Old 02-10-2011, 11:23 PM   #466
Originally Posted by snellemin View Post
Well speed and the 2250 motor is mentioned, which is the truggy motor. That motor can pull some tall gearing. I ran the Plettenberg BigMaxximum which is 2300kv on the 47/28 gearing on 4s. Currently running a 1515 2700kv motor on the same gearing and 4s. I'll find a way to fit the 30T pinion on my motor mount.
I just received 2 more 4s Acepow lipos, the new 50Hz Eagletree logger, Eagletree 10hz GPS receiver for my 4s 100mph quest.
do you use the stock motor mount? i have to get another gear mine is getting pretty beat. the 28 will fit with the 47 with no issue? i was running the 51/26 and that was right on the edge, but im gonna get the 47 and 28. definatley glad to rc monster goes up to 30t now
scrivtwin2 is offline   Reply With Quote
Old 02-10-2011, 11:30 PM   #467
also do they only make the 47t in steel or do they have a plastic one?
Old 02-11-2011, 07:01 AM   #468
rcwck's Avatar
Default 47t pinion
Where do find the 47T spur for the single speed? All I can locate is the stock 51T.
rcwck is offline   Reply With Quote
Old 02-11-2011, 07:18 AM   #469
Pit-racer's Avatar
Thumbs up
Originally Posted by treborwd22 View Post
Well it finally arrived!!! Hope to test it out sometime this week and get it ready to race by the 18th!!!
Thanks igthobbies!!!
That's an awesome chassis .... now you need the Alpha R2 body to complete it.
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 02-11-2011, 07:37 AM   #470
snellemin's Avatar
Trader Rating: 16 (100%+)
I'm using the RC-Monster motormount, as my rides are nitro conversions.
The 47T only comes in steel. You can do plastic 46T, and 44T if you use a center diff.
The 47T can be found at Nitrohouse and it's made for the center spool. Seek the Titan/Blazer spur #40247.
I didn't opt for a center diff and 44T spur, as I'm afraid that I will run out of torque when geared for a roll out of 2.26 and only running 4S. My diffs are allready made for a higher topspeed 44/14, compared to the buggy diffs 43/13. I could do a 40T spur, but will need to go with an 8S setup. I have allready gone the 10s A123 route once before in my GTP and want to do something different. I blew up the diffs within a few speed runs what that kinda power. The diffs lasted longer once I went to the KingHeadz diff cups and hardend ring gears.
Here is the pic of the 47T spur.
Here is the 10s A123 setup running on ipanema's.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 02-14-2011, 10:05 AM   #471
WildBillMassey's Avatar
Alpha R2 bodies now in stock at IGT Hobbies!
http://www.igthobbies.com/product_p/alp18r2.htm
And we just got another shipment of the R1 bodies.
http://www.igthobbies.com/product_p/alp18r1.htm
AND, since this is the electric forum, we would like to announce that we are now an authorized RC-Monster dealer, and I will have the items on the site shortly!
Former owner of The Nitro Pit and IGT Hobbies
Now living in the Great White North.
You may think you know what you're talking about, but the only person you're fooling is yourself - Wild Bill Massey
WildBillMassey is offline   Reply With Quote
Old 02-14-2011, 05:33 PM   #472
rcwck's Avatar
Default Ofna Ultra GTP2e
Thanks Snellemin for the reply.
How well will the stock diff rings hold up in a 4S w/Tekin 2050-2150kv motor for road racing with 25/51 ratio? Should I invest in hardened steel rings from the get go? Are there any other weak points in the stock car?
What's the approx mph on the straight and run time with a good 5000mah lipo on a large track with a straight of ~200'? Nitro GT's can go 7 minutes on a tank and average 25 second laps and 52-55mph straight speeds?
What starting and ending RPM range should the timing be applied with the above set up and how much? Tekin ESC of course.
Thanks for your replies.
Old 02-16-2011, 03:34 PM   #473
Since nobody has a motor mount for my older gtp , yes rcmonster makes one-out of stock forever now, plus not bashing it I just dont care for a 2 bolt down setup, figured I'd make my own, this just showed up today
Joat is offline   Reply With Quote
Old 02-16-2011, 03:58 PM   #474
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
sweet how much did the cost you? wouldn't mind have those in my shop garage...
OVA is offline   Reply With Quote
Old 02-16-2011, 05:02 PM   #475
$1200 shipped with some tools ,and thats to hawaii !!!!!!,shipping was $215
Old 02-16-2011, 09:17 PM   #476
bennytheblade's Avatar
milling machine ftw.
bennytheblade is offline   Reply With Quote
Old 02-16-2011, 10:02 PM   #477
Bmr4life's Avatar
Trader Rating: 50 (100%+)
New or used? I want one for real.
Too many RC's to list.
Bmr4life is offline   Reply With Quote
Old 02-16-2011, 10:20 PM   #478
Brand new,it's a special edition sieg sx2, it's a pretty decent mill once gone thru and adjusted etc, if you want a small mill out of the box that's ready go with a sherline ,smaller though and not as much power
For sieg machines sold at grizzly ,harbor freight,travers etc
x0 -micro mill
x1 mini mill
x2 -older model
sx2 - super x2 -brushless -sold at micromark.com
sx2 super special x2, sold at Littlemachineshop.com, bigger table then sx2
I have a Sieg made grizzly 7x12 lathe , my runout is .0005 or less typically,.0002,it's been modded alot ,but no cnc yet
For info go here -
http://www.mini-lathe.com/Mini_mill/...%20SX2/SX2.htm
What I bought
http://littlemachineshop.com/3900 and this too
http://littlemachineshop.com/product...ProductID=3489
Old 02-17-2011, 10:15 AM   #479
For those that are looking for the Alpha Brushless Tires, we have them on the site now....
http://www.igthobbies.com/product_p/alp12704.htm
Old 02-17-2011, 04:13 PM   #480
Stock ring gears in the OFNA and Kyosho cars are similar material, and they seem to hold up pretty well, but you have to check your mesh regularly. On the Kyosho's we can shim our diffs (checking for backlash), not sure if you can on the OFNA's. If you do not check this regurarly, you will destroy ring and pinions in a hurry, even the hardened ones.
Its hard to say on how long the 5000Mah will last during a race, it all depends on how long you are on full throttle and how much you use the brake. I would take a fully charged battery and time how long it takes to cut-off, and then subtract the time before a race you use for warm-up.
I will have to answer your last question later, and I will download my setup from my Tekin, it should give you a good starting point.
