Old 12-08-2010, 10:26 PM   #286
anyone know if you can do the ball bearing steering upgrade like some of the off road ofna's ?
Joat is offline   Reply With Quote
Old 12-08-2010, 10:36 PM   #287
MambaPower87's Avatar
Trader Rating: 19 (100%+)
MAMBA MONSTER 2200KV ON 6S (THE BEST CHOICE I HAVE EVER DONE IN MY LIFE...NO REGRETS!)
MambaPower87 is offline   Reply With Quote
Old 12-09-2010, 01:36 PM   #288
Bmr4life's Avatar
Trader Rating: 50 (100%+)
Any of you all have videos of your GTP's?
Too many RC's to list.
Bmr4life is offline   Reply With Quote
Old 12-09-2010, 03:10 PM   #289
snellemin's Avatar
Trader Rating: 16 (100%+)
I only have older vids of mine dragracing at the LHS parkinglot on youtube.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 12-09-2010, 04:02 PM   #290
Bmr4life's Avatar
I've seen those. Have you changed the setup since?
Old 12-09-2010, 05:55 PM   #291
snellemin's Avatar
It runs the Hacker 6L motor now on 4s2p A123. I will finish installing PCR goodies in my second one first and go back changing up the first one.
First one will see an 8s A123 setup with a 1520 1600kv Castle motor. ESC will be the LT-120A 10S Lutach esc. Should be one efficient torque monster. Purchased some more EC5 connectors and 6mm bullets for that setup today.
New vids will be posted soon enough.
6 KiloWatt Racer
Old 12-09-2010, 11:07 PM   #292
Default need part #'s and suggestions
I need some part #'s?
I am doing a gtp to e conversion, I tore down my gtp and going thru it, I need to shim the pinions, what is the part # for a shim kit?what weight silicone for the diffs,only bashing,shock fluid wt?
T.I.A
Old 12-10-2010, 02:38 PM   #293
FangsCPO's Avatar
T.I.A
Last time I needed shims, I ordered these from Nitrohouse:
OFN10099
OFN10410
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 12-12-2010, 12:54 AM   #294
Jpm1's Avatar
set up tips needed, what are you guys running, droop,shock oil, diff oil, caster,camber toe, etc, i ran mine today and it was all over the place, it pushed and lifted the noise something terrible!!!, i am running the box setup, any help would be awesome......
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 12-13-2010, 06:26 PM   #295
Jpm1's Avatar
Surely someone has some setup tips for this thing?????
Old 12-20-2010, 10:42 AM   #296
veee8's Avatar
Is anyone making a smaller spur gear for the center spool?
What is the top mph someone has reached with the GTP2e? Whats the setup?
My goal is 100 mph on 6s. I am running RX8 and 2650kv, I have some custom pinions coming from Kershaw, but I feel the limiting factor is going to be the stock 52t spur.
RC8B-Losi .21 350............SC10FT-MMP 4600kv..........XXXCR-Tekin RS 17.5T..........Inferno GT2 Mclaren...........Super Clodbuster..........F103...........Ofna GTP2E Tekin RX8 2650kv 6s and a huge ass pinion
veee8 is offline   Reply With Quote
Old 12-20-2010, 10:50 AM   #297
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
Look on youtube I think their are guys that already hit that mark.
snrscion is offline   Reply With Quote
Old 12-20-2010, 11:02 AM   #298
veee8's Avatar
I saw one that was like 92 mph
I am not trying to break any record or anything, just whopp locally. There are a bunch of these GTP's popping up locally. All are running MMM's, I went with the RX8 system.
I was so impressed with the RS and the Hotwire compared to my MMP and Castlelink, I wanted to see how the RX8 compared to all the others running the MMM locally.
The spur gear is a mystery to me though.
Old 12-20-2010, 11:05 AM   #299
Registered User
snrscion's Avatar
RX8 for road racing is very smooth ESC you made a good choice. I personally run a MMP with a Tekin 2650 sensor mode.
Old 12-20-2010, 11:37 AM   #300
snellemin's Avatar
There is a 47 spur for the spool that comes off a Blazer I believe. But if you are using a 1512 size motor like the Tekin 2650, stick with the stock 51T spur. I use the plastic version, for reduced rotating mass. One GTP of mine runs the 47T, but with a bigger motor. The other with a smaller 4000kv motor, runs with the 51 spur.
6 KiloWatt Racer
