to keep the battery low for lowest possible CG
2) if you had a Redemption code for RcTech members
Also, would you consider doing a carbon fiber rear wing for the cars.. they made a huge difference in 1/5 racing
jahno30 is offline   Reply With Quote
Old 01-03-2012, 09:57 PM   #1212
c0nr4d's Avatar
Default Servo
It looks taller, Im wondering if it will fit.
Old 01-03-2012, 10:01 PM   #1213
Monteman's Avatar
Trader Rating: 16 (100%+)
looks way tall in the pic, but then again it could just be the picture.
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 01-03-2012, 10:07 PM   #1214
c0nr4d's Avatar
It does look tall. Im just concern before buying it lol. You have any suggestions for servo with a good price?
Old 01-03-2012, 10:39 PM   #1215
Younggwapp's Avatar
That thing looks great dude.... I have a Dm spec 1e I'm building now
Younggwapp is offline   Reply With Quote
SEO by vBSEO 3.5.0
