Old 01-06-2015, 01:15 PM   #2071
Default ground clearance
What ground clearance do you guys run for bashing or speed runs? Where on the car do you measure clearance from?
tc4basher is offline   Reply With Quote
Old 01-06-2015, 01:25 PM   #2072
Trader Rating: 25 (96%+)
really depends on the surface you're running... if it's a super flat parking lot without any bumps, then the lower the better... 9mm front and 7mm rear would do nicely for me.
If you're on an unprepped street with chunks of loose gravel or pot holes... then I would increase the necessary height to clear any such obstacle as measured.
billdelong is offline   Reply With Quote
Old 01-06-2015, 05:14 PM   #2073
Where do you measure from? The lowest part of the car(front bumper mount)?
Old 01-06-2015, 05:52 PM   #2074
Here is an example of how to measure ride height from the Hudy guide:
http://www.hudy.net/xhudy/showfile.p...252739b1ad8c24
Old 01-06-2015, 11:20 PM   #2075
Thanks!
Old 01-06-2015, 11:22 PM   #2076
Default 8mm pinion as spur gear?
I saw a youtube video of a DM1 speed car using an 8mm pinion gear without any adaptor as a spur. Can this also be done on a gtp2e?
Old 01-07-2015, 05:14 AM   #2077
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I have the RC Monster adapter in mine. I don't see how you'd have enough teeth on an 8mm bore pinion. I see RC Monster has a 21 tooth Mod 1. If you used that as a spur and their 12 tooth as a pinion, the car would be ridiculously fast. But, It would work.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 01-07-2015, 02:56 PM   #2078
Anyone else running an 8mm pinion as a spur? Does having a metal pinion and spur combo wear the gears a lot faster? Who sells 8mm mod1 pinions? I couldnt find any on ebay.
Old 01-09-2015, 02:56 PM   #2079
Default OFNA foam tires
Are the OFNA foam tires (OFN82031-P) any good?
I was thinking about getting a "blue dot" set(medium shore). I would primarily be using them for speed runs and light bashing
Old 01-13-2015, 10:42 AM   #2080
MikeGozz's Avatar
all you need to do is apply fresh grease around the gasket and rubber o ring, if the rubber o ring is torn, you'll want to replace it.
Thanks Bill! I took the diff apart and noticed the small (really small) gasket. After straightening it out, refilling the diff it hasn't leaked at all. I applied some grease to it too so hopefully I'll be good to go.
Mike
MikeGozz is offline   Reply With Quote
Old 01-17-2015, 09:22 PM   #2081
Noob here, first post on an awesome thread
I finally gave in and got a gtp2e on tower (first payment of three paid)
I've read ever single post of this thread and learned a ton of stuff, I've seen a set up a couple places, where there are turnbuckles attached to the upper arms on the front and the front aluminum plate. What does this help with? Slop? Or is it just a looks thing (looks cool anyways) hoping to get this paid off this week, start my build have a good set up in mind not gonna race, just do speed runs
Bwally is offline   Reply With Quote
Old 01-17-2015, 09:33 PM   #2082
Kershaw design's, cannot post a link but I found this out even before I bought my gtp2e and they come in tons of sizes. I'm thinking about running 34/34 for speed runs
Garage so far...
.21tm powered rc10gt
Ofna gtp2e (build up coming soon)
Old 01-19-2015, 05:36 PM   #2083
http://kershawdesigns.com/PinionsMod1.htm
Here's the link to kersaw's mod1 pinions. Definitely the cheaper way to go instead of buying a spur gear adapter. Does running metal on metal pinions/spurs wear them both out.? I've always run plastic spurs.
Old 01-19-2015, 07:13 PM   #2084
I've run metal on metal no problems so far. Only thing is keep your motor screws tight, I've had a motor come loose running metal on metal and it slid the motor far enough back to unmesh the gears, talk about sparks flying
Garage so far...
Old 02-01-2015, 03:21 PM   #2085
Default 97.8 MPH
I did a couple 6s speed runs today. I was hoping to break triple digits with the stock spur but not quite.
Ofna Ultra GTP2e-97.8.jpg   Ofna Ultra GTP2e-gtp2-xo1.jpg   Ofna Ultra GTP2e-gtp2-outside.jpg
