Old 11-27-2011, 02:24 PM   #1141
Monteman's Avatar
Trader Rating: 16 (100%+)
is the tekin 1950 discontinued? or is it not in the redline series?
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 11-28-2011, 11:56 AM   #1142
FangsCPO's Avatar
I believe this chart is pretty accurate....unless something has changed.
http://www.teamtekin.com/t8/index.html
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 11-28-2011, 02:44 PM   #1143
Monteman's Avatar
Anyone have anything good or bad to say about the Orion 1950 set up available from Amain?
Old 11-28-2011, 05:24 PM   #1144
Vision's Avatar
Trader Rating: 38 (98%+)
Where are you guys getting the 47T from ?
6iX, GTP2e, XO-1, DM1-E, ST-R/MP777 GT2 Hybrid, GT2-VE, GT2-E Circuit, Hybrid Vorza, Rampage XB-E, Slash Platinum, tc5R
Vision is offline   Reply With Quote
Old 11-28-2011, 07:01 PM   #1145
Capt'N_Slow's Avatar
47t steel spur gear fits although it's not under the GTP2e parts list.
Part# OFN40247
Micah
Capt'N_Slow is offline   Reply With Quote
Old 11-28-2011, 07:28 PM   #1146
Monteman's Avatar
i cant locate that number on my LHs site, amain, tower or ofna. are you sure about that #
Found it, nitrohouse has them listed for the 9.5 violator
Old 11-28-2011, 10:20 PM   #1147
it's a Titan/Blazer part originally but it fits on the center spool just fine. The only problem with running the steel spurs is the pinions wear out quicker.
My suggestion would be to keep the 51T plastic spur until you start running out of motor mount.
Micah
Old 11-29-2011, 01:01 AM   #1148
Originally Posted by SNR Graphite View Post
Here you go.
Hello Steve,
do you weight your car?
Regards,
Romuald
romuald31 is offline   Reply With Quote
Old 11-29-2011, 05:53 PM   #1149
Think I got it figured out how to run a center diff with 44t spur
Joat is offline   Reply With Quote
Old 11-30-2011, 03:58 AM   #1150
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
Originally Posted by romuald31 View Post
Hello Steve,
Regards,
Romuald
3615 grams or 7.9lbs
This is running weight with 4s lipo and body and PMT tires.
www.snrgraphite.com
SNR Graphite is offline   Reply With Quote
Old 11-30-2011, 11:11 AM   #1151
tonydig11's Avatar
Trader Rating: 21 (100%+)
Hey guys. Been reading the thread but tons of pages so ill just tell my story. I have a gtp2 nitro that I broke in and bashed once. Well my water heater broke and rusted out almost every metal part on the car. Some things were saved like the diffs aome drive cups and front drive shafts.
Well today I got a gtp2e roller seeing I had a tone of extra parts and a decent price. Now for power system. I also about a month ago got a brushless revo withMMM 2200 system. So do a get a tekin for the revo and put the castle in the gtp, get another castle system or go tekin combo for car. No racing just bashing for me.
Also do the diffs come grease filled or oil and are the harderned diff bevial gear nessesary.
JQ THE e-car, Tekno V4 conversion, mamba monster, savox
Losi 5ive 5th scale
tonydig11 is offline   Reply With Quote
Old 11-30-2011, 11:45 AM   #1152
If you have an existing Castle system (with castle link) I would stick with the castle product as it's pretty solid and adjustable. Most people in the forums run motors ranging 2000kv to 2650kv so you are in the right ball park.
Try 16/17 pinion with the stock 51T spur. This should get you 45-48mph with low motor temps.
Diffs come grease filled but the oil is fairly light. For Drag Racing you will want to increase it to 50k-100k front / 10-30k rear.
The hardened diff gears are not necessary using 4S power. If you are regularly going to be using 6S power then I would recommend it.
Micah
Old 11-30-2011, 03:21 PM   #1153
tonydig11's Avatar
Thanks. Planning on 4s. But have to buy a motor esc anyways. So put a tekin in gtp and keep castle in revo. Or the tekin in revo and swap castle to gtp. Running 6s in revo. Thinking the sensored in gtp would be better tho
Losi 5ive 5th scale
Old 11-30-2011, 09:31 PM   #1154
For racing the Tekin has an advantage but for bashing, speed runs, or dragracing you just can't beat the castle.
Castle = Sensorless System
Advantage = Cost
Disadvantage = Initial Cogging, low speed acceleration is poor.
Tekin = Sensored System
Advantage = No Cogging, Good Low speed acceleration, Boost.
Disadvantage = Cost, More things to go wrong (sensor system).
Micah
Old 11-30-2011, 10:14 PM   #1155
Monteman's Avatar
stupid question. What pitch is the stock spur gear? Must be late and brain isn't working properly. Cant seem to find that bit of info.
