Old 11-29-2010, 02:30 PM   #241
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
Once again guys, can anyone tell me if you trim the foams before fitting glueing? Just got my kit and they seem long???
Thanks again in advance......
Sorry to post this again but these foams piss me off, can you buy one piece foams for these things or is there something I'm missing? I even took them down to my LHS and he handed them back lol.
Can someone walk me through it?
Ps. HELP
Try these molded insert 81098 from Ofna they work great with the slicks and tread tires.
snrscion is offline   Reply With Quote
Old 11-29-2010, 03:46 PM   #242
Jpm1's Avatar
Ps. HELP
Thanks for that snrscion, they do look a lower profile foam on the ofna site?, they do fit in the gtp2 tires in the kit???
Anyway just ordered some from the LHS hope they make it easier....
Thanks again
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 11-29-2010, 06:35 PM   #243
Vision's Avatar
Trader Rating: 38 (98%+)
snellemin, what are the advantages of putting the caps on the tekin rx8 ?
6iX, GTP2e, XO-1, DM1-E, ST-R/MP777 GT2 Hybrid, GT2-VE, GT2-E Circuit, Hybrid Vorza, Rampage XB-E, Slash Platinum, tc5R
Vision is offline   Reply With Quote
Old 11-29-2010, 07:20 PM   #244
snellemin's Avatar
Trader Rating: 16 (100%+)
Time Travel.....
The caps in the RX8 are rather short and can't dissipate as much heat as a taller cap.
Ripple current is reduced.
Safer to run cheaper packs(high resistance lipo's).
Better braking.
Cooler running ESC.
The ability to run a 2.5T motor on more than 2S in 1/10. I used 3s A123 with a 2.5T motor in a CRT.5.
I can run a 4000KV 1/8 scale motor on 4s or 4s2p A123 for dragracing my other GTP.
Less stress on ESC during braking when running at max Voltage.
I also have 2 TVS installed to clamp the voltage down during braking when running at the ESC voltage limit.
I still have 2 of the first generation RX8 running like a champ.
The MMM has taller caps installed and can handle some serious power. But the Tekin is so much smoother to race with.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 11-30-2010, 08:55 AM   #245
-TC5racer-'s Avatar
Trader Rating: 40 (100%+)
Snellemin you gotta tell them what TVS means.
GTPe-RX8-Neu 1515/1D | DM-1Se-RX8-Plettenburg MAXX | Losi GT8e-RX8-Hacker C50-9L |X1 CRT Pro-MMM-CC1717 | SCRT10-RX8-Hacker CMaxx | MHyperSte-RSpro-LMT XL4200 | TC5-RSpro-LRP 4.5 | TC3-RSpro-LRP 10.5 | B44-R1pro-Tekin 268
Just to name a few!!!
-TC5racer- is offline   Reply With Quote
Old 11-30-2010, 10:17 AM   #246
snellemin's Avatar
Transient Voltage Suppressor
6 KiloWatt Racer
Old 11-30-2010, 03:14 PM   #247
Jpm1's Avatar
This is a newbie question as I've never owned a touring car before!, but if these cars are based on a 1/8 buggy why don't they have a centre diff, what are the advantages of the spool for on road vs the diff, wouldn't the diff give some more adjustability? Or is it not needed?
Could someone explain this to me?
Cheers....
Old 11-30-2010, 03:53 PM   #248
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Cheers....
It' simple. Not having a diff brings the cost down of the kit. It is in fact advantageous to have a center diff in Low Traction Situations.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 11-30-2010, 04:03 PM   #249
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Cheers....
For onroad, the center diff is not necessary. The added rotational weight plus the drag from diff gears actually will hurt the performance of the drivetrain. The basic premise is that onroad has way more traction than that of offroad so the need for a center diff is not necessary.
Spools are usually used on the front. A spool / solid axle has no diff action when going through turns. It is positraction all the way. People have found that using a front spool on high traction surfaces provide more control in terms of throttle and brake versus a diff. If you look at what most of the fast guys are running on their 1/10th electric TCs they're mostly running a spool up front.
YR4Dude is offline   Reply With Quote
Old 12-01-2010, 07:30 AM   #250
-TC5racer-'s Avatar
YR4 I think you misunderstood his ? because I haven't seen any (everyone correct me if I'm wrong) front spools for 1/8 buggies.
Jpm1 in this application Charlie B's answer is correct!!!
Old 12-01-2010, 08:31 AM   #251
snellemin's Avatar
This is from King Headz. Front Full One-Way Assembly
6 KiloWatt Racer
Old 12-01-2010, 08:45 AM   #252
-TC5racer-'s Avatar
I stand corrected!!!!!!
Old 12-01-2010, 09:26 AM   #253
Trader Rating: 77 (100%+)
anyone looking for a gtp2? i have one in the for sale section...lmk thanks!
artoftatt2 is offline   Reply With Quote
Old 12-01-2010, 02:48 PM   #254
Jpm1's Avatar
I was just curious about the no center diff option?, I'll only be bashing and light track work so I won't need the front spool I think......
I'd buy that gpt2, cause mine still hasn't arrived, it's been sitting in LA since the 25th!, why does nitrohouse use USPS, it will be the last time I buy from them unless they can send through ups..... Grrrrr
Old 12-01-2010, 03:10 PM   #255
Jpm1's Avatar
