Ofna Ultra GTP2e >
Ofna Ultra GTP2e
Ofna Ultra GTP2e
Old 06-28-2011, 11:20 AM
  #871
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
You will want buggy motor.
SNR Graphite is offline
Old 06-28-2011, 06:30 PM
  #872
GaryA's Avatar
Ofna offers premounted slicks and treaded tires on white rims.
http://www.ofna.com/tires-onroad.php
Anybody out there know if the tires are belted or not?
I made the kit tires belted by using duct tape and they worked well.
GaryA is offline
Old 06-28-2011, 07:43 PM
  #873
FangsCPO's Avatar
Go with Sweeps, IGT Hobbies carries them or go with PMTs, FG Supply carries them. Don't waste your money on the OFNA tires. PMTs and Sweeps both come premounted, you'll definitely appreciated that. Good Luck!
FangsCPO is offline
Old 06-30-2011, 04:14 PM
  #874
Rkk
Rkk's Avatar
+1 for the sweeps I've been happy with them, although it is a bit warm here for the shore I am running. The ipanema's seem to be popular too, but I haven't tried them yet. The kit tires actually worked pretty well (bought my kit used so I didn't have to glue them.) Although the glue didn't hold up to the power, foam shifted and now they are way out of balance.
Rkk is offline
Old 06-30-2011, 04:20 PM
  #875
WildBillMassey's Avatar
The ones that come mounted are unbelted, but you can get the tires belted or unbelted and mount them yourself.
http://www.igthobbies.com/OFNA-TIRES_c_211.html
Also, as for Sweeps, we are starting to get the 55 Shores in for the summer heat. Slicks are here and treaded are on their way.
http://www.igthobbies.com/55-SHORE_c_252.html
WildBillMassey is offline
Old 07-01-2011, 07:24 AM
  #876
superspeed's Avatar
Does OFNA plan to make any RTR 1/8 brushless buggy, truggy, or GTP ?
superspeed is offline
Old 07-01-2011, 01:00 PM
  #877
Default Rear center cv ?
I know theres a front center cv for the gtp, it's from a mugen x6 muge0223,but has anyone found one for the rear ?
Joat is offline
Old 07-02-2011, 07:24 PM
  #878
Rkk
Rkk's Avatar
Everything I'm aware of from OFNA is ARR. Supply your own electronics.
Rkk is offline
Old 07-04-2011, 11:56 PM
  #879
GaryA's Avatar
I ordered some 50 shore Sweeps today from IGT Hobbies. A couple of guys at the Fantasy World track in Tacoma are running the 45 shore slicks. They seem to hook up great and wear very well.
I have been running some Ipanema 45s. The wider rear tire looks cool and makes a lot of sense from a traction and wear point of view. But for me, the car seemed to slide around more. I was at least a 1/2 second a lap faster with the kit tires, which is surprising. Plus, the Ipanemas kind of shred quickly on the FW track (cleaned parking lot track treated with Mountain Dew).
Maybe after a few runs on the Sweeps I'll give you guys a short report.
GaryA is offline
Old 07-05-2011, 05:41 PM
  #880
Trader Rating: 16 (100%+)
Ok maybe someone can help me with this problem. I keep breaking the rear diff gear and breaking the teeth off the gear that drives the diff. Gear.. meaning the gear that goes thru the diff cases and the coupler attaches to... so both gear keep shreading. Thanks in advance
DanielD is offline
Old 07-05-2011, 11:24 PM
  #881
kcunamay's Avatar
Trader Rating: 20 (100%+)
Hi GaryA,
Are you running the Ipanema 45's on your E car? And for the guys running the 45's at the fantasy world track are they on NITRO or E cars as well? I ask as that shore compound regardless of what manufacturer they're from don't do very well with the hotter temps we have down here in SoCal when run on our E cars. Although, in colder weather, they do pretty well. In the Nitro cars the softer shore compounds still work as it's not as easy to overheat them.
Cheers!
kcunamay is offline
Old 07-06-2011, 09:03 AM
  #882
Hey guys, I decided to grab one of these as a companion to my 1/8 buggy. My main use is just playing around on the street and top speed runs. My problems are as follows. Any help well be greatly appreciated:
1) This thing handles terribly. What kind of suspension mods are you guys doing?
2) I do have the center diff but can't seem to get the setup correct in terms of fluid. Any suggestions?
Thanks in advance.
4x4moneypit is offline
Old 07-06-2011, 09:41 AM
  #883
You may want to replace the diff case. There may be a problem there. There is also a hardened ring gear available. Part# 31010 Are you circuit racing? What system are you using?
D Starks is offline
Old 07-06-2011, 10:34 AM
  #884
If you he goes with the hardened ones he'll need to also change the front as the E has a different ratio, and he'll have tto change both pinions too,either way make sure you shimm the pinion gear to the ring gear
Joat is offline
Old 07-06-2011, 01:05 PM
  #885
31010 has same ratio as stock.
