Old 03-03-2011, 07:37 AM   #571
treborwd22
Thank you for the setup
Did you change the roll center at all (upper and lower hing pins) ???
Thanks again
Lazer Guy is offline   Reply With Quote
Old 03-03-2011, 08:17 AM   #572
treborwd22's Avatar
Originally Posted by Lazer Guy View Post
treborwd22
Thanks again
No... I left that alone
Team Associated Tc6 "Blinky"
Xray T2 Exotek "Spec GT Class"
Ofna GTP2e w/Tekin RX8 2250kv
Losi SCTE
Spektrum DX3r Pro
treborwd22 is offline   Reply With Quote
Old 03-03-2011, 10:44 AM   #573
drpower's Avatar
Hey there Trebor... I wanted a cool car car so I've been collecting the following:
OFNA GTP2E
Tekin RX8 2250Kv w/Hotwire
Hitec HS-7945TH
Sweep 50SH white 6ix Packs
RCM 30T & 24T pinions
igthobbies 350Z Calsonic (completed)
Thunder Power G6 6S 5000Mah + EC5 connectors
Futaba 4PL
Garmin Forerunner 301
The original clear body that comes with the GTP2E kit is being professionally airbrushed and every one of these items is in its box, brand new and ready to be put together when I get back from the Coast Guard patrol I am on right now. The Storm last night brought winds to 80Mph!!
drpower is offline   Reply With Quote
Old 03-03-2011, 01:41 PM   #574
treborwd22's Avatar
OFNA GTP2E
Hitec HS-7945TH
Futaba 4PL
Awsome man!!! Looks like its going to be a good setup. 30t with the 6s lipo WOW! Watch out you dont tear up the diffs with all that instant power As for the 80mph winds I know what you mean. I was stationed in Bremerton WA and would spend weeks in the water where your at about 100 miles outside Vancouver and its not fun. Got to strap yourself in your rack when the winds are that high because of the swells.
Losi SCTE
Spektrum DX3r Pro
Old 03-03-2011, 02:07 PM   #575
treborwd22's Avatar
Thanks Steve (snrscion)!!! I just got my front and rear shock towers
I will post picks later tonight.
Losi SCTE
Spektrum DX3r Pro
Old 03-03-2011, 07:16 PM   #576
snellemin's Avatar
Trader Rating: 16 (100%+)
DrPower, you also need a datalogger to see what your system is doing. Your battery, motor and 30T pinion combo is something you have to be careful with. You really want to see what your battery is doing under that crazy load. Additional caps will ease the stress on the ESC and improve your braking. You allready spend a ton of money on good parts, spend a little more on the logger and see where you stand power wise.
Things you can achieve with a logger:
See voltage drop under load.
See amp draw with different gearing.
Total mah used.
Voltage increase during braking. Very important!
You can also add temp sensors, brushless motor sensor, gps etc.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 03-04-2011, 01:25 AM   #577
drpower's Avatar
Total mah used.
I forgot to add that I also bought a Novak 5685 Power Trans Cap Module....what logger do you suggest. There is the Eagle Tree V4, and sometimes there are used V3 systems for sale. I was told at one point that the 150A version would be best. which sensors are recommended? I'm guessing: Brushless RPM, loop temp & micro temp, or maybe two Micro temps instead?, servo current-monitor
what about the novak sentry data logger I just read there is a pro version
Old 03-04-2011, 05:47 AM   #578
snellemin's Avatar
I've blown the leads off single caps before. I recommend two caps instead. The one I recommend to most people is the 10 cap bank you can get from offshoreelectrics.
The new Eagltree V4 150A logger is what you want. In the beginning I used the temp sensor alot, but after a while I knew what to expect temp wise. There is no need for the servo current monitor, but it's nice to have.
Temps I monitor are from the ESC and battery. Warmer battery has less resistance, thus putting out more power.
6 KiloWatt Racer
Old 03-04-2011, 08:29 AM   #579
treborwd22's Avatar
Ok.... Here is the GTP2e with the carbon upgrades from SNR-Graphite
Losi SCTE
Spektrum DX3r Pro
Old 03-04-2011, 08:42 AM   #580
WOW !!! I like your car !!!!
Do you have the snr chassis also ??
Do you know how much weight the snr stuff took off ??
Thank you
Old 03-04-2011, 08:48 AM   #581
treborwd22's Avatar
Thank you
No... No chassis yet. I did not weigh the stock parts vs. the carbon fiber. Sorry, I did it more for looks and the rear offers more adjustability vs. the stock shock tower.
Losi SCTE
Spektrum DX3r Pro
Old 03-06-2011, 04:29 AM   #582
Bubblehead's Avatar
Default GTP Conversion
I have a 1/8 Jammin' X1 nitro buggy and I would like to convert it into a GTP, I know I can get a kit to convert nitro to electric. Will OFNA's or is there a kit that will convert my buggy into a GTP?
Bubblehead is offline   Reply With Quote
Old 03-06-2011, 10:16 AM   #583
simplechamp's Avatar
Trader Rating: 73 (100%+)
I just got done converting my Jammin X2 to a GT car. I sent you a PM with a link to my build thread on RC-Monster.
There is no kit available to convert the Jammin buggy to a GT car, but it is very easy to do with a few Inferno GT parts, which bolt right on or only require slight mod. You can find all the parts I used in my build thread, or send me a PM back and I'll make a list.
Depending on what you have to buy it might make sense to convert, or it might be more economical to buy a GTP or DM-1 instead. For me I never ran my buggy off-road much anymore, but still had a nice CF chassis to use and a ton of parts, so I decided to convert my Jammin so I'd still be able to put those to use.
The 1/8 GT electric thread has tons of good info on conversions and all other GTs: http://www.rctech.net/forum/electric...-electric.html
Serpent 811Be - Jammin X2 Carbon e-GT conversion - Axial SCX10 Honcho
simplechamp is offline   Reply With Quote
Old 03-06-2011, 10:32 AM   #584
drpower's Avatar
Tekno has a kit for the X2, I didn't see one for the X1 but I could be wrong. I was going to convert my 9.5 MBX at one point as well, and found that for $200 the GTP2E was a no brainer and smarter platform to start with... although the buggy I had left a little to be desired so it was an easy decision. After months of building I'm happy with what the result will be, and the 9.5 is still available to annoy the neighbors some lol Let us know if you find a kit or what you do.
Old 03-06-2011, 04:04 PM   #585
Bubblehead's Avatar
simplechamp thanks,
I ordered my Ultra GTP2 today at my LHS should be here Thursday I also ordered a Tekin RX8 BL 1/8 SYS MTR 2650KV. Which battery should I buy 3S or 4S?
