Old 04-07-2011, 05:02 PM   #661
Capt'N_Slow's Avatar
Originally Posted by GRKSTL View Post
What parts do you use to modify the shocks to make them longer? Can i just get 2 more rear shocks and stick them in the front?
Rear shocks are much to long to fit on the front and maintain your ride height low enough.
Just turn the bottom shock holder out 2-3mm is all that is needed to make the stiffer dm-1 springs easier to install.
Micah
Capt'N_Slow is offline   Reply With Quote
Old 04-07-2011, 09:43 PM   #662
Trader Rating: 7 (89%+)
I was able to get DM-1 front and rear springs at my LHS today. The front springs fit, the GTP 2-E front shocks, just fine. You have to adjust the nut 2-3mm like you said. The DM-1 rear springs are too short to fit the shock bodies on the GTP 2-e. The adjustment nut will not adjust anymore and you have to much play in the spring.
Any other ideas?
GRKSTL is offline   Reply With Quote
Old 04-07-2011, 10:56 PM   #663
Any other ideas?
I am running ultra front shocks in the rear too
Joat is offline   Reply With Quote
Old 04-08-2011, 01:42 PM   #664
Bubblehead's Avatar
What are rule's for GTP2e? (are the classes boosted or non-boosted, length of race)
Bubblehead is offline   Reply With Quote
Old 04-09-2011, 09:26 AM   #665
FangsCPO's Avatar
I can't see needing to boost, those rigs are damn fast already as it is. Also, if you using a RX8 ESC, there is no boost option, only timing.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 04-10-2011, 07:56 AM   #666
Jspeed's Avatar
Originally Posted by rsc View Post
does any one know where to buy ipanema 60sh tiers i have tried ipanema sports and there distributors with no luck.
We usually inventory our harder 60 & 65 shores later in the summer USA season when temps in some placed are in the 95+ degree range.
Check your pm, ok Thank you.
Jspeed is offline   Reply With Quote
Old 04-11-2011, 08:43 PM   #667
Thought i would throw up my Ofna GTE.
It should see a track in about 2 weeks.
Desoto Racing, Serpent America, Novarossi, KoPropo, Xceed.
2011, 2013, 2 Time Midwest Series 1/8th Open, Champion
2011 Byrons onroad 1/8th Open 3rd
2011 Roar Nats 1/8th Open, 5th
2012 GLC 1/8th Open Q7 Finish 5th, 2013 GLC 1/8th Open Q4 Finish 7th
Vector03cobra is offline   Reply With Quote
Old 04-12-2011, 12:20 AM   #668
So if I was to pick up one of these kits, what esc/motor combo do you guys recommend? And servo?
Thanks in advance.
ozzfest is offline   Reply With Quote
Old 04-12-2011, 12:36 AM   #669
drpower's Avatar
Tekin RX8 2250Kv
Hitec HS-7945TH or KO Propo RSX
RC Monster Mod 1 pinion
Sweep EXP - I got the preglued on 6ix packs and they are amazing.
I have been running this with a Reedy #626 4S 5500Mah 65C, and I also have a Thunder Power G6 6S 3850Mah (Only for a Top Speed run) that I am waiting to try once I get the Eagle Tree V4 150A logger and install it.
I heard guys racing with a 1900Kv on 5S so look at that too. Haven't heard a lot from guys with the 2650Kv motor, but I've been out of the loop for some time.
drpower is offline   Reply With Quote
Old 04-12-2011, 06:13 AM   #670
Trader Rating: 31 (100%+)
Send a message via Skype™ to vstrok
What diff weights are you all running? How long does it take you to change per each diff?
Ofna GTP2e - Tekin RX8 / Tekin 2250 kv
Ofna Hyper 10SC - MM Pro / Castle 6900 kv
Ofna Hyper 10TT - MM Pro / Tekin SC4X 5.5T
vstrok is offline   Reply With Quote
Old 04-12-2011, 02:22 PM   #671
Justpassedu's Avatar
Trader Rating: 115 (100%+)
i have a brand new 1 forsale if anyone want's it with a brand new ipanema warrior body - Brand New-Ofna 1/8 Gtp2e OnRoad & Ipanema Gt Warrior Body (never taken out of box)
Mugen Mbx6 Eco
Justpassedu is offline   Reply With Quote
Old 04-12-2011, 06:39 PM   #672
My buddy may be interested. He has some sick Mini Z's. You into a trade? He has some hooked up ones.
Old 04-12-2011, 07:48 PM   #673
No sorry not looking for mini z's but he or you can always pm me if you'd like to work something out.
Mugen Mbx6 Eco
Old 04-12-2011, 08:48 PM   #674
Thumbs up
Originally Posted by drpower View Post
Tekin RX8 2250Kv
Thanks for the info! Really appreciate it.
Old 04-12-2011, 09:05 PM   #675
FangsCPO's Avatar
Thanks in advance.
I have a DM-1 Spec Tekno converted
Tekin 2250kv RX8; geared 16/48 (center diff)
I'm using Futaba S9156, slightly overkill but better safe than sorry.
TLR Team Driver
