Old 09-12-2011, 09:47 AM   #1066
Originally Posted by rpompeu View Post
You won't need this, it doesn't come with a center diff, it has a spool;
Awesome! Thanks for the heads up.
mtrsprt is offline   Reply With Quote
Old 09-13-2011, 11:09 AM   #1067
Capt'N_Slow's Avatar
Default Front Tire Wear
Trying out a new tire manufacture running 45 shore (front/rear). The rears look spotless but the fronts do not have an even wear pattern and the outside of the tire looks like I am overheating it.
Do I need more camber in the front end?
Softer spring (currently running yellow)?
Harder Front Tire 50 shore?
Micah
Capt'N_Slow is offline   Reply With Quote
Old 09-13-2011, 11:46 AM   #1068
Getting warm yes, but that's when they get sticky. How's the traction?
Old 09-13-2011, 01:29 PM   #1069
The rears are hooked but the front end is pushing like a dump truck if I am on the throttle or off.
Normally for bashing I do not mind the car handling this way as it prevents roll overs and makes it very predictable for speed runs.
Micah
Old 09-13-2011, 01:45 PM   #1070
SNR recommends black stock front springs and no swaybar
Joat is offline   Reply With Quote
Old 09-13-2011, 04:00 PM   #1071
Was the picture of the tire you posted from the front or rear? You might need a slightly softer spring in the front for weight transfer under braking.
Old 09-15-2011, 02:34 PM   #1072
Front Tire.
Found the front spring had collapsed by 4mm compared to a new in package one. The front ride height was less than 7mm which would transfer the majority of the weight permanently to the back tires.
I didn't have another yellow to put back in so I went with a new white spring. Increased the front droop by .5mm, and softened the front sway bar.
Will give it a test and see if the front end slides as much and how the tires wear.
Micah
Old 09-18-2011, 06:32 PM   #1073
bronc4now's Avatar
Trader Rating: 40 (100%+)
HERES A NEW VIDEO
some new sweep 55 shore slicks bashing !
THANKS igt hobbies !!
http://www.youtube.com/watch?v=ozlkYRLgz5A
RACE-BASH-CRAWL
Two many toys not enough time..
bronc4now is offline   Reply With Quote
Old 09-19-2011, 07:55 AM   #1074
WildBillMassey's Avatar
Originally Posted by bronc4now View Post
HERES A NEW VIDEO
No Problem, Thanks.
Those tire marks on the pavement are bad ass!
Former owner of The Nitro Pit and IGT Hobbies
Now living in the Great White North.
You may think you know what you're talking about, but the only person you're fooling is yourself - Wild Bill Massey
WildBillMassey is offline   Reply With Quote
Old 09-19-2011, 08:11 AM   #1075
Default Need another GTP2
Hit something square and concrete at 85mph. I have never seen a 6S lipo accordion before or a drive shaft bent this badly .
My need for speed has died down a bit. Will have to pick through the carcass to find anything not broken.
Ofna Ultra GTP2e-side-profile.jpg   Ofna Ultra GTP2e-screen-shot-2011-09-19-8.52.04-pm.jpg
Micah
Old 09-19-2011, 10:38 AM   #1076
Hit something square and concrete at 85mph. I have never seen a 6S lipo accordion before .
Don't have a need for speed so much anymore.
That's going to leave a mark.....
I have assigned speed runs to better and better locations over time. A 9lb object @ 85mph needs a ton of width length to be safe from objects that just JUMP out at you! lol
Old 09-19-2011, 08:15 PM   #1077
Default Force
Weight of car = 7 lb = 31.1281 N
Mass = W / g = 7 lb / 32 ft/s^2 = 0.21875 slugs
Velocity = 85 mi/hr = 124.67 feet per second
Initial Kenetic Energy
Kenetic Energy = 1/2 ( 0.21875 slugs ) ( 124.67 ft/s )^2
KE = 1699.9728 ft lb
Stopping Distance = 8 inches
Work Required to stop the car:
Favg (d) = -1/2mv^2
Favg = 1.268875 tons (2537.75 lbs)
My 7 lbs car became 2537.75 lbs when it hit concrete? Is this right?
Micah
Old 09-19-2011, 11:12 PM   #1078
MambaPower87's Avatar
Trader Rating: 19 (100%+)
Thumbs up Transformers...
+ YouTube Video
CHECK OUT MY CHANNEL! (http://www.youtube.com/user/xxBLKChEvY07xx)
MambaPower87 is offline   Reply With Quote
Old 09-20-2011, 11:44 AM   #1079
SNR Graphite's Avatar
Originally Posted by MambaPower87 View Post
+ YouTube Video
I take it that you are a Transformer fan.
ME TOO.
www.snrgraphite.com
SNR Graphite is offline   Reply With Quote
Old 09-20-2011, 11:50 AM   #1080
FangsCPO's Avatar
Hey Transformers!!! Great looking lid. I recommend you apply a little shoe goo under the leading edge of your front end of your lid. It will make it last a little longer. Just my. 02.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
tc4basher
