Old 11-22-2010, 10:09 PM   #226
Jpm1's Avatar
Thanks for that info kcunamay, I got the kit plus the cc2650 combo off nitrohouse, I also bought a tekin 2650 and I'll see which 1 I like and sell the other one on ebay.
In relation to the Tyres, do you glue the narrower foam to the wheel?, do you know of any YouTube vids that show the fitting of the tires.
Anyway can't wait for it to turn up now!!!
Jpm1 is offline   Reply With Quote
Old 11-22-2010, 10:16 PM   #227
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
What kind of temps are you guys getting running the 2650 on 4s?
Are vent holes on the body used on electric onroad? I know with 1/8 buggy, its a necessity.
BOLISARIO is offline   Reply With Quote
Old 11-23-2010, 12:49 AM   #228
kcunamay's Avatar
Trader Rating: 20 (100%+)
I'll temp it next sunday during race conditions.
But as a measuring stick... I can hold the motor with my bare hands after killing a 4500mah 4s pack bashing around in front of my house. No holes on my body aside from the body posts. I have no fans on the motor and I am running the stock gearing.
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 11-23-2010, 01:08 AM   #229
kcunamay's Avatar
I guess you could....but I didn't. Just glued the ends of the thick and thin foams together, put them into the tires and then mounted them onto the wheels.
The tires are great for bashing around. Even when completely bald, they have life until the tires get too thin and tear apart.
Old 11-23-2010, 10:57 AM   #230
FangsCPO's Avatar
Those tires were no joke when I had to mount them. I did a crappy job and now all I have for my DM-1 S is pre-mounted stuff. PMTs and Sweeps. You can also buy the OFNA stuff premounted but those are just good for bashing as it was previoulsy mentioned by someone else. Good Luck!!
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 11-23-2010, 11:08 AM   #231
FangsCPO's Avatar
Wow!! That sounds really low temp. I'm curious, what's your gearing (stock ??) and motor/ESC setup. I'm running a 6500 mah so I can see mine getting a little hotter.
TLR Team Driver
Old 11-23-2010, 05:09 PM   #232
Jpm1's Avatar
Do you trim any off the foams before glueing them?, they seem long!!!
Old 11-23-2010, 10:33 PM   #233
kcunamay's Avatar
When I was running the GTP2E, I ran the stock gearing of 51/14 with the RX8/2650KV combo
It didn't get very hot at all. I was just bashing around though. I believe using the brakes is what generates the most heat, therefore race conditions will probably get the temps a little warmer. Last time at corona, I didn't temp the motor so, I don't have a solid number to provide. But I am certain it was well below the max of 180 degrees I've been told to stay under. If I had to guess....perhaps 130?
The WOT runs I do on my street, turn around and then do it again till the voltage cutoff kicks in just isn't enough to stress things out.
Old 11-24-2010, 07:11 AM   #234
Justpassedu's Avatar
Trader Rating: 115 (100%+)
Not sure if anyone is interested but I am selling a body wheels and tires off of my gtp2e : http://www.rctech.net/forum/r-c-item...-body-new.html
Mugen Mbx6 Eco
Justpassedu is offline   Reply With Quote
Old 11-24-2010, 07:15 AM   #235
snellemin's Avatar
Trader Rating: 16 (100%+)
Well I blew up my Pletty last Sunday. Was the perfect kv and powerband for the GTP. My next motor options are either another Pletty Max, C50-8L Hacker or the 2650 Tekin. The reason I like the Pletty and Hacker motor, is the spoolup is quicker for onroad and dragracing. But there goes the money I was going to use to buy SNR chassis.
So for now I swapped in the Pletty BigMax, which is 2300kv. Too much torque, even with the smaller spur and 23T pinion.
Well the KingHeadz parts arrived and installed the extra beef. I'm using the hardend ring gears in the diffs as well. I can throw whatever power at my diffs now and not have to worry about breaking the plastic diff case cap again.
Pletty blown up rotor
These are the caps I use on my Tekin esc's.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 11-26-2010, 09:23 PM   #236
Jpm1's Avatar
Once again guys, can anyone tell me if you trim the foams before fitting glueing? Just got my kit and they seem long???
Thanks again in advance......
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Old 11-26-2010, 10:20 PM   #237
i had the same problem bad in when i first bought minelol i just cut it wether it was right or not i dont knowlol
scrivtwin2 is offline   Reply With Quote
Old 11-29-2010, 06:52 AM   #238
Will the ipanema warrior body fit the gtp2e since it fits the dm1 and kyosho car ?
Mugen Mbx6 Eco
Old 11-29-2010, 08:01 AM   #239
Jspeed's Avatar
Yes, the Warrior is designed to fit all GT & Rally/Game cars.
Jspeed is offline   Reply With Quote
Old 11-29-2010, 02:08 PM   #240
Jpm1's Avatar
Sorry to post this again but these foams piss me off, can you buy one piece foams for these things or is there something I'm missing? I even took them down to my LHS and he handed them back lol.
Can someone walk me through it?
Ps. HELP
