Old 07-29-2011, 12:06 AM   #946
Originally Posted by SNR Graphite View Post
Yes it does I run no sway bar in the front and stock black springs 35wt oil.
really? doesnt the car bottom out when braking?
Joat is offline   Reply With Quote
Old 07-29-2011, 08:46 AM   #947
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
No it does not bottom out on my car because I use my CF chassis and DM-1 bumper so the bottom is flush. It give you more down travel.
SNR Graphite is offline   Reply With Quote
Old 07-29-2011, 09:16 AM   #948
daravelli's Avatar
Got mine today and will start building this weekend! Anything I should know before I begin? Thanks guys.
Hot Bodies Ve8 - Sold
Traxxas E-Revo - Sold
1/16 Traxxas E-Revo VXL - MMP Castle 5700kv - Sold
OFNA Ultra GTP-2E - Sold
Team Associated B5m
daravelli is offline   Reply With Quote
Old 07-29-2011, 10:16 AM   #949
Trader Rating: 16 (100%+)
Originally Posted by wyattroa View Post
So now I ask you, what are these tires rated up to? I thought they could go up to 100mph. I know the car is geared for over 100mph so I am just trying to figure out which tire to go with for when I find the right body.
I am running the alpha electric tested for 120mph.
Serpent 811BE w/ Tekin RX8 and 1900kv
Serpent Cobra E w/Tekin RX8 and 2050kv
Serpent 411LE w/Tekin RX8 with 5700kv Castle Creations (for now)
Motonica P81 RS Electron w/Tekin RX8 and 1900kv
Motonica P81 RS.2 Electron w/Tekin RX8 and 2050kv
DanielD is offline   Reply With Quote
Old 07-29-2011, 10:41 AM   #950
daravelli's Avatar
Which chassis are you using exactly? Link would be awesome man... thanks!
Team Associated B5m
Old 07-29-2011, 11:39 AM   #951
http://www.snrgraphite.com/index.php...0018386f490a24
It uses the dm-1 bumpers
Old 07-29-2011, 12:35 PM   #952
WildBillMassey's Avatar
DP8 bodies are due in Thursday.
http://www.igthobbies.com/OFNA-OFN31...en_p_1645.html
Former owner of The Nitro Pit and IGT Hobbies
Now living in the Great White North.
You may think you know what you're talking about, but the only person you're fooling is yourself - Wild Bill Massey
WildBillMassey is offline   Reply With Quote
Old 07-29-2011, 01:05 PM   #953
daravelli's Avatar
Cool thanks bud.
Team Associated B5m
Old 07-31-2011, 09:20 AM   #954
daravelli's Avatar
What type of adhesive are you guys using to glue the stock foams together? Just super glue or no?
Team Associated B5m
Old 07-31-2011, 01:18 PM   #955
CrazyERevo's Avatar
Trader Rating: 18 (100%+)
Just got my GTP2E assembled and tried to take it out today. Not even 10 seconds of driving and I completely stripped out the plastic spur gear all around.
Now Im trying to find out what I did wrong and I think I know just want to confirm.
My setup is:
Mamba Monster
Neu Castle 2200kv
5s 40c
One thing I did was I used a 18t pinion off of my erevo setup which is 32 pitch I believe. A guy at my LHS told me that MOD1 and 32 pitch are identical. Im guessing that he is probably wrong and this is how it all happened. Or is the 2200Kv on 5s too powerful for the stock plastic gear?
You guys are the pros here so I figured Id ask. I did made sure the mesh was set well. The allen bolts holding the motor in were very tight and I dont believe the motor shifted causing this.
CrazyERevo is offline   Reply With Quote
Old 07-31-2011, 01:25 PM   #956
the5's Avatar
Trader Rating: 42 (100%+)
Send a message via Skype™ to the5
32p and Mod 1 are not the same. Get the pinion that came with your kit and get the phone and yell at the guy at the lhs.
the5 is offline   Reply With Quote
Old 07-31-2011, 01:36 PM   #957
CrazyERevo's Avatar
Thanks the5, I figured that was the issue. I guess going off of what some people say isnt always correct. Im just going to order a new metal spur now anyway and a bigger MOD1 pinion too. I should have tried the 14t pinion that came with the kit but I got too antsy and wanted it to haul butt from the start.
Old 07-31-2011, 05:01 PM   #958
rc18junky's Avatar
i could use a little help
i want to get alloy rear hubs and steering knuckles and maybe alloy arms for my gtp2. i seen they have them for the ultra lx1 and since there almost the same i was thinking they may fit a gtp2 . can some one confirm thanks
http://cgi.ebay.com/OFNA-34002-Ultra...item4157d9271d
http://cgi.ebay.com/OFNA-34003-Ultra...item4157d9273c
Savage25 XL7-RC18t 9200K-Recoil 8000K-TC4 5700K-TL01-Raven ST-GTP2 XL7-Slash 4200K-MicroDT brushless and other crappy broken ones
rc18junky is offline   Reply With Quote
Old 07-31-2011, 05:10 PM   #959
Rkk
Rkk's Avatar
I had the same problem I must have adjusted the gear mesh for hours trying to get it right. So much easier with the right gear, lol
Rkk is offline   Reply With Quote
Old 07-31-2011, 06:04 PM   #960
Dont bother, your way better buying this
http://www.nitrohouse.com/p10939/REA...duct_info.html
SEO by vBSEO 3.5.0
