Old 02-03-2011, 11:49 PM   #451
kcunamay's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Jspeed View Post
Go Wide, everything else is just small.
Hello Jspeed,
I'm very interested in the new tire coming out. I've run ipanemas in the past and although they worked great, I found the wheels to be very fragile.
I was wondering if the compound for the plastic has been changed for the ipanema wheels? (regular and the upcomiing wide wheel)
I'd love to test the new wider wheels, but am concerned about the durability. Thanks!
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 02-04-2011, 12:15 AM   #452
Jspeed's Avatar
We’ve updated our wheels with reinforcements to increase nylon durability. Unless you enjoy testing the structural integrity of track barriers, pipes, curbs or other immovable objects you’ll have no problems with our racing products.
They’ve been tested & proven during the 45 minute GT Open class A Main at the 2010 GT World Championships and also during the 2010 USGT Nationals in both 45 minute Spec & Open class GT A Mains without any issues; having won all of those events too.
Thanks!
Jspeed is offline   Reply With Quote
Old 02-04-2011, 12:52 AM   #453
kcunamay's Avatar
Thats good to hear. I'll be getting a set. I'm curious to see the differences. Thanks!
Old 02-05-2011, 10:20 PM   #454
GUYS, my car has no ground clearance at all, the bumper on the bottom where the 2 screws are at scrapes the asphalt. How much ground clearnce do you guys have on your car? what should i do or adjust o this car to get a higher ground clearance? thanks ill post picks tomorrow
Estuardo305 is offline   Reply With Quote
Old 02-05-2011, 10:48 PM   #455
FangsCPO's Avatar
I've got 9mm front and 11mm rear. Your shocks can be adjusted to either raise or lower your ride height. That's what I have but others may be different. It all varies on your preference and what works for your based on your tires and suspension in regards to springs used and oil weights. Good Luck!
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 02-08-2011, 07:12 PM   #456
treborwd22's Avatar
Well it finally arrived!!! Hope to test it out sometime this week and get it ready to race by the 18th!!!
Thanks igthobbies!!!
Team Associated Tc6 "Blinky"
Xray T2 Exotek "Spec GT Class"
Ofna GTP2e w/Tekin RX8 2250kv
Losi SCTE
Spektrum DX3r Pro
treborwd22 is offline   Reply With Quote
Old 02-08-2011, 07:52 PM   #457
kcunamay's Avatar
Nice!
Old 02-08-2011, 08:00 PM   #458
drpower's Avatar
Dude...The car above this post is SICK!!!
OK, GTP2E RX8 2250Kv...what is your opinion for best lipo for high speed, I'll have whatever pinion is stock with the kit and I ordered RC Monster 24T & 30T
What about Hobby King Nano-Tech 4S 5000Mah 45C~90C --- $76 ...what 5S or 6S can you recommend or is this a bad idea? Maxamps, Thunder Power???
P.S. still looking for a painter.
drpower is offline   Reply With Quote
Old 02-09-2011, 08:44 AM   #459
snellemin's Avatar
Trader Rating: 16 (100%+)
I only have a 4s gearing info. 47/28 and 8-10 degrees timing.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 02-09-2011, 08:25 PM   #460
FangsCPO's Avatar
Wow!! Are you running that gearing, 47/28 because of your motor kv?? I'm running Tekin 2250kv at 16/48 powered by a MaxAmps 6500 4S. I can see going any higher, this thing is stupid fast as it is, than again I'm a rookie at this.
TLR Team Driver
Old 02-10-2011, 03:51 AM   #461
snellemin's Avatar
Well speed and the 2250 motor is mentioned, which is the truggy motor. That motor can pull some tall gearing. I ran the Plettenberg BigMaxximum which is 2300kv on the 47/28 gearing on 4s. Currently running a 1515 2700kv motor on the same gearing and 4s. I'll find a way to fit the 30T pinion on my motor mount.
I just received 2 more 4s Acepow lipos, the new 50Hz Eagletree logger, Eagletree 10hz GPS receiver for my 4s 100mph quest.
6 KiloWatt Racer
Old 02-10-2011, 12:39 PM   #462
superspeed's Avatar
Giant touring car, nice
superspeed is offline   Reply With Quote
Old 02-10-2011, 05:41 PM   #463
FangsCPO's Avatar
There's no "touring" when dealing with these big boys. The speed is awesome!!!! These are collectively called GT8's.
TLR Team Driver
Old 02-10-2011, 06:48 PM   #464
Team Alpha R/C's Avatar
Send a message via MSN to Team Alpha R/C
In my Ofna GTP2e i have a problem, i need buy some springs more hard, the original springs are soft , in the track my car is losing time because is necessary a car more hard , i ordered the parts , but until i receive , i'm using the shocks of my Kyosho GT2 , and it's working very good , my car was very fast in the track.
I changed the original pinion because is too short , now my car are bringing "troubles" to 1/8 GT gas powered , this is very good!
Team Alpha R/C
Team Alpha R/C is offline   Reply With Quote
Old 02-10-2011, 07:11 PM   #465
drpower's Avatar
Very Nice Team Alpha... Everyone please post a pic of your GT!! I am still waiting for mine in the mail...
