Old 12-31-2010, 07:54 AM   #316
Trader Rating: 43 (100%+)
If it is not a solid tire it will balloon at 100 mph. Your best bet is foam tires and you need to paint the side walls with CA glue that has the black rubber mixed in to it.
http://www.amainhobbies.com/product_...ughened-CA-1oz
This will keep the side walls from chunking out and knocking them out of balance when you turn around. You will also have to treat the tires with a compound to get them to hook enough and you will have to select a body that will keep it's shape and keep the car on the ground...good luck!!!!!!
crazysavage is offline   Reply With Quote
Old 12-31-2010, 08:05 AM   #317
Originally Posted by Jpm1 View Post
set up tips needed, what are you guys running, droop,shock oil, diff oil, caster,camber toe, etc, i ran mine today and it was all over the place, it pushed and lifted the noise something terrible!!!, i am running the box setup, any help would be awesome......
I like 80wt losi in the front shocks, 100wt in the rear...10k diff fluid front and rear...make sure sway bars are snug in the holder but not binding. 1 degree of camber all around. Sway bars are the easiest way to get this car turning in a neutral manner. If you expose more bar in the rear, the front will turn in harder. If you expose more in the front it will push. Play with shock angle from there.
Old 12-31-2010, 08:12 AM   #318
Bmr4life's Avatar
Trader Rating: 50 (100%+)
thank you very much.
Too many RC's to list.
Bmr4life is offline   Reply With Quote
Old 12-31-2010, 08:18 AM   #319
simplechamp's Avatar
Trader Rating: 73 (100%+)
I have heard the GRP Rally tires are good for high speed runs. I just got a set of them, and while I haven't run them yet compared to my Ofna belted radials the GRP seem much more firm and solid. The compound is tacky, but overall the tire is very rigid. I can see them holding up to very high speeds with little or no ballooning. I'm not sure if they are belted or not. Might just be a very solid design with lots of rubber, doesn't feel like there is much foam (if any? I got them as premounts and this is my first set). Look forward to running them in the spring, as they look to be a very durable and long-lasting tire.
I also would like to pick up a set of the Sweep EXP belted radials and try those too.
Serpent 811Be - Jammin X2 Carbon e-GT conversion - Axial SCX10 Honcho
simplechamp is offline   Reply With Quote
Old 12-31-2010, 08:46 AM   #320
Bmr4life's Avatar
What do the Degree numbers mean for the tires?
Also, do Sweep tires not need foams?
Old 12-31-2010, 03:36 PM   #321
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Will there be a national event for these cars?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 01-01-2011, 11:53 PM   #322
FangsCPO's Avatar
Originally Posted by Bmr4life View Post
Do they balloon? I'm looking for something that can do 100mph.
The PMTs feel pretty solid and are somewhat hard. Wow!!! 100mph. You gonna post a video??
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 01-02-2011, 06:49 AM   #323
Bmr4life's Avatar
Sure. I know its going to take a lot of trial and error as well as me driving to a remote location. My truggy hits 60mph in no time in front of my house. I'm thinking 80mph should be easy with my buggy. 100mph is another story.
Old 01-03-2011, 10:06 AM   #324
veee8's Avatar
I am working on doing the same thing with my GTP2e.
RC8B-Losi .21 350............SC10FT-MMP 4600kv..........XXXCR-Tekin RS 17.5T..........Inferno GT2 Mclaren...........Super Clodbuster..........F103...........Ofna GTP2E Tekin RX8 2650kv 6s and a huge ass pinion
veee8 is offline   Reply With Quote
Old 01-04-2011, 09:38 AM   #325
WildBillMassey's Avatar
Got all the bodies with pictures for the dm-1spec, ultra gtp, and inferno GT1 loaded. There are now 56 bodies to choose from for them.
http://www.igthobbies.com/category_s/27.htm
Former owner of The Nitro Pit and IGT Hobbies
Now living in the Great White North.
You may think you know what you're talking about, but the only person you're fooling is yourself - Wild Bill Massey
WildBillMassey is offline   Reply With Quote
Old 01-05-2011, 08:29 AM   #326
veee8's Avatar
Can you tell me if the Kyosho GT1 and GT2 pre painted bodies have holes cut into the windshield area for nitro engine cooling? The bodies look awesome, but for brushless, would like like crap with big holes cut into them.
Old 01-05-2011, 08:32 AM   #327
All clear bodies come uncut
EDIT: whoops, just realized you asked about painted, not clear. i will check, i can't remember if they are or not.
ANSWER: Painted bodies do not have holes in the windows, but does have a small hole in the side for the exhaust.
Old 01-05-2011, 12:56 PM   #328
veee8's Avatar
Thank you!
Old 01-05-2011, 01:48 PM   #329
Trader Rating: 31 (100%+)
Send a message via Skype™ to vstrok
I am just looking to pick one up for fun and some parking lot speed runs. What do you all think about going cheap and putting a Hobby Wing system in it?
vstrok is offline   Reply With Quote
Old 01-05-2011, 01:57 PM   #330
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Awesome site. Great selection of IGT stuff.
YR4Dude is offline   Reply With Quote
