Old 01-27-2011, 05:28 AM   #391
Originally Posted by MambaPower87 View Post
thanks!
Really ur getting a tekin? I just ordered mine too....I want to compare from the mmm to a tekin 2650kv...let's see how it goes....
Yep, just the motor to use in sensored mode on my MMP, but only in May...
Down here in Brazil the stores are way too expensive and if I order by mail I have to pay 60% of tax on the product + shipping! too much money!
I'll be going to the US on May (Vegas, SF, LA and NY) and I willl buy in this trip.
rpompeu is offline   Reply With Quote
Old 01-28-2011, 05:50 AM   #392
bennytheblade's Avatar
First post.
This thread rocks.
Just got this in the mail and cant wait to get it together.
bennytheblade is offline   Reply With Quote
Old 01-28-2011, 06:36 AM   #393
Team Alpha R/C's Avatar
Send a message via MSN to Team Alpha R/C
Hello, first post in this topic .
Finally i received my batteries from Hobby King .
I will debut my Ofna this weekend.
Soon i will post pictures and videos about my first impressions about this car.
Team Alpha R/C
Team Alpha R/C is offline   Reply With Quote
Old 01-28-2011, 06:43 AM   #394
Bmr4life's Avatar
Trader Rating: 50 (100%+)
And tell us your setup!!
On a side note. Its a center diff a required upgrade?
Too many RC's to list.
Bmr4life is offline   Reply With Quote
Old 01-28-2011, 08:46 AM   #395
Hey Alpha! (Marcos? Marcel?)
I saw a picture of the Alpha R2 Body on rcmasters and I was sure it was an electric car, was this car the GTP2e? I thought you guys had only GP cars... Welcome to the smokless side of the force!
So, what is your ESC/Motor setup? Please, after the tests, imform us how it is compared with the GPs.
Abraços,
Pompeu
Old 01-29-2011, 10:35 PM   #396
treborwd22's Avatar
Guys... I just got my Tekin RX8 w/2250kv motor in today. Being new to the electric world of RC my question is will this motor handle different because it’s a truggy motor (longer more torque) or should I have gotten a 2050kv or 2650kv motor instead?
Team Associated Tc6 "Blinky"
Xray T2 Exotek "Spec GT Class"
Ofna GTP2e w/Tekin RX8 2250kv
Losi SCTE
Spektrum DX3r Pro
treborwd22 is offline   Reply With Quote
Old 01-29-2011, 10:46 PM   #397
FangsCPO's Avatar
That's what I'm running geared at 17/48, 4S 6500 Lipo, Tekno Traktion Drive and center diff. Temps are never a problem and you have tons of power for the straight aways. You'll need to take it easy on the trigger.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 01-29-2011, 10:54 PM   #398
treborwd22's Avatar
Ha... when you say take it easy on the trigger (something I never do) will I be able to control that with my throttle curve on my 3pks? In Austin we have a small track that can be tight and technical at times, http://www.youtube.com/watch?v=0nk-iTpKZ3E but I wanted something that would be good for when I go visit the larger tracks in Texas.
I also think the stock spur gear on the GTP2e is a 51. Should I start with 14 pinion?
Losi SCTE
Spektrum DX3r Pro
Old 01-29-2011, 11:15 PM   #399
RC Passion's Avatar
Yeah, i'd use a less aggressive curve, I even turn down the current limit on my rx8. Try curve 3 (C3) on the esc with no timing advance to start with if traction is a issue.
A 15th pinion is a good starting point. Then you can gear up when u get comfortable with the speed. 2 speed is the ticket for larger tracks though like 200ft plus tracks or else you'll be eaten up on the straight..................
RC Passion is offline   Reply With Quote
Old 01-30-2011, 01:20 PM   #400
snellemin's Avatar
Trader Rating: 16 (100%+)
I swapped out the Pletty for the Tekno Nue 1515 1.5D motor and ran it last nite with the 28T pinion + 4s Acepow. Calculated speed is around 80mph and it sure looked like it went that fast. I did this run with the Ofna Blue foam tires that has about 2-3mm of foam on the rim. I blew foam ups before with less speed. But I figured because that was with fresh uncut foam tires. Lesson learned. The Tekin only had 3 lights on and the motor wasn't even sweating after a few speed runs. Waiting on my V4 eagletree logger and gps receiver to arrive to post some real speeds and verify/tweak my excel calulator.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 01-30-2011, 02:22 PM   #401
simplechamp's Avatar
Trader Rating: 73 (100%+)
What speed calc are you using there? You made it yourself in Excel?
Serpent 811Be - Jammin X2 Carbon e-GT conversion - Axial SCX10 Honcho
simplechamp is offline   Reply With Quote
Old 01-30-2011, 04:27 PM   #402
snellemin's Avatar
That calculator is my latest version and is pretty accurate with sensorless motors. I'm just waiting on my V4 eagletree and gps to verify the timing and Motor winding feature. After that I can work on calculating sensored systems.
6 KiloWatt Racer
Old 01-30-2011, 04:39 PM   #403
If you're ever looking for a beta tester...
Old 01-30-2011, 07:05 PM   #404
WildBillMassey's Avatar
Robert, get with me at the track when you are ready to race, and I will show you the setup in my 4PK. I did some tweaking with the throttle speed setting in the radio, and it made a huge difference, since I also have that on/off trigger finger.
Former owner of The Nitro Pit and IGT Hobbies
Now living in the Great White North.
You may think you know what you're talking about, but the only person you're fooling is yourself - Wild Bill Massey
WildBillMassey is offline   Reply With Quote
Old 01-30-2011, 08:08 PM   #405
treborwd22's Avatar
Bill.... Did you run that new 2250kv motor Sat or are you still running that 1900kv?
Losi SCTE
Spektrum DX3r Pro
